Latest post Thu, Jun 13 2013 11:23 PM by Dom Q. Silverio. 6 replies.
Page 1 of 1 (7 items)
  • Thu, Jun 13 2013 5:09 AM
    Relink to Audio File with Different File Name
    I'm cutting on Avid MC 6.5 on a Mac, as is my collaborator in a different city.  We started off with exact mirror drives, but as we pass new bits of media back and forth, the exact file names are diverging.
    He sent me a bin with a sequence that includes an audio file of voiceover.
    I can open the sequence fine, but the audio file comes up as offline.  When I look in the Media Tool, I can see my MXF file of the audio right there.  I've tried Refresh Media Directories and Load Media Database.  I've even tried Consolidate/Transcode after AMA linking to the raw media file (on my desktop).  And, of course, the mysterious "Relink" command.
    Nothing works.  I presume this is because the audio file is named different things in our media directories, depending upon the order in which we brought it into our "1" Folder.
    How can I relink this file?  There must be a way!
  • Thu, Jun 13 2013 12:08 PM In reply to
    Re: Relink to Audio File with Different File Name
    How was the VoiceOver created and brought into the project on his end?
    Is it a file that was imported? (.wav, .mp3, .aif?) or was it recorded as scratch track and recorded straight into Avid?
  • Thu, Jun 13 2013 1:52 PM In reply to
    The audio file was created in QuickTime Pro.
    It's actually a .mov, the audio is AAC (Stereo, 48KHz).
    It was imported by being dragged into a bin.
  • Thu, Jun 13 2013 2:32 PM In reply to
    knollcrest:
    If you did a seperate import process from th eother editor, check the TC (start and end) of the media. You may not have the same default TC for imported items.
  • Thu, Jun 13 2013 2:56 PM In reply to
    Do you have the .mov file?
    if so, just Batch import to get it into your system.  If you imported separately then it likely will never link.
  • Thu, Jun 13 2013 9:59 PM In reply to
    Thank you for your reply!
    I did in fact import by dragging into the bin.  As did my collaborator.  We both have the same starting TC 01:00:00:00.
    I do also have the original .mov file.
    I've tried to delete the master clip & original media that I importing in that method, and then going back and Batch Importing, but this does not seem to work.
    Is there really no workaround for this?  Coming from, ahem, a FCP background, it seems very strange to me that there would not be a way to do this.
    And/or, what's the best workflow in the future?
  • Thu, Jun 13 2013 11:23 PM In reply to
    1. Put sequence in an empty bin
    2. Fast Menu -> set bin display -> show reference clips
    3. Select the offline clip in question
    4. Right click and batch import
    5. Point to the same MOV file
    6. Disable "show reference clips" when done.
