Latest post Mon, Jul 16 2012 7:03 PM by luca.mg. 39 replies.
Page 1 of 3 (40 items) 1 2 3 Next >
  • Sat, Feb 25 2012 2:37 AM
    • Simon Zimmer
    • Joined on Thu, May 20 2010
    • Easton, Maryland - USA
    • Posts 406
    • Points 4,980
    Strange jump when I use transition:
    Hello,
    I am having a very annoying transition issue on an image.
    Pic1: arrow points to green line at the bottom.
    Pic2: arrow points to NO green line at the bottom.
    Between one frame, there is a slight vertical jump on the image. I can not figure it out. Rendered or not rendered it is an issue. It happens at the end of any type of quick transition (also happens on film dissolve).
    Any ideas?
    The image is 5105 x 2903. I import it as a jpeg with Resize image to fit format raster setting.
    The project is 1920 x 1080.
    Simon
    MC6 Intel Core i7 x980 3.33GHz 12GB RAM Nvidia Quadro FX 3800 3 HD's in RAID 0 (7200rpm) [view my complete system specs]
  • Sat, Feb 25 2012 3:09 AM In reply to
    Re: Strange jump when I use transition:
    I have seen this some times with titles.
    Rendering before exporting cures it here.
    Desktop PC
    3 Heads Digital Films
  • Sat, Feb 25 2012 3:22 AM In reply to
    • Simon Zimmer
    • Posts 406
    • Points 4,980
    Hi George,
    I tried rendering and it still happens. grrrrr! This is driving me nuts! I am sure it is something simple.
    In the meantime, I found a workaround by just using Avid FX-Transition effect and creating keyframes on the opacity. That works but takes much longer than a quick transiton.
    Simon
  • Sat, Feb 25 2012 7:31 PM In reply to
    • Simon Zimmer
    • Posts 406
    • Points 4,980
    I opened up an older project today and I am getting the same strange jump. :(
    I feel like I have tried every configuration when importing images and graphics.
    Can someone please try to download the image below:
    www.aguayuda.org/Uploads/Toilet-Test-Square.zip
    Import it into a 1080 - 29.97 project and then add a quick transition and see if it jumps? If it does not jump, what were the settings you used to import the image.
    I really need to figure this out.
    Any help would be appreciated.
    thanks,
    Simon
  • Sat, Feb 25 2012 7:39 PM In reply to
    • Simon Zimmer
    • Posts 406
    • Points 4,980
    Here is a quick 6 second video of the jump occuring at the beginning and the end.
    http://www.youtube.com/watch?v=6ZujWfBxd-4
    Any ideas?
    Simon
  • Thu, Mar 1 2012 7:49 PM In reply to
    • Simon Zimmer
    • Posts 406
    • Points 4,980
    Hello,
    I can't believe I am the only one with this issue regarding imported images and issues with quick transitions.
    The only way I have it working is by creating a dissolve with Avid FX. I wonder what the connection is between quick transitions and images. Should I report this as a bug? If so, where?
    Thanks!
    Simon
  • Thu, Mar 1 2012 9:19 PM In reply to
    Two things come to mind.
    a) check to make sure "boarder" is not checked in the effect controller. It is now defaulted to "on".
    b) in the "General" settings, make sure effect aperture is set to UTI601 and not DV25.
    Edit 1: HP Z400 Nitris DX, 2 Xeon W3540 @ 2.93Ghz, NVidia FX3800, 6GB Ram, MC 5.5.3.2 [Mothballed Edit 2: HP xw8200 Adrenaline, Dual Xeon 2.6Ghz, 4GB... [view my complete system specs]
  • Thu, Mar 1 2012 9:30 PM In reply to
    gspfilmworks:
    I have seen this setting again and don't understand it.
    Where is it?
    Desktop PC
  • Thu, Mar 1 2012 9:40 PM In reply to
    • Simon Zimmer
    • Posts 406
    • Points 4,980
    gspfilmworks:
    Thanks for responding. Unfortunately, I could not find either setting. Could you provide more detail or a screen shot?
    Simon
  • Thu, Mar 1 2012 9:50 PM In reply to
    The border is at the 3D Warp effect.
    But the other one I don't understand.
    Desktop PC
  • Thu, Mar 1 2012 10:13 PM In reply to
    Under the settings tab (next to the bins tab), select "General". A pop-up window will appear, check the setting.
  • Thu, Mar 1 2012 10:14 PM In reply to
    General gives only the timecode.
    Maybe it's your Nitris box.
    I am on software only.
    Desktop PC
  • Thu, Mar 1 2012 10:19 PM In reply to
    It's for NTSC based projects.
  • Thu, Mar 1 2012 10:26 PM In reply to
    • Simon Zimmer
    • Posts 406
    • Points 4,980
    I can't find the setting you are referring to either gspfilmworks.
    I did add the 3D Warp effect to an imported image. If I keep the plain border on with "metal", the quick transition works! :) between two images.
    If the border is "plain", it will not work. What does this mean? Hmm
    Simon
  • Thu, Mar 1 2012 10:53 PM In reply to
    • Simon Zimmer
    • Posts 406
    • Points 4,980
    I am getting closer to a good solution. :)
    I am getting the strange jump when I import two images at 1:1MXF and put a quick transition between them.
    However, if I import the two images at say 220X MXF and put a quick transiton, there is NO JUMP!
    So I guess for now, any images, I will bring in at 220x MXF. Strange that 1:1 is giving me issues. Can anyone test out on their system if they are having problems too when they import images at 1:1?
    Thanks!
    Simon
