Latest post Wed, Mar 14 2012 7:49 PM by Saylur. 11 replies.
Page 1 of 1 (12 items)
  • Wed, Mar 14 2012 8:48 AM
    • Brian Coe
    • Paris France
    • Posts 20
    • Points 270
    How to export 1920 x 1080 sequence to Avid DVD
    Hi
    We have sequences in 1920 x 1080i (Canon MXF AMA source) and wish to export to Avid DVD for making Blu rays disks.
    Up until now we have been using the "HDV Elementary streams" export to make .mpg and .mpa files.
    However we have just realised that these files are created as 1440 X 1080i files so we have been loosing part of the better quality of the full HD 1920 x 1080 camera source.
    There doesn't seem to be an obvious way of exporting the full res files to .mpg
    What is the correct workflow, how should we be doing it.
    We have Mc 6.0.1 on dual Zeon 6 core machine with all the latest software (upgraded yesterday.)
    Many thanks for help.
    Avid MC 6.0.1 + Avid DVD + Sorensen Dell twin ZEON 6 core 3.4 gHZ 8Go RAM FX 4000 Second workstation Dell Twin Zeon 2 core 4 Go [view my complete system specs]
  • Wed, Mar 14 2012 12:07 PM In reply to
    Re: How to export 1920 x 1080 sequence to Avid DVD
    Brian Coe:
    Export as a QT reference file and import that into AvidDVD and let AvidDVD do the Blu-ray transcoding.   It's a solid workflow that I use all the time for Blu-ray.
    MC 2018.4 with Symphony, Matrox MX02 Mini Max, Win 7 Pro, HP Z800 2x6-Core 3.2Ghz Xeon, 48GB ram, Quadro K4200, SanDisk Extreme 240GB SSD as system drive... [view my complete system specs]
  • Wed, Mar 14 2012 1:24 PM In reply to
    • Brian Coe
    • Paris France
    • Posts 20
    • Points 270
    I have tried that but am getting an error message
    "QuickTime refrence exports cannot be performed on clips linked via AMA or on sequences containing media linked via AMA"
  • Wed, Mar 14 2012 1:43 PM In reply to
    Brian Coe:
    Brian,
    Duplicate your sequence and then do a video and audio mixdown.    Cut in the video mixdown (the audio mixdown should already be there) and then delete all the tracks except the mixdown tracks.  Make sure you do this to the duplicated sequence, NOT your original sequence).   Then you should be able to export the QT reference of the mixdown tracks from the duplicated sequence.
  • Wed, Mar 14 2012 2:24 PM In reply to
    HDV is a horrible mastering format.
    As you've spotted it's subsampled at 1440 but it's also fixed long GOP so you end up with soft and low datarate sections of GOP.
    You need to work with frame based codecs after aquisition. File sizes will grow but that's better than quality dropping...
  • Wed, Mar 14 2012 2:57 PM In reply to
    • Brian Coe
    • Paris France
    • Posts 20
    • Points 270
    Thanks for help.
    I did the audio and video mixdown and Avid DVD gives an error message on import saying that it cannot find the right codec?
    When i did the video mixdown, I used the XDCAM 50 MXF codec? perhaps this was not the right one to use?
  • Wed, Mar 14 2012 3:00 PM In reply to
    • Brian Coe
    • Paris France
    • Posts 20
    • Points 270
    Bearing in mind that our source is Canon XF305 mxf, what do you suggest that we use as a codec. And at what point to we convert, after linking to AMA or do we have to do an import and conversion rather than a link ?
  • Wed, Mar 14 2012 3:04 PM In reply to
    Use Avid DNxHD.
  • Wed, Mar 14 2012 5:10 PM In reply to
    • Brian Coe
    • Paris France
    • Posts 20
    • Points 270
    Hello
    I tried this by doing a video mixdown to DNxHD 120; but when I try to export a QT ref , the audio exports then when it tried to export the video I get the following error message
    Exception: ADD_MEDIA_DATA_REF_FAILED
    Any help would be appreciated
  • Wed, Mar 14 2012 6:23 PM In reply to
    • Saylur
    • Laguna Woods CA
    • Posts 485
    • Points 6,115
    In your QT export settings do you have Use Avid Codecs checked?
    MC-6.0.5,MB Asus Z87 Expert 1150 ATX,Intel Core i7 4770 3.4 Ghz CPU,32GB Kingston DDR3 Mem.,Samsung 840 250GB SSD,Win 7 Pro SP 1, QT 7.7.3,PNY Quadro K2000... [view my complete system specs]
    Regards
    Mike
  • Wed, Mar 14 2012 6:33 PM In reply to
    • Brian Coe
    • Paris France
    • Posts 20
    • Points 270
    I have tried both with and without.
  • Wed, Mar 14 2012 7:49 PM In reply to
    • Saylur
    • Laguna Woods CA
    • Posts 485
    • Points 6,115
    I have a Canon XF 100. My workflow is AMA in & consolidate to my media drive,edit, then do a video mixdown using DNxHD 145,turn off all tracks except VM & audio markin & out points & do a QT Ref & import in to Avid DVD. Do you have the latest version of Avid DVD?
    Regards
    Mike
