Latest post Fri, Apr 12 2013 3:27 PM by Mitch009. 1 replies.
Page 1 of 1 (2 items)
  • Fri, Mar 1 2013 4:47 PM
    • Marc
    • Joined on Thu, Aug 12 2010
    • Montreal
    • Posts 5
    • Points 65
    Sync problem after modify 23.976 sequence to 59i
    I got a sequence in 23.976 edit with 5 video layer. The sequence contain mix frame rate 23.976 (90%) and 59i(10%).
    The duration of the sequence is around 50 minutes.
    I modify the sequence, set format to 59i and open the sequence in 59i project
    After looking the sequence I realize some clip on V3 and V4 are offsync 1 frame.
    The bug is on and off one the same layer.
    Each time I modify the sequence I got the same off sync.
    Did someone else experience this kind of problème.
    Thanks for any help
    Using Avid version 6.0.3 and Interplay 2.5 on ISIS
    MAC 10.7.4
    Model Name: Mac Pro Model Identifier: MacPro4,1 Processor Name: Quad-Core Intel Xeon Processor Speed: 2.66 GHz Number Of Processors... [view my complete system specs]
    Filed under: , , , ,
  • Fri, Apr 12 2013 3:27 PM In reply to
    • Mitch009
    • Joined on Fri, Apr 12 2013
    • Posts 1
    • Points 5
    Re: Sync problem after modify 23.976 sequence to 59i
    Hey Marc, I am experiencing the same problem. Have you discovered any solutions to this? or an alternative way?
