Latest post Thu, May 16 2013 8:33 PM by AndrewAction. 11 replies.
Page 1 of 1 (12 items)
  • Mon, May 28 2012 9:19 PM
    • Ivo
    • Joined on Fri, Oct 21 2005
    • Germany
    • Posts 518
    • Points 6,990
    How can I transcode DPX to DNxHD 444?
    Avid Media Composer 2018.9 MacBook Pro [view my complete system specs]
  • Tue, May 29 2012 6:43 AM In reply to
    Re: How can I transcode DPX to DNxHD 444?
  • Tue, May 29 2012 6:53 AM In reply to
    Not sure that does DNxHD 444, Pat. Are you sure about that?
  • Tue, May 29 2012 8:44 AM In reply to
    No not sure but I thought Metafuse had been updated for V6?
    If I get a chance I'll have a play.
  • Tue, May 29 2012 8:57 AM In reply to
    Pat Horridge:
    DL center is still on 2.5 of March 2011. That version does not allow me to choose any other color space than YCrCb709, and only 4:2:2 versions of DNxHD, in 8-bit or 10-bit.
  • Tue, May 29 2012 12:27 PM In reply to
    Job ter Burg:
    Pat Horridge:
    Thansk for that. Shame Avid aren't upto date with it?
    Do we know if there are plans for Metafuse or will it become like media log (the tool that if it had been enabled for AMA would have been a killer Avid application)?
  • Sat, Apr 20 2013 1:00 AM In reply to
    • prberg
    • Los Angeles, CA
    • Posts 256
    • Points 3,525
    Just wanted to folllow up on this thread.  Any development on MetaFuze?
    I want to convert DPX into 4:4:4 media.  I'm currently on Symphony 5.5 so I was hoping to convert to Uncompressed 10bit RGB (444).  Doesn't seem like Metafuze will output 4:4:4 media.
    Any idea if it will ever been updated with 4:4:4 support?  What are our options at this point?  Is Avid DS the only option for working with DPX files (and keeping the 4:4:4 color space)?
    thanks,
    Peter
    Asus P9X79 Pro - Intel i7 16GB Ram_Win7 Pro Nvidia GTX580 ATA100 7200rpm drives (1 for system, 1 for video) 2 SATA 7200rpm drives in a internal RAID... [view my complete system specs]
  • Sat, Apr 20 2013 1:10 AM In reply to
    Resolve 9 handles DPX's and has a render to DNxHD 1080P 444
  • Sat, Apr 20 2013 1:30 AM In reply to
    • prberg
    • Los Angeles, CA
    • Posts 256
    • Points 3,525
    Thanks for the email.  I do know there are many other applications for converting clips (I think FCP does it, nuke does it, After Effects and Smoke too I think).  Guess I was wondering if Avid offered any solutions to this problem?  Looked like v7 awnsered a few of the problems people have been having and I hoped they might have updated Metafuze with RGB output.
  • Sat, Apr 20 2013 2:13 AM In reply to
    MetaFuze does not seem to have changed for a long time,,, so will it change?. I do not THINK MC7 will handle DPX. Resolve lite (free) has the same 444 export.
    FWIW this would give you a fairly easy workflow by keeping the  DPX's on Resolve CPU (Resolve opens from a media folder like AMA). In Resolve render to DNxHD 36 plus an AAF export to MC for offline.
    After the cut is finalised AAF back to Resolve and link to the original DPX's for grading or or just render back to 444 media.
  • Thu, May 16 2013 8:23 PM In reply to
    Another way of skinning this cat if you are on a Mac is to use Aja DPX to QT convertor:
    If you load the Aja Codecs you can make an  AJA QT reference of the DPX's and then use AMA to injest, trancoding to 444 media in MC.
    It seems to retain 10 bits, and comparing some F3 material through the AJA route with the same footage that had been laid off to tape dual link and digitised from SR looks identical.
    Symphony 7.06 OS 10.9.5 QT 7.6.3 Mac Pro 2x2.66 6-core 32GB Ram Aja Kona 3. MC 7.0.6 OS 10.9.5 Mac Pro 5.1 2x2.97 6-core 14GB ram Aja I/O express, Apple... [view my complete system specs]
  • Thu, May 16 2013 8:33 PM In reply to
    David Yardley:
    Soon MC7's fully managed AMA media MAY improve this from a good option to a great one
