Latest post Fri, Mar 22 2013 8:18 PM by ninok. 3 replies.
  • Thu, Mar 21 2013 9:12 PM
    • ninok
    • Joined on Wed, May 23 2012
    • Posts 15
    • Points 195
    MC 6.5 Project format differ from the record format, import options?
    I have a video material from the EOS 500D Canon camera that was recorded in HD format (1920x1080) but with 20p / sek. I am cutting with AVID 6.5 version and cannot find an option to create the project with these settings. I have choosen the project format with 25p. But when I import, the video looks horrible. Is there any possibility to eather:
    - create a projekt with 20p and 1920x1080 in AVID or
    - to transform my raw material to 24p or 25p format?
    by the way: wich codec (video resolution) should I shoose while importing this raw material (I assume, it was  recorded with H264 codec, unfortunately noone can figure it out): DV25p 411 MXF? Have someone any experience to importing this format without or at least with minimum quality losses?
    I will appreciate any help!
  • Thu, Mar 21 2013 10:50 PM In reply to
    • Vilem
    • Joined on Sat, Apr 10 2010
    • Prague
    • Posts 1,404
    • Points 15,465
    Re: MC 6.5 Project format differ from the record format, import options?
    ninok:
    MC does not allow projects in 20 fps. Only the possibility of using the console command to force reading AMA fps (but I can not remember now, I'll find it). Material will then play rapidly, but you can apply the Timewarp effect and try different settings.
    ninok:
    Try to use the MediaInfo - 99% find details codec.
    DV25p 411 is SD codec H264 for 90% HD codec. Use the HD project.
    V.
    AVID MC2018.12.1 - dongle, HP Z620 - 2 x Intel Xeon E5-2620, Quadro P2000 - driver 390.77, RAM 48GB - DDR3, BM Intensity Pro 4k - 10.11, W10 - 64bit Professional... [view my complete system specs]
  • Thu, Mar 21 2013 10:59 PM In reply to
    • Vilem
    • Prague
    • Posts 1,404
    • Points 15,465
  • Fri, Mar 22 2013 8:18 PM In reply to
    • ninok
    • Posts 15
    • Points 195
    I'm sorry, but I would really appreciate your help again.
    When importing the video file, It's weird, but I cannot reach the same color quality. In import settings I have tested both: computer RGB (0-255) and 709 (16-235), the last one is much more better than RGB but I still don't  have the same saturated picture as on the raw material. Is there any other import options I can't figure out?
    V., thank you in andvance!!!
    Vilem:
