Latest post Mon, Jun 17 2013 2:24 PM by juako. 6 replies.
Page 1 of 1 (7 items)
  • Mon, Jun 17 2013 12:06 PM
    • juako
    • Joined on Fri, Sep 15 2006
    • Posts 59
    • Points 740
    Fast Import Avid 1:1x
    Hola.
    En After Effects trabajo con una composición PAL D1/DV Widescreen.
    Exporto con los siguientes settings:
    QT movie / Avid 1:1x / ITU-R 601/709 / SD PALp
    Al intentar importar el archivo QT resultante en el proyecto de Avid (25p Pal) me aparece la ventana "Import Resolution Conflict".
    Resolution on this file: 1:1
    Resolution in Media Creation settings: 1:1
    Chequeo los settings de importación y si no me equivoco todo parece estar correcto:
    Image Sized for current format
    601 SD or 709 HD
    Alpha channel ignore
    Video Resolution 1:1
    Por qué no me importa el clip como "fast import"???
  • Mon, Jun 17 2013 12:23 PM In reply to
    • mjolnarn
    • Joined on Wed, Feb 8 2006
    • Sweden
    • Posts 13,346
    • Points 159,335
    Re: Fast Import Avid 1:1x
    My spanish is good enough to see that you have ran into an old Pal SD bug with the Avid 1 : 1 codec, I´m chasing this bug on each new version always reminding Avid when I see it, sometimes I have seen it fixed though.
    So, first and most important, what Avid version are you using.
    Tomas
  • Mon, Jun 17 2013 12:47 PM In reply to
    • juako
    • Posts 59
    • Points 740
    Thanks mjolnarn.
    I´m running Mc 5.5.3
    Thanks again!
  • Mon, Jun 17 2013 12:58 PM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 159,335
    You´re welcome juako, with 5,5 try with setting the advanced codec settings to SD Pal 609 Interlaced, will create an Progressive file  ( from memory ).
    It still maybe won´t fast import but you at least have it progressive initially.
    Tomas
  • Mon, Jun 17 2013 1:23 PM In reply to
    • juako
    • Posts 59
    • Points 740
    Awesome! Works like a charm!!
    So I don´t understand.... I rendered an interleaced QT and then import as progressive. In this way.... How Avid interpret this file to don´t eliminate one field??
    Fast import works!
    Thanks again!!
  • Mon, Jun 17 2013 2:04 PM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 159,335
    Smile
    I believe that the techs just have mixed the buttons somewhere down the road ..
    Tomas
  • Mon, Jun 17 2013 2:24 PM In reply to
    • juako
    • Posts 59
    • Points 740
    Perhaps.... ;)
    You calm my mornig headache!!
    Thanks a lot!!
