Latest post Wed, Apr 10 2013 1:58 PM by Jakob_kpp. 2 replies.
  • Mon, Apr 8 2013 12:31 PM
    • hlitani
    • Joined on Wed, Jun 3 2009
    • UK
    • Posts 14
    • Points 160
    Direct out to deck on MC6.0
    I have just upgraded from MC 5.5 to MC6.0.1.
    On the version 5.5, I was able to patch one stereo track from the timeline, to either channels 1&2 or 3&4 on the deck. On version 6.0, I could not find a way to patch one stereo track to two channels on the deck. In my case I have a stereo mixdown of a programme on one stereo track and a stereo mixdown without music on another stereo track. I would like to patch the first one to channel 1&2 on the deck and the second one to channels 3&4 on the deck, but on the version 6.0 I could not find a way to do that.
    Does anybody knows of a way to do that?
    HP Z820 Workstation 64 bit Nitris DX MC 8.2.7 with Symphony On Windows 7 Professional [view my complete system specs]
  • Mon, Apr 8 2013 2:52 PM In reply to
    Re: Direct out to deck on MC6.0
    I'd check to make sure your hardware settings haven't changed. Audio Project Settings > Hardware. Make sure your IO is selected under "peripheral". Also, check your deck preferences and see if they match up for the deck you're using. These settings get changed all the time, depending on user, project, weather, mood, hunger, etc.
    HTH,
    --G
    Edit 1: HP Z400 Nitris DX, 2 Xeon W3540 @ 2.93Ghz, NVidia FX3800, 6GB Ram, MC 5.5.3.2 [Mothballed Edit 2: HP xw8200 Adrenaline, Dual Xeon 2.6Ghz, 4GB... [view my complete system specs]
  • Wed, Apr 10 2013 1:58 PM In reply to
    • Jakob_kpp
    • Joined on Mon, Aug 29 2011
    • Posts 5
    • Points 45
    Hi hlitani
    I had the Problem with MC 6.5.2.
    Delete the mono tracks of your sequence and you should be able to direct out as you used to in MC 5.5
    Hope that helps...
