Latest post Mon, Jan 30 2012 7:01 PM by Sylvain P. 14 replies.
Page 1 of 1 (15 items)
  • Tue, Jan 24 2012 2:56 AM
    • Wes Torain
    • Joined on Mon, Feb 22 2010
    • Huntsville-Decatur Alabama USA
    • Posts 65
    • Points 880
    Poor Quality in DVD by Sonic using Media Composer 5.5.2
    I've edited a great looking 20 minute 32GB QuickTime .mov video, but when I send to DVD by Sonic and burn a DVD, I lose quality.  High need a high quality master in order to make multiple duplications.
    Dell Precision T7610-64bit Dual Quad Core Intel Xeon Processors Windows 7-Media Composer 8.3.1 QuickTime 7.7.9 32GB RAM - NVIDIA Quadro FX 3800 Boot Hard... [view my complete system specs]
  • Tue, Jan 24 2012 3:16 AM In reply to
    • Camilo
    • Joined on Fri, Jul 23 2010
    • Virginia
    • Posts 967
    • Points 12,140
    Re: Poor Quality in DVD by Sonic using Media Composer 5.5.2
    How did you take it into Avid DVD?  Did u use a QT reference file and let Avid DVD do the encoding or did you try and encode it first?  If you tried to encode it first, you should just import a QT reference file into Avid DV D and let it encode.
    On another possibility are you working with HD or SD footage?  You indicate your file is 32 GB in size.  A DVD can only hold 4.7 GB of data, so if you are having to reduce the file size down that much, then that would definately be your problem.  If you want to maintain the HD quality, if that is what you are using, you should be writing to a BluRay disk to maintain the quality.
    I hope some of this helps and makes sense...
    Good Luck to you!
    Camilo
    Intel i7-980x Hexacore water cooled by Corsair H-50 on EVGA Classified 762 with 12Gigs RAM and Quadro FX3800 Video Card. Sound Blaster X-fi Titanium Sound... [view my complete system specs]
  • Tue, Jan 24 2012 5:36 AM In reply to
    • Wes Torain
    • Posts 65
    • Points 880
    I shot and edited in 1080 30P.  I exported as a QT.mov not a reference.  I took in the large 32GB file into Sonic and burned to DVD.  Yes I'm working with HD footage and I realize the quality will not be the same as the master, but I've done this before and gotten much better than what I'm getting now.  It just seems something has changed.
    Thank you,
    Wes Torain
  • Tue, Jan 24 2012 5:42 AM In reply to
    • Sylvain P
    • Montreal, Quebec, Canada
    • Posts 1,484
    • Points 17,545
    You can do a video mixdown of your sequence in DHxHD145, then export a QT Ref with the video mixdown on a duplicated sequence.
    Media Composer 2018.5 (Symphony Option), ASUS P8P67 Deluxe, Intel i7 2600k, 16G DDR3-1600, PNY NVIDIA Quadro 2000 (353.82), Windows 10 Pro. Boris Red 5... [view my complete system specs]
    Sylvain Primeau
    Self-employed worker - Les productions Primeau Medias
    primeaumedias.com
    Radio-Canada/CBC news editor
    cbc.ca / ici.radio-canada.ca
  • Tue, Jan 24 2012 7:06 AM In reply to
    Never found Media Composers downconvert to be the best so for quality work would always output an HD size file and convert externally. We have aDigitial Rapids that does a good job and Adobes Media ENcoder is nice as well.
    But the best is laying of to HDCAM and then using the decks SD output and capturing into a hardware mpeg encoder.
    But if limited to using just Media Composer and it's tools I'd go the video mixdown to SD (say 2:1) and then file export and squeeze to MPEG at a flavour Avid DVD accprts without re-encoding.
  • Tue, Jan 24 2012 8:04 AM In reply to
    • jwrl
    • Melbourne, Australia
    • Posts 8,385
    • Points 97,005
    Pat Horridge:
    Never found Media Composers downconvert to be the best so for quality work would lways output an HD size file and convert externally. We have aDigitial Rapids that does a good job and Adobes Media ENcoder is nice as well.
    I think that Pat is being very tactful here.  Avid's downconvert has obviously been designed for speed so that it can be played realtime while you're editing.  For a quality playout or export it's pretty disgusting.  Even Squeeze does a better job of scaling.  The last major SD downsize that I did I used After Effects for.
    (I think I can feel a feature request coming on.)
  • Tue, Jan 24 2012 9:19 AM In reply to
    It doesn't matter whatever you do or how you export it from MC or another NLE to a converter.
    HD and SD can't be compared. If you look one time at a good lighted HD you can't
    lay your eyes on SD anymore. Live with it.
    Desktop PC
    3 Heads Digital Films
  • Tue, Jan 24 2012 9:52 AM In reply to
    jwrl:
    Pat Horridge:
     Me tactful? I must be lossing my grip...
    Yes it's great that Avid has a fast up and down converter. Would be great for an option to switch it into a quality rather than speed mode so it could be more useful.
  • Tue, Jan 24 2012 12:56 PM In reply to
    • Josh Short
    • Joined on Fri, May 13 2011
    • Washington, DC / Northern Virginia
    • Posts 46
    • Points 590
    Try to check your SD transcoding preferences in your project settings in Avid DVD.
    File>Project Settings...>SD Transcoding tab>Superior Quality VBR (8000kbps video; PCM audio)
    The default in mine is set to High Quality CBR and whenever I forget to switch the setting it looks bad (over exposed, jittery, etc.).
    I also usually export a QT reference or take my high quality MPEGs from either Squeeze or Digital Rapids into Avid DVD.
    Hope this helps!
    MC 8.4.2, MacBook Pro with Retina, Thunderbolt display attached, Os X 10.10.1, 8 GB RAM, Intel HD Graphics 4000, QT 10.2, Media Storage - USB3.0 drives [view my complete system specs]
  • Tue, Jan 24 2012 7:47 PM In reply to
    • Wes Torain
    • Posts 65
    • Points 880
    I'll try the video mixdown and export as a QT Ref and compare.  Thanks
  • Tue, Jan 24 2012 7:49 PM In reply to
    • Wes Torain
    • Posts 65
    • Points 880
    thanks, I will do a few tests and see how it turns out
  • Tue, Jan 24 2012 7:51 PM In reply to
    • Wes Torain
    • Posts 65
    • Points 880
    My next question was going to be whether Squeeze would do a better job maintaining good quality...but seems I might already have the answer in your reply.
  • Tue, Jan 24 2012 7:58 PM In reply to
    • Wes Torain
    • Posts 65
    • Points 880
    George Angeludis:
    That part I get.  I am well aware that there is no comparison between HD and SD...but there is a lot of HQ (High Quality) between SD and HD.  And since there is no industry standard, and so many formats and settings to choose from, my goal is simply to get the best quality I can on a standard DVD.
  • Tue, Jan 24 2012 8:18 PM In reply to
    In that case I went some times from the QT to TMPGEnc for mpeg2 creation.
    I warned everyone that the final (while it was fine for SD) wouldn't have anything to do
    with what they saw before.
    Desktop PC
  • Mon, Jan 30 2012 7:01 PM In reply to
    • Sylvain P
    • Posts 1,484
    • Points 17,545
    Me, I like the DVD that are output from a HD Avid DVD project.
    As I said, I do a video mixdown in DNxHD145, then export a QTRef from the timeline and do everything in HD, including the menus, in Avid DVD.
    Finally, I create my DVD from the HD project. Yes, it's longer to encode, but the quality is great.
    Sylvain Primeau
    primeaumedias.com
