Latest post Wed, Nov 23 2011 12:50 PM by hagi. 14 replies.
Page 1 of 1 (15 items)
  • Sun, Nov 20 2011 6:20 AM
    • JeffWoodward
    • Sherman Oaks, California
    • Posts 129
    • Points 1,570
    Need help - MC6! Your ACPL GPU effects are currently ***DISABLED***
    I have an NVIDIA 4000 display card. When I start MC 6, I get a message that my ACPL GPU effects are disabled. I'm assuming that means the display card GPU won't be used to render effects. Is there something that I need to do to enable the GPU effects? Am I understanding this correctly?
    Any advice is welcome. Lots to learn. :-)
    Thanks.
    MC 6.0; 3.20 gigahertz Intel Core i7 970 Multi-core (6 total) Hyper-threaded (12 total); 7.5 Terabytes Usable Hard Drive Capacity; ASUSTeK P6X58D... [view my complete system specs]
    Jeff Woodward LampLight Pictures Director/Editor
  • Sun, Nov 20 2011 7:10 AM In reply to
    Re: Need help - MC6! Your ACPL GPU effects are currently ***DISABLED***
    This COULD mean that you need a newer driver version.
    If it's not trouble to you try the newest one.
    Even if it's not supported.
    Desktop
    Zalman 600W/Asus P8Z68 Deluxe(Gen3)/i7 2600K@4.5/Corsair 16G DDR3/PNY Quadro 2000D(275.89)/WD VelociRaptor 300@10K(OS)/ 2x1TB Samsung F1@RAID 0/LG BH10LS30/Optiarc 7240S/W7 Pro 64bit/MC 6.0.1.1/Matrox MXO2 Mini/2xHP 22'' Monitors/M-Audio AV30 Speakers
    Laptop
    Clevo W170HN/i5 2410(2.30)/4G DDR3/Geforce GT 540M(296.10)/Liteon DS8A5S/W7 Pro 64bit/MC 6.0.1.1
    YouTubeVimeoLinkedIn
  • Sun, Nov 20 2011 7:33 AM In reply to
    • mjolnarn
    • Joined on Wed, Feb 8 2006
    • Sweden
    • Posts 8,883
    • Points 104,600
    JeffWoodward:
    The drivers to be used for it are the ones provided by Avid and situated into Avid/Utilities/Nvidia .
    Are these the drivers you currently are using ?
    Mac: 17" Macbook Pro i7 2,66 ghz with 8Gb Ram, 500gb 7200rpm drive___ PC: W 7 Ultimate Mbo gigabyte 965-DQ6,cpu quad core QX 6700, mem 8 GB Corsair... [view my complete system specs]
    Tomas
    a very happy TAW 5 user
  • Sun, Nov 20 2011 8:45 PM In reply to
    • JeffWoodward
    • Posts 129
    • Points 1,570
    Hi, mjolnarn,
    Yes, I installed the driver that came with my Avid installation.
  • Mon, Nov 21 2011 12:39 AM In reply to
    • JeffWoodward
    • Posts 129
    • Points 1,570
    Bump
  • Mon, Nov 21 2011 4:52 PM In reply to
    • JeffWoodward
    • Posts 129
    • Points 1,570
    Bump
  • Mon, Nov 21 2011 5:08 PM In reply to
    • hagi
    • Posts 244
    • Points 3,280
    Jeff can you confirm that you have driver 275.89, I have the same card as yours, and when I installed MC6, and did not update the driver, I have a message about the GPU so I went to nvidia and downloaded the most current driver, and I still got the message, so I followed what MC6 wanted me to install and that is 275.89, restart MC and everything is fine so far
    PS: Do you mean you see the error during startup or after MC 6 is up and running
    HP Z800 2.9Ghz(2x) 12GB Ram, Nvidia Quadro 4000, HP workstation xw8200 4Gig Ram No Mojo Canon xl2/ HMC150 Media Composer 6.0.0 [view my complete system specs]
  • Mon, Nov 21 2011 10:00 PM In reply to
    • JeffWoodward
    • Posts 129
    • Points 1,570
    Yes, I have driver 275.89 that I installed from the Avid Utilities folder. The message I get when I START MC 6 is this:
    "GPU card and driver are qualified but an error occurred during initialization. GPU accelerated effects will be disabled resulting in reduced effects performance."
    That sounds like all my effects rendering will be sent through the CPU with now help from the GPU. I'm not sure why this happens.
  • Mon, Nov 21 2011 10:18 PM In reply to
    Got caught with this one so no credit to me if it solves it.
    My issue was using VNC which is a remote access service that runs. Seems it interferes with the display calls and causes the issue. So check you have nothing else running in the background that could be interfering with the display.
    ACI Moderator. I'm not employed by Avid or work for them. I just do this in my spare time. Multiple systems: Dual Boot DS10.3.1 - Symphony V5.5.3 MC... [view my complete system specs]
    Pat Horridge
    Technical Director, Trainer, Avid Certified Instructor, Apple Certified Support Professional 10.6
    VET
    Production    Editing     Digital Media    Blu-ray    DVD
    T +44 (0)20 7505 4701 | F +44 (0)20 7505 4800 | E pat@vet.co.uk |
    www.vet.co.uk | Lux Building 2-4 Hoxton Square  London N1 6US
    Avid AMA & Ingest course at VET http://www.vet.co.uk/site/training/scheduled_courses/avid_ama_ingest_and_export_vet_short_courses
    My Youtube videos of motorbike rides
    Now over 1 million hits garage door opener video http://www.youtube.com/watch?v=1C-Bxifv2Pk
  • Mon, Nov 21 2011 10:39 PM In reply to
    • JeffWoodward
    • Posts 129
    • Points 1,570
    Thanks, Pat. Are you referring to services that appear in the Task Manager under the Services tab? I don't have anything that looks like VNC running in the background. I wouldn't know if any of the services that are running would cause a problem. Did you stop services until you found the culprit?
  • Tue, Nov 22 2011 6:51 PM In reply to
    • JeffWoodward
    • Posts 129
    • Points 1,570
    Still need help with this. Anyone know why my Quadro GPU ACPL is disabled?
  • Tue, Nov 22 2011 7:31 PM In reply to
    It was VNC for me but there are other programs and utilities that hijack the display drivers and that can cause an issue.
    Pat Horridge
    VET
  • Wed, Nov 23 2011 7:05 AM In reply to
    • mtahir
    • UK
    • Posts 230
    • Points 2,875
    Jeff, have you tried 276.28 or gone back to 190.38 nVidia drivers?
    MC6 (W7 64-Bit) | MC5.5.3.3 (W7 64-Bit) | Avid XPress Pro 5.8.4 (WinXP SP2) | Dell690 1333MHz FSB | 2 x Dual-Core Intel Xeon 5150 2.66MHz | Quad-Channel... [view my complete system specs]
  • Wed, Nov 23 2011 10:26 AM In reply to
    mtahir:
    What Mohammed says.
    Desktop
    Laptop
  • Wed, Nov 23 2011 12:50 PM In reply to
    • hagi
    • Posts 244
    • Points 3,280
    Jeff, like Pat said, there could be a program that has hijacked your display settings and not allowing MC6 to function properly, I have the same card as you and I dont see that problem. The initial problem I had was that I was being smart and upgraded my driver to the most current at from nvidia website, them I got a similar display message when starting MC6 so I went back to the required driver and problem solved.
    what I would do in your situation is to uninstall MC 6, and install again, if problem solved ok, if not move to the next step;
    Check control panel to determine all programs that you have installed on your PC, determine those that you have installation cd/file that you can install again after unstalling that program
    Start uninstalling your programs one at a time and at each uninstall rebooth your computer and start MC6 to see if problem solved, I believe by doing that you will find the culprit responsible for this error.
    BTW what is your system spec. Also if you dont mine, list all programs installed on your computer here so that people can look through and make suggestions as to which program might be a probable conflict
Avid Technology, Inc. brands:
M-Audio  |   Sibelius  |   Pinnacle Systems  |
