Latest post Wed, May 9 2012 9:46 PM by Keith Nicolini. 4 replies.
  • Wed, May 9 2012 7:02 PM
    • Keith Nicolini
    • Joined on Wed, May 9 2012
    • Northern Indiana
    • Posts 6
    • Points 70
    New system locks up on exports - h.264, mpeg2
    We have a brand new Media Composer 6 on HP Z800:
    Media Composer ver 6.0.1
    Quicktime Pro ver 7.7.1
    Sorenson Squeeze ver 8.1.0.170
    When I try to export H.264 in Avid and QT Pro or MPEG-2 in Sorenson applications lock up.
    Problem is that I have a TV show going to network and I need to provide it in one of the following formats:
    - 1920x1080  59.94i  Quicktime ProRes
    - 1920x1080  59.94i  Quicktime H.264
    - 1920x1080  59.94i  Windows Media
    - 1920x1080  59.94i  MPEG-2 PGM Stream
    When I try to export H.264 in Avid and QT Pro or MPEG-2 in Sorenson applications lock up...  Anybody have any ideas??
    ASUS X99-M WS Intel XEON E5-2680 14-Core 64GB ECC 2400MHz RAM 12GB NVIDIA Titan X Windows 10 Pro [view my complete system specs]
  • Wed, May 9 2012 8:01 PM In reply to
    • Baklap
    • Hilversum - The Netherlands
    • Posts 6,944
    • Points 82,400
    Re: New system locks up on exports - h.264, mpeg2
    Did you tripple check if the version QT you are running is the one Avid recomends with your specific version Media Composer?
    35+ MC's - 224TB Isis - 2.2 PB Spectra T950 - Interplay - 2 Media Central's - 3 TM's - 2 STP's - 500 TB Isilon - 2 Vantage - MOG SPeedrail... [view my complete system specs]
    Twitter Account
    "If you do what you did you will get what you got!"
    My Keys
  • Wed, May 9 2012 8:15 PM In reply to
    • Keith Nicolini
    • Northern Indiana
    • Posts 6
    • Points 70
    I'm running QT Pro Ver 7.7.1
    Is that a safe version? Also Sorenson Squeeze doesn't work either?
  • Wed, May 9 2012 9:26 PM In reply to
    • Baklap
    • Posts 6,944
    • Points 82,400
    That my friend you can check over here
    http://cdn.pinnaclesys.com/supportfiles/attach/mediacomposer_versionmatrix.pdf
    What you also can try (and i do not know if this stll works) is changing a setting in QT. Go to QT player preferences and check if the video is set to either safe mode or Direct X Change that to safe mode (if set to direct X) and try some more.
    (screenshot https://plus.google.com/photos/113490377156637680097/albums/5740647545504884881/5740647554619577346 )
    Twitter Account
    My Keys
  • Wed, May 9 2012 9:46 PM In reply to
    • Keith Nicolini
    • Northern Indiana
    • Posts 6
    • Points 70
    Thanks but no success going in safe mode in QT, and versions all check out right...   this is weird..
