Latest post Tue, Sep 25 2012 1:44 AM by Chepal. 1 replies.
Page 1 of 1 (2 items)
  • Mon, Sep 24 2012 10:35 PM
    • janusz
    • Paris
    • Posts 394
    • Points 4,535
    2:1 SD QT AMA consolidate - repeatable FATAL_ERROR
    I've some footage encoded with the 2:1i Avid SD codec, encapsulated in a Quicktime file.  If I do a "Link to AMA file" all is well.  But if I then consolidate and load the consolidated clip "FATAL_ERROR" appears and the following message in the console:
    JPEG:Codec Decode Error -1
    Decode frame failed.
    CChannel: error: CMError_Codec, function Execute, line 284, internal codec error string: JPEG Error: SOI not Found
    DecodeFrame error: JPEG Error: SOI not Found
    PlayerHostThread::CheckForExceptions: Exception: FATAL_ERROR
    Exception caught in APlayer::Play - Exception: FATAL_ERROR
    This is completely reproducable.  I've had the problem on 5.5.3.3, also on 5.5.3 on 6 different machines (teaching at a film school at the moment and all of my students had the problem!)
    Steps to reproduce:
    i) Using Quicktime 7, export some footage with the Avid Meridian Compressed codec, RGB levels, 2:1i PAL, Millions of colours (no + to avoid having Alpha which blocks the AMA import as native and forces sample mode)
    ii) Link to AMA volume in a 50i project (same behaviour seen on other project types).  Load the footage-> all is well.
    iii) Consolidate.
    iv) Load the consolidated footage to the source monitor and go to the start and end frames.
    -> Fatal error (or consistency check error then fatal error) appears and the source monitor stays black
    The only workaround I've found is to use the 1:1x codec which takes a lot of space; I need a high quality SD codec that takes less space than 1:1.  In V6 I could probably use Prores HQ, but I want to maintain media compatibilty with V5 and earlier, and maintain the transparency of a native codec that I can consolidate.
    Any ideas, workarounds, or otherwise can anyone else reproduce this so that it can be escalated as a bug ?  I have seen no mention in the readme files of subsequent releases that it has been fixed anywhere.
    Janusz
    MC 2018.12 / OS 10.12.6 + others elsewhere [view my complete system specs]
    Filed under: ,
  • Tue, Sep 25 2012 1:44 AM In reply to
    • Chepal
    • germany
    • Posts 537
    • Points 6,285
    Re: 2:1 SD QT AMA consolidate - repeatable FATAL_ERROR
    hi janusz,
    why not a straight import - it will be fast_import into a sd_25i_project.
    maybe not, if your colorspace is rgb?
    i have some meridien_2:1_clips on my scsi_raid, but can't check these at the moment - it's too late.
    che
    mac_mc_8, fibre, sata, scsi [view my complete system specs]
    peace from germany
