Latest post Sat, Nov 17 2012 8:06 PM by Chepal. 2 replies.
  • Sat, Nov 17 2012 7:56 PM
    How to Batch Import only the files that are used in a sequence
    Hi all,
    I have a final sequence of a project currently linked to Avid DNX 175x files, and I would like to batch Import these files with the Apple Pro Res HQ codec, since i like better how this codec renders . The project has a big amount of files, and it would be very time consuming to batch Import all of them, especially when I am not using most of them in this sequence. The sequence is 12 minutes long, so go file by file is very time consuming as well. Does anyone know a way to tell Avid  to BAtch Import only the files that are being used? I have tried to decompose the sequence but it gives me an error. And I don't think I can decompose a sequence that has Magic Bullet Plugins in eevery single clip. Does anyone have a suggestion about how to approach this process in a simple not too time consuming way?
    I'm working on MC6, btw.
    thanks very much,
    Filed under: ,
  • Sat, Nov 17 2012 7:59 PM In reply to
    Re: How to Batch Import only the files that are used in a sequence
    You don't necessarily need to decompose. Duplicate your sequence, put the duplicate in it's bin, right click and choose batch import specifying the new target resolution. Batch import is also in the bins menu.
  • Sat, Nov 17 2012 8:06 PM In reply to
    • Chepal
    • germany
    • Posts 537
    • Points 6,285
    or transcode your duplicated_sequence to prores_hq, if your source are the dnxhd_175x.
    che
    mac_mc_8, fibre, sata, scsi [view my complete system specs]
    peace from germany
