Latest post Sun, Sep 16 2012 7:25 PM by Lash LaRue. 7 replies.
  • Sat, Sep 15 2012 5:40 AM
    First P2 experience (please be gentle).
    My friend, who operates a Panasonic Hvx200, has decided to throw me some editing work. She dragged and dropped the contents of her P2 card to a USB thumb-drive and passed it to me. That's where I am now.
    I'm on MC 4.0.5 and unable to link to AMA (thumb-drive) or import P2.
    Is there more to copying a P2, do we need P2 Viewer or something?
    I'm guessing I could connect the camera via USB and import the card that way, but we were hoping to have a more convenient workflow?
    What could complicate matters more is she's Mac based while I have the good sense to work with a PC. jk
    Thanks for any help!
    Lash
    I have purchased MC6 and have a new PC about ready to roll, but I thought I'd complete this on a well working system giving me some time to get v6 squared away.
    Antec P183 Antec CP-850 850W Intel Core i7 Processor i7-920 2.66GHz 8MB Cooler Master Hyper 212 Plus Asus P6T Deluxe v2 OCZ Platinum DDR3-1600 12GB... [view my complete system specs]
  • Sat, Sep 15 2012 6:28 AM In reply to
    • Lars M
    • Joined on Fri, Mar 5 2010
    • Larvik, Norway
    • Posts 199
    • Points 2,400
    Re: First P2 experience (please be gentle).
    Hi Lash,
    And you have of course installed the P2 AMA plug in ?
    Regards,
    Lars
    MC 2018.11 | W10 PRO 64bit | MB ASUS X99 | INTEL i7-5930K OC@4,3mHz | 64GB Corsair Dominator 2400Mhz DDR4 RAM |Samsung 912 PRO M.2 512TB boot drive| ASUS... [view my complete system specs]
  • Sat, Sep 15 2012 8:39 AM In reply to
    • Jayanta
    • Joined on Fri, Jul 6 2007
    • India
    • Posts 1,504
    • Points 16,255
    For P2 You will need the following Software
    Download the P2 AMA Pligin
    Download the MXF AMA Plugin
    Download P2 Driver
    Download P2 Viewer and AVC Intra Decoder for P2 Viewer
    and I think you will be good to go.
    Also read the Manual/FAQ/Read Me etc,  throughly.
    All Sorts of System as I am a freelance Editor [view my complete system specs]
    "Out of mud the lovely Lotus Blooms, Out of Strife something higher vies "
  • Sat, Sep 15 2012 9:15 AM In reply to
    • dor
    • Israel
    • Posts 596
    • Points 7,585
    Hi
    I don't think there are AMA plugins to install in MC 4.x
    You can try to COPY all the MXF files from your USB drive to your local \Avid MediaFiles\MXF\1 folder
    Then get the clips from the media tool
    MC 2018.4 + MXO2 mini. CPU I7 2600K + 32GB RAM. Nvidia GTX970 driver 388.71. QT.7.7.9 [view my complete system specs]
  • Sat, Sep 15 2012 1:07 PM In reply to
    • Tom Pearson
    • Joined on Thu, Mar 1 2007
    • Los Angeles CA / Minneapolis MN
    • Posts 2,163
    • Points 23,215
    Hi I shoot and edit P2 all the time and it's easy as pie.  if you are on 4.0 just use import p2 from your file menu.  navagate to one folder above the contents folder and select clips to bins.  then  go back and to your file menu and select import media and your all done as for newer versions you need a ama p2 plug in as mentioned earler but there is no need for the P2 viewer as it is a stand alone pgm to log and import p2 files  and the p2 driver is a driver to load p2 cards into systems and you are not doing that as you have the files on a flash drive
    Mac Pro 3.5 gig 6 core 64 gig ram D700 radons with ssd os drive with a 20 tb raid, Artist Mix and Artist color Artist control [view my complete system specs]
    Tom Pearson
  • Sat, Sep 15 2012 1:30 PM In reply to
    • Lars M
    • Larvik, Norway
    • Posts 199
    • Points 2,400
    dor:
    Hi
    Are you sure about that?
    This link says "P2 AMA for MC 3.5 and later"...
    http://avid.force.com/pkb/articles/en_US/Download/en394531
    But I may be wrong Smile
  • Sat, Sep 15 2012 10:24 PM In reply to
    • wil
    • Quebec
    • Posts 60
    • Points 740
    Tom's right, if you have the content of the P2 card on a drive there's no need for drivers. I still have a bunch of MC 2.8 and they work just the same, Import P2, Clips to Bin and then Media. Just make sure you copy the whole content of the card in a folder and select that folder in the import process.
    MC703 on Precision T3500, 6 cores Xeon W3670 3.2Ghz, 12GB ECC, Quadro 4000, Win7 Pro 64 on WD Caviar Blue WD2500AAKX-753CA1 250GB 7200RPM, data on Hitachi... [view my complete system specs]
  • Sun, Sep 16 2012 7:25 PM In reply to
    I couldn't understand why the "Import P2" option was not in my file menu. I finally found AMA must be turned off in Settings and then MC needs to be restarted! Got my Import P2 option now and it works!
    Thanks all!  :^>
