Latest post Fri, Nov 30 2012 12:53 AM by Sameer. 7 replies.
  • Thu, Nov 29 2012 2:34 PM
    • Sameer
    • Joined on Wed, Sep 19 2012
    • Posts 14
    • Points 200
    Link to AMA H264 issue
    I have a project linked to AMA with Canon 5D H264 footage and the footage stutters and stalls on playback.  I don't think its a hardware issue as larger ProRes 422 footage linked to AMA plays back fine.  Can anyone help with how to solve this issue? I am using MC 6.5.
    Sameer
    MacBook Pro 2.53 GHz Intel Core 2 Duo 4GB Ram 1067 MHz DDR3 OS X 10.8.1 [view my complete system specs]
    Filed under: , ,
  • Thu, Nov 29 2012 3:07 PM In reply to
    Re: Link to AMA H264 issue
    It's not the datarate size thats the issue here it's the unpacking of the H.264 content.
    H.264 is very CPU intensive to decode ready for playback. You need a really powwerful system to get good playback. In fact disk speed is less important as the file sizes and datarates are quite low.
    That's why so many people transcode to do the actual edit. Either to frame based online quality media or to lower quality for an offline and then relink back at the end for the conform.
  • Thu, Nov 29 2012 3:09 PM In reply to
    Hi Sameer,
    Sameer:
    Do you see little blue, yellow, or red lines in the TC track?  They'd give a clue about why the footage is stuttering.
    Blue = hard drives aren't fast enough, or the connection to them isn't fast enough; no frames dropped yet
    Yellow = processor isn't fast enough; no frames dropped yet
    Red = frames are being dropped
    Also, h264 codec files are tough to play back via AMA.  This link has more info:
    http://avid.force.com/pkb/articles/en_US/Compatibility/en365919
    ciao,
    Carl
    Media Composer 2018.12.5 w/Symphony/SS/PF options, HP Envy 17t-j100 Quad Edition laptop, Windows 10 Pro, Intel Core i7 2.4GHz, 16 GB RAM, nVidia GeForce... [view my complete system specs]
  • Thu, Nov 29 2012 5:17 PM In reply to
    • Sameer
    • Posts 14
    • Points 200
    Thank you Pat and Camoscato for your help.  I have a few questions:
    What would you recommend to be the best transcode to use form H264 if I wanted to keep the quality the same but keep the transcoding as quick as possible?
    Would it be faster to import at a lower quality and conform?
    How can I link to AMA and lay out the main part of it and then transcode it?
    Sameer
  • Thu, Nov 29 2012 5:26 PM In reply to
    At most of the places I work, they use whichever DNxHD codec fits their needs.  Without knowing more about your intended output, I'd say pick the highest DNxHD number that won't eat up all your drive space.
    Sameer:
    Probably not.  From everything I've seen AMA link & transcode is faster than importing.
    Sameer:
    You can either transcode all the footage prior to editing, or edit using AMA linked footage and then transcode the sequence.  When possible, I prefer the first choice so I get all my transcoding done before doing any editing.
    Hope that helps.
  • Thu, Nov 29 2012 5:46 PM In reply to
    • Sameer
    • Posts 14
    • Points 200
    I am laying out the edit at the moment on link to AMA.  What's the process to transcode it when it is ready?  Do I export it as a DnxHD file and re import it or is there an easier way?
  • Thu, Nov 29 2012 8:06 PM In reply to
    Sameer:
    Right-click on the sequence and select Consolidate/Transcode from the menu.  No need to export/import or any of that.
  • Fri, Nov 30 2012 12:53 AM In reply to
    • Sameer
    • Posts 14
    • Points 200
    Thanks, that worked well.
