Latest post Mon, Jun 10 2013 1:20 AM by jwrl. 26 replies.
Page 2 of 2 (27 items) < Previous 1 2
  • Sun, Jun 17 2012 6:01 AM In reply to
    • mjolnarn
    • Joined on Wed, Feb 8 2006
    • Sweden
    • Posts 13,346
    • Points 159,365
    Re: Export error: Exception: ADD_MEDIA_DATA_REF_FAILED
    And if you uncheck Same as Source in the render settings does that work better .
    Tomas
  • Sun, Jun 17 2012 7:36 PM In reply to
    • Sylvain P
    • Montreal, Quebec, Canada
    • Posts 1,489
    • Points 17,600
    mjolnarn:
    Sorry, I made an error, you should read Same as Source unchecked.
    The last test was without Same as Source.
    Media Composer 2018.12.2 (Symphony Option), ASUS P8P67 Deluxe, Intel i7 2600k, 16G DDR3-1600, PNY NVIDIA Quadro 2000 (353.82), Windows 10 Pro. Boris Red... [view my complete system specs]
    Sylvain Primeau
    Self-employed worker - Les productions Primeau Medias
    primeaumedias.com
    Radio-Canada/CBC news editor
    cbc.ca / ici.radio-canada.ca
  • Tue, Jun 19 2012 10:04 AM In reply to
    Hi!
    I am getting the same error when trying to export QT REF from DNXHD sequence. Different timelines on the same projet: some can be exported, some not... same settings. Always fixed after a video mixdoxn.
    Please, someone from Avid on this?
    Media Composer 2019.12 on PC Windows 10 Pro (64-bit), Ryzen™ Threadripper™ 3960X, + 64 Go RAM, Nvidia Quadro P5000 (16Go), DeckLink 4K Extreme 12G, RME... [view my complete system specs]
  • Fri, Jun 22 2012 4:19 AM In reply to
    • Sylvain P
    • Posts 1,489
    • Points 17,600
    Avid must fix this issue.
    I never saw this issue with pre v6 versions.
    Sylvain Primeau
    primeaumedias.com
  • Sat, Jun 30 2012 10:09 PM In reply to
    • amirox
    • Joined on Tue, Jan 19 2010
    • Germany
    • Posts 76
    • Points 800
    same error here: made videomixdown in dxnhd 185x 1080i25 tried to do qtref and got this error... - no audiotracks...
    HP XW8600 Z800 MacPro Nehalem MC v4.x Symphony Nitris DX v4 DS v10.3 Unity 5.1.3, Interplay 1.6.2 [view my complete system specs]
    thx
    Michael Radeck
    Productspecialist, Postsupervisor, Post-Trainer, AVID ACSR MC, DS,
    Interplay, Unity, ISIS, Airspeed...
    Iridas Speedgrade, Adobe Studio, Apple FCS
    Trainer www.handsonhd.de
  • Wed, Dec 26 2012 10:30 AM In reply to
    Hi, I found another issue and solution, as I had the same error message after mixdown.
    Fact is my original sequence came with special characters (with accents) in its name. So media files generated by the mixdown had also special characters. I changed name, then mixdown and export are OK.
    MC8.3.1 - HPZ800 - 2xX5650 CPUs - BMD Decklink Studio 4K - W7 Professional 64 (French "Edition Integrale") - 24 Gb RAM - NVIDIA Quadro 4000 ... [view my complete system specs]
  • Thu, Dec 27 2012 2:35 PM In reply to
    • Sylvain P
    • Posts 1,489
    • Points 17,600
    Pascal Bourgeois:
    Also, in addition to special characteurs, I noticed that file lenght may cause issue.
    When doing a video mixdown, I now avoid long sequence names. I don't have an exact number, but it may be 27 characters the maximum.
    Sylvain Primeau
    primeaumedias.com
  • Thu, Dec 27 2012 4:28 PM In reply to
    • Chris DK
    • Joined on Sat, May 27 2006
    • Denmark
    • Posts 9
    • Points 125
    We regularly see this error when we export QT refs, but we found out that every time it had something to do with special characters in the related mxf filenames.
    For example: If a sequence contains a master clip named with a special character, the related mxf filename also contains the same character, which leads to the "add media data ref failed-error"
    It will not help renaming the master clip, because the mxf file keeps the old name.
    If a sequence is named with a special character, a rendered effect will get the same character in the mxf.
    Advice 1: Do not use special characters at all.
    Advice 2: If you have already used them. Rename your sequence. Make a video and audio mixdown.
    It DID work with special characters before version MC6(NC10), and I would appreciate if Avid would make it possible again.
  • Sun, Dec 30 2012 4:04 PM In reply to
    • Sylvain P
    • Posts 1,489
    • Points 17,600
    Chris DK:
    Exactly, you have to rename your sequence before making a video mixdown. Not when exporting a Quick Time Ref.
    Sylvain Primeau
    primeaumedias.com
  • Sat, Jun 8 2013 5:20 PM In reply to
    • Blaska
    • Joined on Tue, Aug 28 2012
    • Posts 1
    • Points 5
    Thank you! My problem was caused because I had a special character in my sequence too. I fixed it and my qtref exports like a charm.
  • Sun, Jun 9 2013 10:35 AM In reply to
    • Joachim Claus
    • Seeheim-Jugenheim, Germany
    • Posts 945
    • Points 12,070
    Pascal Bourgeois:
    I had the same problem with German "Umlaute" in sequence names. When I rebuilt the sequence (name did not include any special character), QT-Reference export ran smoothly.
    Joachim
    Joachim Claus
  • Mon, Jun 10 2013 1:20 AM In reply to
    • jwrl
    • Melbourne, Australia
    • Posts 8,407
    • Points 97,250
    While this doesn't affect me in an English-speaking country, surely it's well past time that this problem was addressed!  That a user can't use their native language when naming clips in this day and age seems absurd.
    If someone affected by this would like to post a feature request you might be surprised at the feedback.
