Latest post Thu, Dec 6 2012 6:24 PM by hugo13584. 2 replies.
  • Thu, Dec 6 2012 5:42 PM
    • hugo13584
    • Joined on Thu, Dec 6 2012
    • Posts 5
    • Points 45
    Avid Media Composer 5.5 setting capture resolution
    hello, i'd like to know if there is a way to set the capture resolution for all the projects i'll create.
    i'm having a problem with the setting of capture resolution, i set it as DV25 420 mxf but every time i create a new project resolution it's as dv25 411 mxf. but all other settings aren't changed.
    Any suggestions?
    thanks in advance.
  • Thu, Dec 6 2012 5:50 PM In reply to
    Re: Avid Media Composer 5.5 setting capture resolution
    Set you media creation as you want it.
    Then in the special menu open the site settings and drag your media creation settings into there.
    Every new project should then inherit those settings.
  • Thu, Dec 6 2012 6:24 PM In reply to
    • hugo13584
    • Posts 5
    • Points 45
    Pat you have given me a RIGHT AND QUICK ANSWER.
    THANK YOU VERY MUCH!
