Latest post Mon, Apr 23 2012 1:15 PM by RUD ONE. 6 replies.
Page 1 of 1 (7 items)
  • Mon, Apr 23 2012 12:13 PM
    Avid Marquee Tool, type on effect, Help
    I've used the type on effect in Avid Marquee, it's great. but...
    When it finishes typing the text on, it disapears. Avid will not let me put a freeze frame on, or extend the clip out, so i obviously need to make the effect last for say, 3/4 of the clip length so that it 'types it on' and then leaves the words up for around 10 seconds...
    Does anyone know how to do this?
    Ta!
    Brad
  • Mon, Apr 23 2012 12:18 PM In reply to
    • Lars M
    • Joined on Fri, Mar 5 2010
    • Larvik, Norway
    • Posts 199
    • Points 2,400
    Re: Avid Marquee Tool, type on effect, Help
    Brad,
    Are you keyframing the animation?
    Regards,
    Lars
    MC 2018.11 | W10 PRO 64bit | MB ASUS X99 | INTEL i7-5930K OC@4,3mHz | 64GB Corsair Dominator 2400Mhz DDR4 RAM |Samsung 912 PRO M.2 512TB boot drive| ASUS... [view my complete system specs]
  • Mon, Apr 23 2012 12:21 PM In reply to
    • Vilem
    • Joined on Sat, Apr 10 2010
    • Prague
    • Posts 1,408
    • Points 15,505
    Hello,
    I once tried to type on the Marque, but not in the script version was a mistake. I started using Avid FX as described here. I stayed at it. I suppose that in the Marque can set keyframes on the timeline.
    V.
    AVID MC2019.6 - dongle, HP Z620 - 2 x Intel Xeon E5-2620, Quadro P2000 - driver 411.95, RAM 48GB - DDR3, BM Intensity Pro 4k - 10.11, W10 - 64bit Professional... [view my complete system specs]
  • Mon, Apr 23 2012 12:43 PM In reply to
    Hi, no im not at the moment,
    In the scripts on the marquee tool, there was just the 'type on' effect, so i selected it. it works beautifully, but dissapears when its done...
    thanks!
  • Mon, Apr 23 2012 1:11 PM In reply to
    • Lars M
    • Larvik, Norway
    • Posts 199
    • Points 2,400
    Select the "Animate" button.
    Then you can set keyframes to you likings on the Marquee's timeline...
    Lars
  • Mon, Apr 23 2012 1:13 PM In reply to
    • Lars M
    • Larvik, Norway
    • Posts 199
    • Points 2,400
    ... and here is a link to a tutorial ....
    http://www.youtube.com/watch?v=MdVb9q5ECXw
    Good luck!
    Lars
  • Mon, Apr 23 2012 1:15 PM In reply to
    • RUD ONE
    • Joined on Thu, Dec 14 2006
    • Milwaukee, WI
    • Posts 216
    • Points 2,570
    Before you run the type on script, mark an in and an out on the MArquee Timeline for the duration that you want the effect to take.
    MCA v4.0.5,HP XW8200, Adrenaline [view my complete system specs]
    Rud One - Milwaukee, WI
