Latest post Thu, Feb 2 2012 1:04 AM by Twosheds. 6 replies.
Page 1 of 1 (7 items)
  • Mon, Aug 29 2011 12:55 AM
    • Twosheds
    • Joined on Wed, Mar 15 2006
    • Melbourne, Australia
    • Posts 86
    • Points 930
    Batch Capture Problems with Symphony 5.5.3
    <Moderator's Note> I have split this off and given it it's own thread. Please do not post unrelated topics in existing threads. Thank you for your cooperation.
    Larry Rubin, Forum Moderator
    I am experiencing Batch Capture problems with Avid Symphony v5.5.3. I am unable to batch capture into Avid with this update. I either get a timecode break error or a video dropped out error when attempting a batch capture. I am able to set an in out and out point and capture a clip but if I then delete the media from that clip and attempt to recapture it I get these errors. If I reinstall v5.5.2, no problem.
    Setup
    MacPro, Mac OS 10.6.5 3GHz Quad Core, 16GB RAM, QuickTime 7.6.6
    Capturing from Telecined Digibeta on a Sony Deck. (So solid video and timecode tracks)
    Is this a known problem or an issue with my setup?
    I know I should update the OS to 10.6.8 but if the update doesn't work it will make it a lot more difficlut to go back to v5.5.2 which is not qualified for the newer OS.
    Media Composer with Symphony option v8.10.0, MacOSX 10.11.6, Avid DNxIO [view my complete system specs]
  • Thu, Sep 1 2011 2:40 PM In reply to
    • Mark Renz
    • Joined on Tue, Feb 21 2006
    • Kansas City, MO
    • Posts 1,040
    • Points 12,945
    Re: Batch Capture Problems with Symphony 5.5.3
    I am having the same issue. Just logged a few clips and tried to batch capture with no luck. I can capture the same clips using capture with marking in and out. I think it is time to go back to 5.5.2
    Media Composer Nitris DX 2018.8 with Symphony option Win10 64Gb Ram * Media Composer 8.8 with Symphony option Nitris DX Dual 2.66GHz "Westmere"... [view my complete system specs]
  • Tue, Oct 25 2011 9:27 AM In reply to
    • valerio23
    • Joined on Tue, Oct 25 2011
    • Posts 2
    • Points 20
    Hi!
    I'm working on 5.5.3 with Nitris Dx and I have tha same problem capturing 1:1 10bit with the batch capture function from a Sony DigitalBeta. If I try to capture in live mode 1:1 10bit not finding any problems.
    Batch capture works only in 1:1 8bit or with compressed formats.
    I'm downloading MC 5.5.2 hoping for a resolution.Confused
    Media Composer Nitris DX 5.5.3 Dual 6 Core (12core) Dell Precision T5500 Win7 64bit 6GB Ram NVidia Quadro 4000 [view my complete system specs]
  • Tue, Oct 25 2011 2:46 PM In reply to
    • valerio23
    • Posts 2
    • Points 20
    Hi!
    I confirm!
    I think it's a bug of Avid Media Composer 5.5.3
    After the installation of 5.5.2 batch capture running again in 1:1 10bit!
    Thank You!
  • Tue, Oct 25 2011 3:00 PM In reply to
    • Mark Renz
    • Kansas City, MO
    • Posts 1,040
    • Points 12,945
    I went back to 5.5.2 and problem went away. Guess I will stay here until someone can get this up the chain and get it looked at. I have tried with support but didn't get an answer.
    Mods can you help??? I can provide a case number if you need.
  • Tue, Jan 31 2012 8:27 PM In reply to
    • Mark Renz
    • Kansas City, MO
    • Posts 1,040
    • Points 12,945
    Ok so I have been running 5.5.3 for a while now and had to revisit a SD project. Wasted an hour trying to batch capture before I realized this bug. Has this issue ever been addressed? I don't do SD much anymore but when I need to....
  • Thu, Feb 2 2012 1:04 AM In reply to
    • Twosheds
    • Posts 86
    • Points 930
    I have tried the latest Media Composer v5.5.3.2 and I am still getting the same Batch Digitize errors. It seems independant of resolution. 1:1 10b, 1:1, 2:1 DV420. It did briefly work yesterday at lower resolutions but today, nothing. AVID????
