Latest post Fri, Aug 26 2011 11:21 PM by MichaelP. 3 replies.
  • Fri, Aug 26 2011 3:45 PM
    Exporting a Stereo image to non-stereo QT
    We're working on an animated project.  The project is being done in 3d.  Getting the side-by-side stereo images into Avid is no problem.  We can view the side-by-side as a blended file in the Stereo Frame Layout in the Composer Settings also with no issue.
    We'd like to export a single eye or blended image QT, but when we export the QT comes out side-by-side.  Is there a way to export a QT which shows only one eye or blended image?  Is a third-party software required?  Is there a different workflow other than just a standard export of a QT?
    MC5.5.1
    Metafuze 2.5.0
    Unity 5
    HP Z400 | MC 5.5.3 | Mojo DX | Unity | Quicktime 7.6.8 |Windows 7 [view my complete system specs]
  • Fri, Aug 26 2011 4:31 PM In reply to
    • MichaelP
    • Boston
    • Posts 2,444
    • Points 30,415
      Avid Employee
      Moderator: Film
      Moderator: MetaFuze
    Re: Exporting a Stereo image to non-stereo QT
    You need to apply a DVE on the top level track to correct for the eye you want exported and at the proper aspect ratio.
    Michael
    24p.com
  • Fri, Aug 26 2011 4:43 PM In reply to
    Like 3d Warp?  Or is there a specific effect?  (Do you have a fave or preferred one?)
    Thanks!
  • Fri, Aug 26 2011 11:21 PM In reply to
    • MichaelP
    • Boston
    • Posts 2,444
    • Points 30,415
      Avid Employee
      Moderator: Film
      Moderator: MetaFuze
    3D Warp will work fine. Once you set it up to your preferred eye, save it to the bin for easy-re-use.
    Michael
    24p.com
