Latest post Thu, Jan 24 2013 3:41 PM by Marianna. 2 replies.
  • Thu, Jan 24 2013 12:16 PM
    Avid on an iMac
    Hello,
    I am originally an Avid editor, but had to move over to FCP on a iMac.  I would very much like to get back to Avid but on the iMac I already have.  I've looked at a few sites to see whether my mac can run Avid and the mac I have doesn't appear on the lists?!
    It is a 27inch iMac and has:
    3.1 ghz Intel Core i5
    Memory 8gb
    Graphics: AMD Radeon HD 6970M
    OS X 10.8.2
    I don't want to upgrade to Avid if it won't even run it!  My understanding is that I will only need the software, I don't need to digitse/playout etc.  I have an AJA TTAP to output my video to an external monitor.
    Any help would be greatly appreciated.  Thanks
  • Thu, Jan 24 2013 3:35 PM In reply to
    Re: Avid on an iMac
    Check against the qualified/supported systems.  You seem to have done so, and if you say it's not on the lists, your system is technically not qualified.  This doesn't necessarily mean it won't work, but it does mean that Avid either has not tested that configuration, or has tested it, but decided not to qualify it.  Many people run unqualified setups and get along just fine, but there are no guarantees.
    That said, why not install the trial and take it for a spin?  You get plenty of time to try things out and see how everything works, without paying a penny.  If it works to your satisfaction, then go ahead and make the purchase.
  • Thu, Jan 24 2013 3:41 PM In reply to
    • Posts 10,202
    • Points 218,050
    Re: Avid on an iMac
    Hi
    You basically have what it takes to run MC.
    For example, the iMac 21.5" display with 3.6 ATI GHz i5 Dual core with Radeon 5.03 HT HD 5670 is qualified and then the iMac 20" display 2.66 GHz Core 2 Duo is approved - your right in the middle.
    I have this iMac and I am running MC 6.5 just fine.
    marianna
