Latest post Mon, Mar 4 2013 7:14 AM by AndrewAction. 10 replies.
Page 1 of 1 (11 items)
  • Mon, Dec 12 2011 9:09 PM
    • mr_zoom
    • Joined on Mon, Aug 16 2010
    • Berlin
    • Posts 45
    • Points 640
    more import options
    While importing files, I would like to have the option to choose between the whole clip or just audio/video tracks only. Sometimes I import clips where I only need the audio tracks but importing the whole thing is so time consuming. Of course I can extract it with mpeg streamclip or wathever but that's another time consuming detour though.
    MC 8.9.2, OS 10.12.5, MacBook Pro Retina 15", 2,7 GHz Intel Core i7, 16GB RAM [view my complete system specs]
    http://tobiassuhm.com/
  • Mon, Dec 12 2011 10:04 PM In reply to
    Re: more import options
    +1
  • Mon, Dec 12 2011 10:36 PM In reply to
    • jwrl
    • Melbourne, Australia
    • Posts 8,387
    • Points 97,025
    Oh, yes, please!!!!
  • Wed, Dec 21 2011 11:34 PM In reply to
    • eddieb
    • Joined on Fri, May 2 2008
    • Ontario, Canada
    • Posts 52
    • Points 715
    Another one here!
    2 x MC 8.3 Nitris DX HP Z820 32GB RAM Quadro K4000 340.84 Windows7/64 QT 7.7.7 Unity 5.1 [view my complete system specs]
  • Sun, Mar 3 2013 7:08 PM In reply to
    • adampaez
    • Joined on Tue, May 11 2010
    • Posts 65
    • Points 825
    Avid really needs to update its importing features. Also it would be awesome to be able to choose various folder/sources to import from. This means you can have stuff organized and not have to move it to a temporary import and import everything from there.
    Maybe a feature where you import folders and Avid creates bin called the same as the folders you have. Would be really efficient.
  • Sun, Mar 3 2013 7:19 PM In reply to
    +1 to the OP!
    adampaez:
    +1 as well!
    Media Composer 8.2 Dongle+Symphony Option Win7x64 Pro HP zBook 15" Laptop - 16GB RAM (2nd System) Media Composer 8.2 Dongle+Symphony Option - HP z420... [view my complete system specs]
     The FunkyDragon
    Happy Editing!
  • Sun, Mar 3 2013 10:27 PM In reply to
    But Import is the old way. AMA is the new way.
    And with AMA you can then select only part to Transcode and which tracks (sort of)
    Now if AMA had alpha support it would allow the few remaining needs for import to be left behind.
  • Sun, Mar 3 2013 10:34 PM In reply to
    Pat Horridge:
    Still reasons to choose classic import over AMA. For instance, BWAV's (and other sound files) are only supported over traditional import. Earlier versions had issues clamping luma levels when using H264 and ProRes over AMA, whereas this worked fine with traditional import.
  • Sun, Mar 3 2013 11:53 PM In reply to
    Job ter Burg:
    Yep. Here we have just had 15% of a group of ProRes files that play fine in Quicktime but open with green over them with AMA. Clasic import works fine. (using a MacBook that is out on hire and may only have QTx)
  • Mon, Mar 4 2013 6:44 AM In reply to
    • mjolnarn
    • Joined on Wed, Feb 8 2006
    • Sweden
    • Posts 13,346
    • Points 159,335
    AndrewAction:
    Job ter Burg:
    Andrew , QTX  or not, have you tried to scroll between different ama plugins instead of the default " use all "
    MIght sometimes help when you get " green " views or other funny things.
    Tomas
  • Mon, Mar 4 2013 7:14 AM In reply to
    Thanks, I will remember that in the future. They were part of a batch all from the same source so it seems strange that most AMA linked no problem and a random few would not.
