Latest post Mon, Mar 11 2013 10:36 AM by filmfriseur. 3 replies.
  • Fri, May 18 2012 8:02 AM
    • Michel
    • Joined on Tue, May 31 2011
    • Stockholm
    • Posts 5
    • Points 65
    Could not activate audio suite plug-in
    I've recently installed the 5.5.3 patch. The thing is, when I try to load my audio-suite or RTAS effects I get the following message:
    "Could not activate plug-in. Possible causes, 1. An attempt to authorize a plug-in while activating failed. 2. Attempted to run an authorized plug-in."
    Ok, the problem is obvious, avid can't authorize the audio-suite plug-in. Why is that? And how can I authorize it properly?
    Best regards, Michel
    Avid Media Composer 8.1.0, iMac (Retina 5K, 27'), 3,5 GHz Intel Core i5,32 GB 1600 MHz DDR3 AMD Radeon R9 M290X 2048 MB Adobe CC [view my complete system specs]
    Filed under: ,
  • Sun, Mar 10 2013 11:51 PM In reply to
    • filmfriseur
    • Joined on Fri, Feb 8 2013
    • Berlin, Germany
    • Posts 63
    • Points 560
    Re: Could not activate audio suite plug-in
    I kind of ran into the problem only with 6.5. Did you found a solution?
    regards
    amc 2018.4 - symphony . 3.46 dual 6core mac pro (early2009, upgraded to westmere 5.1, OSX 10.12.6). 64 gb . msi gtx 970 . 2x 27" monitor . 1x 24"... [view my complete system specs]
  • Mon, Mar 11 2013 9:42 AM In reply to
    • Michel
    • Stockholm
    • Posts 5
    • Points 65
    I uninstalled AMC, and re-installed it, it works fine now
  • Mon, Mar 11 2013 10:36 AM In reply to
    • filmfriseur
    • Berlin, Germany
    • Posts 63
    • Points 560
    Thanks for your reply. Unfortunately this did not work in my case. :-( Did a uninstall and wipe out everything (I hope) that was left and re-installed AMC. Also deleting MC State, Settings and Attributes did not fix it. Full discription of my problem is here: http://community.avid.com/forums/p/117634/678687.aspx#678687
