Latest post Mon, Aug 4 2014 12:02 PM by Snowball. 84 replies.
Page 2 of 6 (85 items) < Previous 1 2 3 4 5 Next > ... Last »
  • Thu, Sep 13 2012 11:00 PM In reply to
    Re: Audio keyframe (changing volume of a group of keyframe)
    Patrick Loiseau:
    This is a step back.
    I agree.
    Patrick Loiseau:
    Where can I report that I NEED that « Mark I/O and select tracks » technique working again ?
    I'll get back to you on that, but I will make sure the source of that information sees this thread. I have a feeling that once this becomes common knowledge, we're going to see more users reporting in. On the one hand, the lasso technique is more flexible, but it cannot account for all keyframe situations, when many are close together. It's great to have lassoing and lateral movement in keyframe regions, but KB marking to define a region is a precise, quick technique AND IT SHOULD NOT BE ABANDONED.
    {EDIT} Cross posted with Jay's response, which supports my points.
  • Fri, Sep 14 2012 12:28 AM In reply to
    I haven't upgraded to 6.5 yet but this functionality change would be a very unapreciated hindrance.
    Please Avid, stop changing things that have worked for years.
    MC 8.8.2 OSX 10.12.3 Quicktime 7.6.6 Nitris DX [view my complete system specs]
  • Fri, Sep 14 2012 12:34 AM In reply to
    • Evan Schiff
    • Los Angeles
    • Posts 120
    • Points 1,460
    On the whole I'm really happy with the changes to audio, and that's the main reason we decided to try out 6.5 even in the middle of a show. For me the new functionality is well worth it, even with some functionality that is hopefully only temporarily lost.
    MC 7.0.0, OSX 10.8.4 Retina Macbook Pro Blackmagic Mini Monitor [view my complete system specs]
  • Fri, Sep 14 2012 7:00 AM In reply to
    • Jojo Likar
    • Joined on Sat, Nov 26 2011
    • Austria
    • Posts 60
    • Points 715
    I've just installed the 6.5 trial version on my home system. First of all I have to say that it's great to have the new audio keyframes cababilities. But loosing the feature to mark a region an adjust keyframes makes audio mixing a lot slower for me. One thing that I like about Media Composer is the possibilitie to be able to use the keyboard for most of the editing functions.
    As much as I'd like to update to 6.5 for improvements like Audio Punch-In for 3rd party hardware, this keyframe thing is a big reason for me to stay with version 6.
    Hopefully this will come back.
    Media Composer 2018.2 | Win 7 64-bit | BMD Decklink Mini Monitor 4K | Intel i7-6800K | X99-EWS | 64 GB RAM | GTX 970 | Artist Control & Transport ... [view my complete system specs]
  • Fri, Sep 14 2012 8:07 AM In reply to
    Evan Schiff:
    Yeah, that's how it worked up until 6.5. So like if you had music on A13 and A14 and had those tracks active, one hit of Add Keyframe would put a keyframe on both tracks, and then dragging up or down, say, the A14 keyframe would also adjust the A13 keyframe. But it only worked vertically, not horizontally
    yes, that is pretty annoying... keyrames of  tracks that belong to the same Master Clip should behave in the same way!
    Social Media Manager at Avid
    Editor-in-Chief avidblogs.com
    Got a great story to tell for #TimelineTuesday?
    Want to share a Media Composer Tutorial on #TutorialThursday?
    Contact me!
    Twitter: @editorbelga
    Facebook: fb.com/editorbelga
  • Fri, Sep 14 2012 11:46 AM In reply to
    Here's my response sent to the Avid individual who contacted me:
    First of all, thanks for the reply, and we all really do appreciate the enhancements to keyframing behavior, especially horizontal movement of keyframe regions. However, you need to re-evaluate your decision to drop marking in and out to define a range of keyframes. You and the beta team have not considered several specific scenarios where marking is the best and quickest way to create a region. There should be no reason why both lassoing to define a region and marking to define a region can't peacefully coexist. Once again, PLEASE DON'T remove features users have depended on for years in their workflow. Add new ones to them, but don't remove the existing ones, especially ones that have been there almost since the very beginning of Avid software. Speed is of the essence to a lot of us, and this decision markedly slows us down. I would request that you, the beta testers, and the design team both read and continue to follow these threads from the Forum on this subject:
    http://community.avid.com/forums/t/112675.aspx
    http://community.avid.com/forums/t/112743.aspx
    Thank you very much.
    Regards,
    Larry
  • Fri, Sep 14 2012 12:10 PM In reply to
    Thank you Larry, for sending this request to your AVID contact.
    I placed a call to the support line to report this change. Hopefully, they will bring that fonction back. Sit and wait...
    Nitris DX and AVID Artis IO, MC 2018.4 (symphony option), OS 10.11.6, MacPro, 2 X 2.66 GHz 6-Core Intel Xeon, RAM 32 GB 1066 MHz DDR 3. [view my complete system specs]
  • Mon, Sep 17 2012 5:45 PM In reply to
    This additional problem with audio keyframing in 6.5 also needs to be restored. When working with mono tracks, adding a single audio keyframe in the same location on two or more audio tracks, you used to be able to grab one of those keyframes, and with the other tracks active, adjust all keyframes volume at that position simultaneously.
    Well, in 6.5, you can only adjust one keyframe at a time per track, instead of multiple identical keyframes simultaneously. This is a serious deficiency and I sincerely hope NOT A DESIGNED CHANGE. I still have yet to get a response from my contact at Avid regarding this. I am attempting to get a reply.
  • Mon, Sep 17 2012 5:52 PM In reply to
    • Evan Schiff
    • Los Angeles
    • Posts 120
    • Points 1,460
    Yeah, that was what I was trying to point out the other day :)
  • Mon, Sep 17 2012 6:56 PM In reply to
    I have escalated both of these keyframing issues to engineering.
  • Wed, Sep 19 2012 5:13 PM In reply to
    As for me, I've downgraded back to AVID MC 6.0.3. The keyframe issues are just too annoing to work with and REALLY slowing the process.
    Will wait to see if AVID fix this. Otherwise, I'll stick to version 6 as long as I can.
  • Thu, Sep 20 2012 3:01 PM In reply to
    • Snowball
    • Joined on Wed, Sep 20 2006
    • York, UK
    • Posts 103
    • Points 1,270
    HI Folks,
    Really pleased to find this thread.  I've just installed the 6.5 trial on a brand new top of the line iMac i7.  I'm having the above issues and then some.
    I too am missing the in/out option to adjust multiple keyframes.  I could live with the lasso for now if it work at all.  Doesn't matter if I drag left-right or right-left, as son as I click on a keyframe in that selection only the keyframe I click on is selected.  The only way I can select multiples is to click on them individually.  EXTREMELY frustrating and now good for a complicated mix at all.  This must be fixed as a priority.
    But I have further issues here, maybe related?
    Having imported several files at 720p DNxHD90x (a mixture of pro res files and h.264's) I drop them on the timeline and two seperate audio tracks are created automatically.  I'm assuming MC is treating the audio as stereo split over two tracks for the left and right channels.  However, adjusting the volume on track two using a single keyframe reduces the overall levels on both tracks which is weird.
    Furthermore the mute and solo buttons have no effect at all.  Mute both tracks - audio still comes through.  Mute one track - audio still comes through both channels with no drop in levels (as looking at the sudio tool).
    Anyone else experienced this or have any ideas?
    Thanks.
    iMac 3.4GH i7 27" OSX 10.8.2 16GB 1333MHz DDR3 Radeon HD 6970M 2048MB MC7.0 and me old.. XP Pro SP2 MC v3.5 QT v7.4.5.67 HP xw8200; 2gb RAM; Intel... [view my complete system specs]
  • Thu, Sep 20 2012 3:10 PM In reply to
    • Snowball
    • York, UK
    • Posts 103
    • Points 1,270
    Just as an addition to that - if I open Audio Mixer and select both tracks as mono, use the a keyframe to drop the levels on Track 2 all the way down, the Audio mixer shows no levels coming from track 2 (as you'd expect) but there is no adjustment to the actual volume and the Audio Tool shows levels coming through both channels with no drop in volume.
  • Thu, Sep 20 2012 3:15 PM In reply to
    Snowball:
    Try clicking on one audio keyframe that represents the desired in point you want for your region FIRST, THEN draw the lasso from left to right. Make sure you start the lasso in the background area above and behind the highest track in your timeline if the smart tool is enabled to avoid going into segment edit mode while lassoing.
    I am having ongoing discussions with design and engineering on these keyframing issues. If and when a development occurs, I will inform the community.
  • Thu, Sep 20 2012 3:22 PM In reply to
    Hi Snowball,
    Snowball:
    Try holding the « Option » key when you do the lassoing, from Left to Right. Then, you should see that all volume keyframes in the lasso area are selected and will stay that way until you double-clic anywhere else in the sequence.
    About the other audio bugs, I didn't notice that when I tried the MC6.5. Don't have any clue to give you.
    Sorry !
