Latest post Sun, Jan 20 2013 7:06 AM by Job ter Burg. 4 replies.
  • Thu, Dec 6 2012 8:46 PM
    • delarita
    • Joined on Thu, Dec 6 2012
    • Posts 2
    • Points 40
    How to transcode DPX 10B 444 from Gemini/C500 into proxy with Lut
    Hello
    Every things are in the title...
    exept that i try to do it with MetaFuze and something is wrong with my way to do it.
    I can actually open DPX from the Gemini.
    I can transcode file in Mxf format and send an ALE file into MediaComp.
    But when i try to relink the mxf, Avid tell me that "i can't import the file into a bin".
    Any helps are welcome.
    Julien Daniel
  • Thu, Dec 6 2012 9:14 PM In reply to
    Re: How to transcode DPX 10B 444 from Gemini/C500 into proxy with Lut
    I use Resolve. (Resolve light is free)
    Open the Gemini DPX and put them on a Resolve timeline, add your LUT and render to DNxHD 36 clips (you can send your renders directly into an Avid MediaFiles\MXF\"number" folder) Export an AAF of the Resolve timeline. In Avid import the AAF and edit.
    Renders here including LUT almost real time on an older MacPro
    An AAF export of your timeline when imported back into Resolve can be linked to the original DPX files
  • Fri, Dec 7 2012 9:09 AM In reply to
    • delarita
    • Posts 2
    • Points 40
    THanks you very much,
    I will try this asap. And report result.
    i Dl "CanonLog10ToRec709_ver1.0.csv" from Canon USA WebSite.
    Julien Daniel
  • Sun, Jan 20 2013 12:32 AM In reply to
    • aqlucky
    • Joined on Sun, Jan 20 2013
    • Posts 4
    • Points 5
    Hi, I think it is becase mxf files can't be directly import into Avid. Why do you try a MXF Converter to help you?
  • Sun, Jan 20 2013 7:06 AM In reply to
    Afte creating the files in MetaFuze, you should not (and cannot) import the resulting MXF files, but rather add them to your Avid MediaFiles folder.
