Latest post Fri, Nov 18 2011 2:59 PM by Kevin Klimek. 6 replies.
Page 1 of 1 (7 items)
  • Fri, Nov 18 2011 12:54 AM
    • redi47
    • Joined on Thu, Nov 3 2011
    • Posts 29
    • Points 355
    PMM_MISMATCH_AUDIO_FORMAT Help please!
    Hello,
    Ive been happily cutting a project for a while and for no real reason that i can see, the messgae PMM_MISMATCH_AUDIO_FORMAT appears now when i try and play my sequence.
    What does this mean???? How can i fix this problem? Your help is greatly appreciated.
  • Fri, Nov 18 2011 1:16 AM In reply to
    • redi47
    • Posts 29
    • Points 355
    Re: PMM_MISMATCH_AUDIO_FORMAT Help please!
    Also,
    Im cutting on MC 5 on a Mac OS X. I have 4 audio tracks, 2 link to the visual clips and two music. If i delete the tracks that arent the music the sequence plays fine, so im assuming there's a problem with the audio link to the video tracks, but they've been fine up unitl now. Anyone no how to trouble shoot this? Thanks for you help.
  • Fri, Nov 18 2011 4:51 AM In reply to
    • Mondo
    • Sydney Australia
    • Posts 1,625
    • Points 18,630
    When you say linking do you mean AMA via Quicktime? If so try importing the audio using the import command instead. Avid will transcode the audio into its native format,
    John
  • Fri, Nov 18 2011 5:08 AM In reply to
    • redi47
    • Posts 29
    • Points 355
    No, sorry I guess linked isnt the right word. I mean 2 audio tracks that relate to the imported media.
  • Fri, Nov 18 2011 5:18 AM In reply to
    • Tom Pearson
    • Joined on Thu, Mar 1 2007
    • Los Angeles CA / Minneapolis MN
    • Posts 2,161
    • Points 23,185
    is th ecamera audio 48khz and the music 44khz by chance
    Mac Pro 3.5 gig 6 core 64 gig ram D700 radons with ssd os drive with a 20 tb raid, Artist Mix and Artist color Artist control [view my complete system specs]
    Tom Pearson
  • Fri, Nov 18 2011 5:25 AM In reply to
    • redi47
    • Posts 29
    • Points 355
    They all appear to be at 48khz.
  • Fri, Nov 18 2011 2:59 PM In reply to
    Can you please fill out your system specs with the exact version of MC you are using and version of the OS?
