Latest post Tue, Jun 19 2012 1:38 AM by diegovillalba. 15 replies.
  • Sat, May 26 2012 2:12 AM
    PROBLEMAS CON EL AUDIO DEL FORMATO .MPG EN LA LINEA DE TIEMPO
    Como sabran existen diferente tipos de mpg,s mpg y mpg-4 cuando edito formato .mpg resulta que aparece el video en el timeline pero el audio no se escucha ni aparece las ondas en la linea de tiempo.
    hasta ahora este es el unico problema que me da avid studio gracias...
    Filed under: ,
  • Sat, May 26 2012 4:11 AM In reply to
    • Sylvain P
    • Montreal, Quebec, Canada
    • Posts 1,483
    • Points 17,530
    Re: PROBLEMAS CON EL AUDIO DEL FORMATO .MPG EN LA LINEA DE TIEMPO
    No estás en el buen foro.
    Aquí es el foro por Media Composer y Symphony. El foro por Avid Studio está allí http://forums.pinnaclesys.com/forums/287/ShowForum.aspx
    Media Composer 2018.5 (Symphony Option), ASUS P8P67 Deluxe, Intel i7 2600k, 16G DDR3-1600, PNY NVIDIA Quadro 2000 (353.82), Windows 10 Pro. Boris Red 5... [view my complete system specs]
    Sylvain Primeau
    Self-employed worker - Les productions Primeau Medias
    primeaumedias.com
    Radio-Canada/CBC news editor
    cbc.ca / ici.radio-canada.ca
  • Thu, May 31 2012 2:59 PM In reply to
    No estás en el foro adecuado, este es el foro de Media Composer y Symphony.
    Pincha aqui para el  foro de Avid Studio: http://forums.pinnaclesys.com/forums/287/ShowForum.aspx.
    Man, the Babel-type translators are almost useless, especially for more than one word.
    When English is translated literally to Spanish (and viceversa), the results are mostly funny gibberish :-D
    But,  thanks anyway to Sylvain's
    Lenovo E32 ThinkStation Intel Xeon E3-1245,16GB RAM, Nvidia Quadro 600 (1 GB), Windows 10 Pro x64 (up to date) USB 3.0, Lite-On SSD 256GB System Drive... [view my complete system specs]
    Remembering my friend Larry Rubin
  • Mon, Jun 4 2012 9:40 PM In reply to
    As you know there are different types of MPG and MPG-4, when I edit format. Mpg video is displayed on the timeline but the audio is not heard or waves appear in the timeline. so far this is the only problem that I'm avid studio thanks ...
  • Tue, Jun 5 2012 5:35 PM In reply to
    • Sylvain P
    • Posts 1,483
    • Points 17,530
    Carlos Sardá:
    Were you talking about my answer? I didn't use any translator.
    Español es mi tercera idioma. And English my second!
    Sylvain Primeau
    primeaumedias.com
  • Thu, Jun 7 2012 11:20 AM In reply to
    La ayuda desinteresada de Sylvain, es lo que debería importar mas. Wink
    * Avid Media Composer 8.6.5 * MacBook Pro 8,3
  • Sat, Jun 9 2012 5:46 PM In reply to
    diegovillalba:
    .- And I already said thanks to him.
  • Sat, Jun 9 2012 5:49 PM In reply to
    .- And I guess FRENCH is your first, isn't it?.
    Well, I'm pretty sure your french is better than mineWink
    Well, I'm sorry but you sounded like you were translating literally and from English. but also you have a big merit, specially having in mind the place you're from.
    And Spanish and French are a lot harder to learn than English.
    Spanish is structured a lot more like french than any Anglo - Saxon language, both are from Latin roots.
    If you're to improve your Spanish, better think in French.
    I.E  FOR (in English) means both POR and PARA in Spanish.
    The thing is POR and PARA are different words and, in Spanish, they have totally different usage.
    POR doesn't fit in your sentence.
    That's the problem with English, one word has lots of meanings, and, most of the times, totally different meanings.
    When I was learning English, the first thing I had to do was quit thinking and translating to and from Spanish.
    On the other hand, French's POUR means PARA, which, while not of common use in that very case, it's totally correct and fits in the sentence.
  • Tue, Jun 12 2012 3:36 AM In reply to
    • Sylvain P
    • Posts 1,483
    • Points 17,530
    Yes, you guessed right, French is my native laguage.
    Lo siento, tenìa un poco de difficuldad en el passado con por y para. I just should have made a little bit of revision before writing.
    Now, I have remembered that in French, a basic rule is.
    Por = Par (cause)
    Para = Pour (but)
    I didn't translated litterally from English, I was thinking in French, but I mixed por y para.
    Thanks, I needed a little bit of revision. ¡Tengo que practicar más mi español!
    Sylvain Primeau
    primeaumedias.com
  • Thu, Jun 14 2012 11:57 AM In reply to
    Carlos, yo si hablo español.
    Y supongo Sylvain is a her, not a him.
    Au revoire! Wink
  • Fri, Jun 15 2012 3:12 AM In reply to
    • Sylvain P
    • Posts 1,483
    • Points 17,530
    No, estoy un ombre. I'm a man.
    In French, there is Sylvain (masculino) and Sylvie (femenino).
    Au revoir!
    Sylvain Primeau
    primeaumedias.com
  • Fri, Jun 15 2012 3:08 PM In reply to
    .- The thing with Spanish is that it isn't as permissive and flexible as English. So is French.
    But effort and intention it's what counts, and please, DO take my "corrections" as constructive, not as criticism and certainly NOT as mocking.
    Well
    Back to Español.
    Dieguito, en Frances Sylvain es un nombre bien masculino, nombre de Guerrero.
  • Fri, Jun 15 2012 11:47 PM In reply to
    • Sylvain P
    • Posts 1,483
    • Points 17,530
    De acuerdo Carlos. ¡Gracias para la corrección!
    Sylvain Primeau
    primeaumedias.com
  • Sun, Jun 17 2012 1:40 PM In reply to
    Sylvain P:
    Excusez moi Sylvain.
    Au revoir!
  • Sun, Jun 17 2012 7:33 PM In reply to
    • Sylvain P
    • Posts 1,483
    • Points 17,530
    Il n'y a pas de problème!
    No hay problema
    Sylvain Primeau
    primeaumedias.com
