Latest post Sat, Nov 10 2012 9:24 PM by mjolnarn. 5 replies.
Page 1 of 1 (6 items)
  • Sat, Nov 10 2012 2:33 AM
    • Sameer
    • Joined on Wed, Sep 19 2012
    • Posts 14
    • Points 200
    Export crashing on MC 6
    I am trying to export a 15 minute file and the project keeps crashing.  The file is a Link to AMA ProRes 422 file and I want to export 1:1 to ProRes 422.  I am exporting custom and selecting the ProRes 422 from the drop down box.  If I try a one minute section it does work however.
    Is there a way to export without having to convert to a quick time reference and using sorenson squeeze as it seems like I have to purcahse the ProRes Codec (unless I am wrong about this).
    Can anyone help?
    Sameer
    MacBook Pro 2.53 GHz Intel Core 2 Duo 4GB Ram 1067 MHz DDR3 OS X 10.8.1 [view my complete system specs]
  • Sat, Nov 10 2012 7:04 AM In reply to
    • mjolnarn
    • Joined on Wed, Feb 8 2006
    • Sweden
    • Posts 13,346
    • Points 159,335
    Re: Export crashing on MC 6
    Do a try if the file fast imports instead of ama linking it, then export Same as Source .
    Tomas
  • Sat, Nov 10 2012 8:35 AM In reply to
    • Sameer
    • Posts 14
    • Points 200
    Hi Mjoinan,
    Do you mean an import as a ProRes 422 Proxy (Mxf) or something different to that, as my deliverable is a ProRes 422 file?
    Sameer
  • Sat, Nov 10 2012 9:56 AM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 159,335
    Just select the same import codec as the origin file, it should fast import with the correct settings if the codec is supported.
    If it fast imports it´s just rewrapped to Avid mxf without being changed in any way, export SAS will keep the same codec and file structure.
    Tomas
  • Sat, Nov 10 2012 6:11 PM In reply to
    • Sameer
    • Posts 14
    • Points 200
    Thankyou.  That worked well.
  • Sat, Nov 10 2012 9:24 PM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 159,335
    You´re welcome, happy to have been able to assist
    Tomas
