Latest post Thu, Aug 1 2013 8:07 PM by Dale Gagne. 4 replies.
  • Thu, Aug 1 2013 5:22 PM
    • Dale Gagne
    • Joined on Mon, Oct 24 2011
    • Toronto, Ontario
    • Posts 124
    • Points 1,310
    MC 7 / Mac - Duplicating sequence bug
    Is anyone else seeing the behaviour when trying to duplicate a sequence either through the contextual menu or keyboard command that you get an error screen. You can continue without crashing MOST times but often an application or system restart is required to fix the issue SOMETIMES. It doesn't always fix it and never allows a duplication even if copying to a new sequence or original sequence to new bin. I have never had this error before v7. wondering if bugs are coming out of the woodwork.
    Using AVID mc7 on 12 core Mac Pro w 24g ram.
    Avid MC 2018.12.2, Avid Mojo DX, Mac Pro, Mid 2012, 2x2.4 ghz 6 CORE Intel Xeon, 64GB Ram, SSD Startup, 10.12.6, ATI Radeon HD 5770, 9TB Internal Storage... [view my complete system specs]
  • Thu, Aug 1 2013 6:57 PM In reply to
    • briMestone
    • Joined on Fri, Nov 18 2005
    • San Francisco
    • Posts 140
    • Points 1,570
    Re: MC 7 / Mac - Duplicating sequence bug
    Interesting..
    Can you elaborate a bit on the environment (if you don't mind)
    OSX version? sequence created in old version? or brandnew sequence created in v7? Frame rate and resolution?
    6 ISIS5000 split in two environments, 25 MC7+SYM NitrisDX, MacPro3,1 MacPro4,1 [view my complete system specs]
    Ted Simbajon
    http://www.tedsimbajon.com
    Head Janitor
  • Thu, Aug 1 2013 7:24 PM In reply to
    • Dale Gagne
    • Toronto, Ontario
    • Posts 124
    • Points 1,310
    Sorry yes...
    Typically sequences created in older versions as we are on a tv series. Sequences are brought from either v5.0.3 or 6.0.3 to v7.Although I have tried cutting the sequence into a new sequence made in v7 but with same result.
    OS X 10.8.4,
    Projects are 1920x1080 , 23.976, dnxhd 36, mxf
  • Thu, Aug 1 2013 7:35 PM In reply to
    • briMestone
    • San Francisco
    • Posts 140
    • Points 1,570
    bummer.. see if this will give you a different result.
    Export the old sequence as AAF (LINKED) then import it back.
    When you export, make sure you don't load the sequence. Just select the sequence on the bin by itself then export it as AAF ( also, check the "Enable Edit Protocol" ).
    Ted Simbajon
    Head Janitor
  • Thu, Aug 1 2013 8:07 PM In reply to
    • Dale Gagne
    • Toronto, Ontario
    • Posts 124
    • Points 1,310
    I'll give it a try. Thanks for the suggestion. Might go back to 6.5 and wait for the v7 patch update.
