Latest post Sat, Nov 14 2015 12:44 PM by rosenprod@aol.com. 372 replies.
Page 13 of 25 (373 items) « First ... < Previous 11 12 13 14 15 Next > ... Last »
  • Fri, Mar 16 2012 8:34 AM In reply to
    • daapap
    • Germany
    • Posts 523
    • Points 6,895
    Re: MC on PC 6.0.1 Bugs
    changing parameter values by cursor-keys in the pan&zoom effect editor goes in steps of +1.0 (+10.0 with the shift key).
    it's almost impossible to adjust the effect exactly with the mouse now.
    until 5.5 it was steps of a hundredth (1.01, 1.02, 1.03, and +1.0 with shift)
  • Fri, Mar 16 2012 7:18 PM In reply to
    • GeorgeD
    • Posts 212
    • Points 2,555
    Motion Effect Editor:
    When Edit Graph is set to Position the Speed graph shows erratic numbers. It is supposed to indicate the current speed, but the numbers are wrong.
     Sometimes it is important to know what the current speed is when keyframes in the Position Graph are adjusted. This is not working.
  • Sat, Mar 17 2012 8:02 PM In reply to
    • Kevin Thompson
    • Joined on Fri, Jun 11 2010
    • Perth, Australia
    • Posts 13
    • Points 175
    When trying to export a 9 minutes MC6.01 timeline as a H.264 .mov
    Exception: std::exception, what: Error c0000005 in thread "CQTExportWorkingThreadBody", ACCESS_VIOLATION, at address 000007FEED52BFB9
    The project has 50 odd clips which exported successfully using the same saved export preset, they were all 10seconds to 4 minutes duration.
    This remaining 9 minute clip will not export. ..failing at about 50minutes of 1hour30minutes
    Note: I have performed both a video mixdown and an audio mixdown, with the same result.
    I never had this problem with 5.5.3 .. successfully.
    There is at least one other report in another thread here.
    Media Composer 6.01 | Dual Xeons @ 2.25 | Quadro 600 | 12G Ram [view my complete system specs]
  • Sun, Mar 18 2012 8:44 AM In reply to
    • Kevin Thompson
    • Perth, Australia
    • Posts 13
    • Points 175
    More info.
    If I divide the sequence into three pieces (subclip it), each sub clip renders without error.
    Is there a time limit bug?
  • Mon, Mar 19 2012 4:04 PM In reply to
    Play Length Toggle does not cause Play button to turn white, which it should according to Help and how it's worked in previous version of MC.
    From Help:
    The Play button and the Play Length Toggle button change to white, indicating the Play Length Toggle feature is active.
  • Tue, Mar 20 2012 4:40 PM In reply to
    • daapap
    • Germany
    • Posts 523
    • Points 6,895
    audio punch in with per/postroll or handles active does not work
    2 places, 2 fully qualified machines aso ...
  • Tue, Mar 20 2012 4:41 PM In reply to
    • daapap
    • Germany
    • Posts 523
    • Points 6,895
    Marquee Titler shows wrong aspect ratio in a 16:9 SD Pal project - as if 4:3 would have been stretched twice. Positioning titles is a mere matter of luck.
    2 places, 2 fully certified machines, several users, all of them totally tired of this software
  • Tue, Mar 20 2012 5:13 PM In reply to
    • DIESELE
    • Joined on Mon, Apr 28 2008
    • Cymru/Wales
    • Posts 1,066
    • Points 13,150
    In frame view when you switch to the composer window to play a selected clip it loses the yellow clip highlight in the bin.  Knowing which was the last clip you viewed is very useful.
    Symphony 2018.11, Blackmagic Intensity Pro (cant get it working well in 4k though for client monitor - which was the point...), WIN 10 on 2000Mbps M.2 SSD, Nvidia Quadro K2000, Asus X99 Mobo, 4.0 GHz Hex core CPU, 32Gb 2800 Mhz RAM, WD Black 8Tb RAID10
    VIDEO MEDIA PRODUCTION COMPANY AND FACILITIES CARDIFF, LONDON, BRISTOL, WALES, CRACKING PRODUCTIONS
  • Tue, Mar 20 2012 5:54 PM In reply to
    • mmtapeop
    • Joined on Thu, Jan 19 2012
    • Posts 18
    • Points 165
    Does the same thing in text mode. I mapped "find bin" to my F12 key so I can navigate back to the clip. It's a pain but it's a work-around until the problem is fixed.
    Avid Media Composer v6.0.1 HP Z800 Workstation Intel Xeon W5580 3.20 8MB/1333 QC CPU-2 HIGHPWR NVIDIA Quadro FX4800 1.5GB PCIe Graphics HP 12 GB (6x2GB... [view my complete system specs]
  • Tue, Mar 20 2012 9:32 PM In reply to
    daapap:
    Count Me in.
    That was the case with MC 6.
    Desktop PC
    3 Heads Digital Films
  • Wed, Mar 21 2012 9:43 PM In reply to
    • Jason
    • Joined on Wed, May 11 2011
    • Toronto
    • Posts 159
    • Points 2,105
    MC 6.0.1 allows you to export a QTRef from a sequence containing HDV material.  Found out the hard way by importing said QTRef clip into Sorenson, compressing for half an hour and it resulted in a 10 minute video of a white screen.  I used to get an error message saying that exporting Long GOP media was not allowed.
    Dell Precision M6500 laptop w/ all updates, i7 X940 2.13GHz, 8GB RAM, Quadro FX 3800M (w/ driver 257.29), Samsung 128 SSD Primary drive & Western Digital... [view my complete system specs]
  • Wed, Mar 21 2012 9:53 PM In reply to
    • Vilem
    • Joined on Sat, Apr 10 2010
    • Prague
    • Posts 1,403
    • Points 15,450
    Jason:
    Long GOP material can be exported as QTref, since the MC5. If you have installed XDcalibrated codec (is paid), reference works correctly.
    V.
    AVID MC2018.12.1 - dongle, HP Z620 - 2 x Intel Xeon E5-2620, Quadro P2000 - driver 390.77, RAM 48GB - DDR3, BM Intensity Pro 4k - 10.11, W10 - 64bit Professional... [view my complete system specs]
  • Wed, Mar 21 2012 10:02 PM In reply to
    • Posts 10,079
    • Points 216,495
    Vilem:
    That is a good explanation, Vilem
    I still do QT refs by first doing video mixdowns of my long GOP material - even in MC6.
    I was disappointed when I realised that the "Now direct Qt refs from Long GOP clips" was only part of the story.
    Nowhere was it clearly stated that you would need to buy an extra codec to be able to view  the QT refs.
    Regards,
    Douglas
  • Wed, Mar 21 2012 10:19 PM In reply to
    • Vilem
    • Prague
    • Posts 1,403
    • Points 15,450
    drbgaijin:
    Vilem:
    Regards,
    Douglas
    Yes, you're right Douglas.
    There is not really highlighted the need to buy the codec. But I must say that my investment in the codec already returned. And both in speed export, thus saving space and order on the HDD.
    V.
  • Wed, Mar 21 2012 11:09 PM In reply to
    • Posts 10,079
    • Points 216,495
    Vilem:
    Thanks for that observation, Vilem
    I think it is time to put my Scottishness aside and dig into my sporran! Geeked
    Regards,
    Douglas
