Latest post Wed, Mar 8 2017 2:14 PM by JD Marlow. 11 replies.
Page 1 of 1 (12 items)
  • Mon, Jul 15 2013 7:20 PM
    • Marty
    • Joined on Sat, Dec 3 2005
    • Berlin, Germany
    • Posts 923
    • Points 10,735
    more options with Spanned Markers
    One of the new features of MC 7 are Spannend Markers. Sounds really great but for me it's kind of useless at the moment.
    It only works on the timecode track, it doesn't transfer from source side to sequence side, FFWD and REW commands only stops on the beginning of a spanned marker, if you move sth. in the timeline, the spanned marker stays at the same position.
    It can be a really powerful tool (I used extended markers in FCP a lot) - but it definitly need some more work for Avid.
    This article describes it really good:
    http://provideocoalition.com/shullfish/story/mc-7-is-out-what-avid-wont-tell-you-about-spanned-markers1
    all different setups in various editing suites. my own: MC 2018.2, OSX 10.12.6, iMac (Retina 5K, 27-inch, 2017), 4,2 GHz Intel Core i7, 40GB RAM, Radeon... [view my complete system specs]
    www.film-editing.de
  • Mon, Jul 15 2013 7:23 PM In reply to
    Re: more options with Spanned Markers
    +1
  • Fri, Nov 15 2013 11:37 AM In reply to
    Another plus one. Goto End and Mark Spanned both essential.
    iMac i5 27", 24GB RAM, OS 10.13.6 with Symphony 2018.12, BlackMagic mini monitor. MacBook Pro, 16GB RAM with OS 10.13.6 with MC 2018.5 and BMD Ultrastudio... [view my complete system specs]
  • Fri, Nov 15 2013 1:21 PM In reply to
    +1. Now that we have spanned markers, I'd like them to appear at their full duration -- as an extra option in the Generator/TimeCode Burn-in FX. That tool is all about communicating important added info outside the edit suite.
    Seems like a perfect job for markers.
  • Wed, Nov 27 2013 9:29 PM In reply to
    • SchnittKontor_HH
    • Joined on Thu, Mar 30 2006
    • Europe - Germany - Hamburg
    • Posts 92
    • Points 1,050
    +1
    ... and overlapping spanned markers...
    MC /w. Sym 2018.12.2 | AVID Artist | DNxIO | HP Z820 GEN 2, 2x Xeon E5-2695W v2 12-Core 2.4 GHz, 64GB RAM, GPU: 2x RTX 2080 TI, HP Thunderbolt 2 | Win... [view my complete system specs]
  • Thu, Nov 28 2013 11:05 AM In reply to
    • sven2615
    • Joined on Wed, Apr 12 2006
    • Berlin
    • Posts 152
    • Points 2,030
    +1
    Avid Media Composer 7.0.3 | MacPro 3.5 GHz 6core 32GB RAM | AJA T-Tap |||| The Audio Mixer is too BIG since mc6!!! [view my complete system specs]
    www.svenbudelmann.com
    http://www.imdb.com/name/nm0118967/
  • Fri, Jan 24 2014 5:44 PM In reply to
    • JD Marlow
    • Joined on Tue, Jan 1 2013
    • NYC
    • Posts 75
    • Points 805
    Found this thread today and started playing around with Spanned Markers.  Agreed they are not really well implemented yet, almost to the point of not being usable.  If I can't snap to in and out of a spanned marker, it's hard to really use them.  Also having them show up on source and sequence side is really a must.  Additionally, when I toggle source/record monitor for my timeline I can't even see the spanned marker there in source mode.  It's got a ways to go, but they'll get there.  Excited for when that time comes.
    Mac Pro 10.9.5 (Dual Quad-Core 2.26 Ghz), 16 GB RAM, Media Composer 7.0.4.3 [view my complete system specs]
  • Sat, Jan 25 2014 10:17 AM In reply to
    In 7.0.3 you can use Alt/Option plus 'Mark Markers' to mark the beginning and end - much better. No overlapping markers though, as already pointed out.
  • Thu, Sep 18 2014 2:20 AM In reply to
    • Butcher
    • Joined on Mon, Apr 17 2006
    • Jacksonville, FL
    • Posts 1,442
    • Points 18,640
    In addition to overlapping markers, I'd like to be able to select a group of clips in a bin and execute a "make subclips from spanned markers" command.  I'd use it to pull individual takes from a long scene where the directors keeps resetting without shutting off the camera.
  • Thu, Sep 18 2014 10:37 AM In reply to
    I can see a major issue with allowing spanned markers to be on tracks other than the timecode track.
    How do you manage them if thety span clips? what happens if you drag the middel clip of a spanned section to the end of the time line? The span is now broken.
    The only way I could see it working is for the In point of a span and the outpoint of a span to be locked to the clip they are created on. If you break the span then MC would have to re-calculate the new span area.
    Tricky. But useful.
  • Wed, Mar 8 2017 9:23 AM In reply to
    • BenoitM
    • Brussels, Belgium
    • Posts 1,209
    • Points 14,480
    I should have asked this a long time ago, but I wonder if there's no practical way to move spanned markers ?
    Typical scenario: you extract a portion of the timeline (all tracks) and all subsequent spanned markers are no longer at the correct place. How to you easily work around this (shift all subsequent spanned markers forward) ?
    MC 2018.12.5 (Symphony option)/BCC2019 12.0.4/RED 5.6; BlackMagic Ultrastudio Mini Monitor (11.2); DELL Precision 5530 - Intel Core i7-8850H 2.6 GHz -... [view my complete system specs]
  • Wed, Mar 8 2017 2:14 PM In reply to
    • JD Marlow
    • NYC
    • Posts 75
    • Points 805
    I assume you're talking about sequence markers, not source markers.  As far as I know, there isn't a great way to do it.
