Latest post Mon, Dec 31 2012 10:36 PM by Job ter Burg. 2 replies.
  • Mon, Dec 31 2012 10:28 PM
    • BrettG
    • Joined on Sat, Feb 18 2012
    • Posts 38
    • Points 555
    Is a Nitris DX firmware update necessary when updating MC?
    Hi all,
    Just a quick question. I am updating Avid Media Composer and Symphony systems here to 6.5. Is a firmware update necessary on the Nitris DX box if I am updating from Media Composer / Symphony 5 to 6.5? My producer here came across some information that an Avid software update may fry the firmware in the Nitris DX box if the Nitris is not first updated. Is there any truth to this? Thanks!
  • Mon, Dec 31 2012 10:36 PM In reply to
    Re: Is a Nitris DX firmware update necessary when updating MC?
    When you launch MC or Symphony it will check for Avid hardware and if found check the firmware versions.
    If they are incorrect then it will ask you to allow it to update them (or down date if loading older versions of MC)
    If you decline MC will quit so to run with out updating you'd have to disable the hardware by leaving it off.
    So updating is required if you wnat MC or Symphony to work with it if it detects a firmware mismatch.
    The firmware has to be correct to operate correctly with that version of MC or Symphony.
    While it is true that there is a very small risk of firmware updates not working correctly and damaging the box (the term used is bricking it) it's a very rare occurance and updating is a normal procedure.
    If necessary (from 5 to 6.5 will likely require one), the software takes care of this. So you install the new version, which ends in a restart. Then you launch the app. During launch, it will check the firmware version, and it will ask you to update the firmware if the new version requires that.
    So just follow the instructions. Haven't ever fried my DX with firmware flashes.
