Latest post Fri, Dec 23 2011 11:29 AM by hollywoodkhan. 3 replies.
  • Tue, Dec 20 2011 2:15 PM
    transcoding low resalution files in metafuze
    hi all, we have major accquisation going on canon 5d in london, offline post happens in india, we need to send footage(mxf 15 or lower than that) via ftp, is that any posble to transcode low resalution mxf via metafuze?
  • Thu, Dec 22 2011 9:24 PM In reply to
    Re: transcoding low resalution files in metafuze
    DNxHD 15 does not exist. DnxHD 36 is the lowest bandwidth available. See the DNxHD white paper.
    MetaFuze can encode DNxHD 36.
    Igor Ridanovic
    www.HDhead.com
  • Thu, Dec 22 2011 10:18 PM In reply to
    I think the OP means 15:1 SD, and I don't think MetaFuze does SD resolutions.
  • Fri, Dec 23 2011 11:29 AM In reply to
    hollywoodkhan:
    Thnx for the prompt response, apology for the raising this question on metafuze forum, we need lower the resolution in order to send tons of footage to India via ftp, since tried all the pre-sets in metafuz, tried telestream episode pro (trial version) avid offline edit mxf combinations, only default settings mxf detected inside the avid, once started trying to modify frame size, none of them recognized inside the avid, may be its restriction for trial version,
    Right now our roadmap is, import the quicktime files inside the avid, or AMA link, transcoded to 15:1mxf or lower than that, ftp to India get offline edit xml or edl confirmed in London, only issue is we are blocking for avid machine for the transcoding, if we can able to use standalone transcoder such as Sorenson or telestream or metafuze, will be an ideal solution for as,
    Thanking you in advance
