Latest post Sun, Nov 4 2012 2:52 AM by TVJohn. 30 replies.
Page 2 of 3 (31 items) < Previous 1 2 3 Next >
  • Thu, Mar 1 2012 10:26 PM In reply to
    Re: Best way to import Powerpoint?
    Most of my work includes ppt. I'm fortunate that I have the original slides re-created in Full HD (1920x1080) sizes. I simply do a "save as" to png format (which seems to come out cleaner than jpg and tif) and normal import into avid. However, I almost never do a zoom-in or move around within the slide.
    $.02
    Edit 1: HP Z400 Nitris DX, 2 Xeon W3540 @ 2.93Ghz, NVidia FX3800, 6GB Ram, MC 5.5.3.2 [Mothballed Edit 2: HP xw8200 Adrenaline, Dual Xeon 2.6Ghz, 4GB... [view my complete system specs]
  • Fri, Mar 2 2012 3:23 AM In reply to
    • Posts 10,284
    • Points 219,185
    gspfilmworks:
    Most of my work includes ppt. I'm fortunate that I have the original slides re-created in Full HD (1920x1080) sizes. . . . . . . . . However, I almost never do a zoom-in or move around within the slide.
    $.02
    I would agree with you that at 1920x1080 original resolution, you should avoid doing any P&Z in MC.
    For any P&Z to be able to pan and zoom without noticeable resolution fuzziness etc. you must have an original image which is bigger than the 1920x1080. (How can you pan across a 1920 pixel image if it is in a 1920 wide project? - by zooming first? Well that will bring out  the pixels and softness)
    Anything that is at a lower resolution than 1920x1080 is not suitable material for panning and zooming.
    If I had some stills which were smaller than 1920 x 1080, I would probably try and rescale them in photoshop first.
    Regards,
    Douglas
  • Fri, Mar 2 2012 4:14 AM In reply to
    • Sylvain P
    • Montreal, Quebec, Canada
    • Posts 1,484
    • Points 17,545
    I didn't use Pan and zoom before and didn't read about it until now. A really nice effet.
    Very interesting to know. I will not have to use Avid FX for large files.
    We learn something new every day!
    Media Composer 2018.5 (Symphony Option), ASUS P8P67 Deluxe, Intel i7 2600k, 16G DDR3-1600, PNY NVIDIA Quadro 2000 (353.82), Windows 10 Pro. Boris Red 5... [view my complete system specs]
    Sylvain Primeau
    Self-employed worker - Les productions Primeau Medias
    primeaumedias.com
    Radio-Canada/CBC news editor
    cbc.ca / ici.radio-canada.ca
  • Fri, Mar 2 2012 6:02 AM In reply to
    • Posts 10,284
    • Points 219,185
    Sylvain P:
    first of all, thank you all for reminding me of the BCC  P&Z filter.
    I have a tutorial on it in the 100+ basic tutorials, but the MC version and BCC versions are a little dated ) even though the functions are the same as today)
    So I was considering doing an updated version.
    However, these past months I have been digging deeper into AvidFX.
    The BCC P&Z filter is available from within AvidFX too.
    If you are at home with Avid's own AVX plug-in interface, then you will feel more comfortable using the filter from the BCC AVX version.
    If, like me, you have trouble getting your head round nesting and stepping into and out of things, and you want to broaden your horizons, you will probably find that learning AvidFX is going to give you a greater scope and control over Text and Effects than Avid's native tools do. But this is so dependent on each individual using MC, that I'll not harp on about it - other than to say that Avid FX has definitely been underestimated by most of us who are using MC.
    I do not like to make promises that I cannot keep within a reasonable time, but there will be a tutorial on using the BCC P&Z filter in one of my upcoming AvidFX Tutorial packets. Probably in my "Avid FX - Part 2" collection - hopefully due by the end of this month . . . . . . .
    Regards,
    Douglas
  • Fri, Mar 2 2012 10:38 AM In reply to
    • Brian Suttie
    • Edinburgh, Scotland
    • Posts 917
    • Points 11,570
    I've always found that any of the rasterised file options in Powerpoint - jpg, png, tif etc. result in text that isn't anti-aliased and hence very jaggy.
    My fix is to use wmf which keeps the text as vector format which you can then rasterise at a much higher resolution and resize down to give you nice smooth text.
    The attached sample shows on the top line text exported from Powerpoint as a tif file, and the bottom line is the same text rasterised at 400% then scaled down in Photoshop.
    You actually don't even need to export a file - just right click on the slide in Photoshop and select copy - this will copy it to the windows clipboard in wmf format - you can then paste in your graphics programme.
    regards
    Brian
    "We'll fix it in post"
    "This is post"
    "aaaahh"
  • Fri, Mar 2 2012 4:06 PM In reply to
    Very good explanation Brian thanks.
    But you have to have it on a file if you need to link it as from P&Z.
    Desktop PC
    3 Heads Digital Films
  • Fri, Mar 2 2012 7:57 PM In reply to
    • Brian Suttie
    • Posts 917
    • Points 11,570
    George Angeludis:
    George, yes but you only need one file, not two.
    i.e. you don't need to export a wmf and then convert to a jpg.
    You copy and paste and save as jpg.
    And you could make that jpg quite large if you want to pan and zoom.
    regards
    Brian
    "This is post"
    "aaaahh"
  • Tue, Mar 13 2012 10:51 PM In reply to
    • MAC HOLLAND
    • Joined on Fri, Jun 9 2006
    • Holland Landing Ontario
    • Posts 740
    • Points 9,305
    I do this a lot.
    1. Export PPT to PNG
    2. Use phtoshop to res-up to format size (I often increase pixles to 200 /  option "best fopr enlargement"
    3. Import to marqie and position or animate
    PPT expots at 72 DPI I find PNG 200 DPI good enough for HD when put through marquee
    AVID MEDIA COMPOSER 4.08 Asus P6T6 WS Revolution Intel X58 LGA1366 Motherboard Intel Core i7 920 Processor BX80601920 - 2.66GHz, LGA 1366, 4.8GT/s QPI... [view my complete system specs]
    MAC HOLLAND
    YORK REGION - ONTARIO
  • Sat, Nov 3 2012 4:08 PM In reply to
    • Lunapark
    • Joined on Sun, Sep 16 2012
    • Posts 6
    • Points 105
    Please please help me..
    I've tried hundreds of ways to import Powerpoint into Avid and everytime Im not satisfied.
    Ive tried saving tiff, png etc. from Powepoint and importing.
    Ive tried installing a plugin for Powerpoint which gives me options of how to save.
    Ive tried screenshot and inserting in Photoshop.
    The Project in Avid is 1280x720.
    The funny thing is that if I have a perfect picture in 1280x720 shown on my computer
    it still looks like crap when its imported.
    Please help how do I import theese slides ?
  • Sat, Nov 3 2012 5:18 PM In reply to
    • GT
    • South Africa
    • Posts 389
    • Points 4,255
    I save the individual Powerpoint slides as PNG, and then open them in Photoshop, and resize them to the required video format, save them as PSD files and import those into Avid. I get great results this way.
    MC Ver 8.7, Intel Core I5, NVidia Quadro FX 570, 16Gb Ram, 250 Gb system drive, 2 Tb Render/Media drive, Windows 7 64bit Pro, QT 7.6.6 [view my complete system specs]
  • Sat, Nov 3 2012 5:39 PM In reply to
    • Lunapark
    • Posts 6
    • Points 105
    And I swear that Im doing it the same way..
    What can I be doing wrong ?
  • Sat, Nov 3 2012 7:37 PM In reply to
    • MAC HOLLAND
    • Posts 740
    • Points 9,305
    Export to PNG -
    Uprez / overrez in photoshop ---to about 300pxl and set for best enlarge option
    Export to PNG  (its a big file now)
    Import to Marquee and pan-zoom in that.
    Another otpion is to zoom to selection in PPT, then screen snap selection and past in photshop
    MAC HOLLAND
  • Sat, Nov 3 2012 9:43 PM In reply to
    • TVJohn
    • Bayonne NJ
    • Posts 4,327
    • Points 53,490
    Naturally after the fact, however if I'm aware that I am going to receive Powerpoint, I create the proper template via the optimum page size selected and email the client the format template.
    Using MC 8.4. Avid FX6.4, Vegas Pro 15/ DVD Architect 6pro, DVDit6.4proHD, CCE Basic, TmpGe Express4, TmpGe Authoring Works 4, DVDLab-Studio. Sony EX-1R, Canon XH-A1, GL2, GL1, Canon EOS 60D
  • Sun, Nov 4 2012 12:13 AM In reply to
    Not to be left out lol Stagetools blows avid's PZ out of the water...Stick out tongue
    MC 7.0 Symphony 7.0 Win 7 64bit 1 x XW 8600 quad 16gig ram 480gig SSD FX 5400 4 1tb 32 mb cache drives Pro tools 10 Avid fx Avid 3d Matrox... [view my complete system specs]
  • Sun, Nov 4 2012 2:51 AM In reply to
    • TVJohn
    • Bayonne NJ
    • Posts 4,327
    • Points 53,490
    You can use these PP settings: If the client has a 1920x1080 monitor, than that option would be available and preferable...
