Latest post Sun, Oct 21 2012 11:51 PM by jworms. 2 replies.
  • Fri, Oct 19 2012 12:09 PM
    • jworms
    • Joined on Wed, Aug 17 2011
    • Posts 156
    • Points 2,350
    After AMA re-link, export crashes computer.
    Hi All
    At work we have an HP XW8400 as our Avid machine.  I've just relinked a project via AMA to it's original media (1920x1080 25p H264 5D MkII material) but when attempting to do the export out to a H264 with Vimeo recommended compression (1280x720, 5000kbps etc) it crashes.
    The computer has 4GB RAM, which I know isn't a huge amount for what we're using it for, and it's Quad Core.  Is it freezing because exporting from AMA is a lot more intensive that from DNxHD material?  The film is 20mins in length by the way.
    It would be good to know whether this is a speed issue or if there's something else at play, so in future we can plan to do the final AMA export elsewhere.
    Thanks a lot.
    Jack
    Avid Media Composer 6.5, HP Z400, 1 Intel® Xeon® Quad-Core Processor W3550, Integrated SATA 3.0 Gb/s with RAID 0, 1, 10, 5 support, NVIDIA Quadro 2000... [view my complete system specs]
    Filed under: , ,
  • Sat, Oct 20 2012 12:20 AM In reply to
    • Diamornte
    • Joined on Tue, Jun 19 2012
    • Posts 14
    • Points 200
    Re: After AMA re-link, export crashes computer.
    Did you try mixing down the video first, then exporting?
  • Sun, Oct 21 2012 11:51 PM In reply to
    • jworms
    • Posts 156
    • Points 2,350
    Hi
    I'm not entirely sure what you mean, can you be more specific?
    Thanks a lot
    Jack
