Latest post Sun, Mar 17 2019 6:59 AM by TrevorA. 14 replies.
Page 1 of 1 (15 items)
  • Mon, Aug 12 2013 3:54 PM
    • PatrickL
    • Joined on Mon, Jun 17 2013
    • Posts 7
    • Points 105
    Audio metadata not importing right
    I know this might not be a suitable question for an Avid forum, since it might not be an Avid issue, but i am slowly creeping towards insanity on this one. I am looking for all the help i can get.
    We are doing post on a feature, where the sound guy is recording on an Aaton Cantar, he is delivering Poly files, which is usually fine, I have imported plenty of poly audio files into the Avid without issues. But for some reason the files he has delivered so far imports fine except the track names for track 2-7 are non existing, there are no columns for them, even if a load them into a bin with a bin view with several tracks showing..
    I then proceeded to do the usual google'ing, but to no avail, i could tell other people have had the same issue, but i couldn't find a solution to the problem. I thougt for a moment that it might have something to do with Avid only reading the BEXT data in the file.
    As it is now i am loading the poly files into Wave Agent where the track names show up as they should, i then split the poly file and combine it again, then import it to Avid. And the track names show up fine.
    I am just left wondering if anyone has had the same problem and found a better solution?
  • Mon, Aug 12 2013 5:26 PM In reply to
    Re: Audio metadata not importing right
    The thing is, if you import poly's, the track descriptors are not baked into the independent files. They might be listed in some header for the entire multichannel clip, but that's not useful. And indeed, Avid MC does not support iXML through File->Import (they do over AMA, but that is a dangerous method!).
    Bummer, and a darn shame that Avid and Aaton never worked this out properly.
    My workaround has been the following:
    - ask the sound dept for BWF-M's, and ask them to provide you with an accompanying ALE files [or use Majax to change any Poly's back to Multi-mono's, and generate an ALE from there, but I have not always been able to generate the right ALE in Majax, somehow]
    - import the individual mono's WITHOUT using the "autodetect BWF groups" (or something like that; if you DO use that option, only the metadata for channel 1 is used for the clip). You will now see that the individual tracks all have their own track descriptors, and if you were to export them to ProTools you would find that this metadata is actually baked into the actual Avid mediafile(s).
    - Import the ALE from the sound dept [or the one you created in Majax], set the Shot Log options to "Maintain Events As Logged".
    - Select the clips generated by the ALE, choose Clip->Relink. This should now relink these multitrack clips to the individuale monophonic imports.
    Advantage:
    1. you have the actual metadata for each track, even at file level, which will transfer to Pro Tools
    2. you have an actual single mutichannel clip inside Media Composer (which allows for easier syncing and matchframing)
  • Tue, Aug 13 2013 11:09 AM In reply to
    • PatrickL
    • Posts 7
    • Points 105
    Alright, thanks for the reply! This eases my mind a bit, even though it really is a bummer that they couldn't work it out.
    I thought for a moment i was missing something really simple, but from what you're saying it seems like it just can't be done the normal, easy way. I'll try your suggestion and see if i can't make work that way.
    Once again, thanks for the reply!
  • Mon, Mar 14 2016 8:59 PM In reply to
    • bdss
    • Joined on Wed, Oct 25 2006
    • paris
    • Posts 3
    • Points 55
    I wake this topic up almost three years later :)
    I have the exact same issue (MC 8.4.5 and Cantar X2 & X3). I have 8 tracks BWF to import. With "import", some metadatas are missing. Via "link import", metadatas are present (but it's not a solution in my case > feature film).
    Is there an other way than relinking with ALE to solve this ? Am I missing something ?
    Thanks for advices.
    Mac pro Intel Xeon 2x2,66, 9 GB RAM, OSX 10.6.6, MC 5.0.3 [view my complete system specs]
  • Mon, Apr 18 2016 12:30 PM In reply to
    We are having a similar problem, too (a month later).  Our AAF we sent to Sound allows for 'Expand All Tracks' function in ProTools but there seems to be metadata missing such as the track labels (found under the TRK1 to TRK8 headings in the Avid bin for each poly clip that was imported directly into the Avid).
    If we discover anything, will let you all know, but hopefully someone has a suggestion that will take some of the pain out of figuring this out.
    Jonno
    iMac (27", Late 2013, 3.5 GHz Intel Core i7, 16 GB, OS X 10.10.5) Connected to 27" Thunderbolt Display, BlackMagic UltraStudio Express (10.7... [view my complete system specs]
    www.fusspotfilms.com
  • Mon, Apr 18 2016 1:45 PM In reply to
    If they were BWF-P, I don't think they make it into the MC's actual media file, only into the master clip. And PT is stone deaf to the metadata from AAF's. Also, I have found some metadata from imports to get baked into OMF media that does not get baked into MXF audio media files -- or at least not seem by PT.
    Best way to force PT to see metadata is to bring in the original wav's, along with your AAF and MXF media, and have PT treat your Avid tracks as Field Recorder Guide Tracks, then make PT find Field Recorder originals.
  • Wed, Apr 20 2016 11:35 AM In reply to
    Hey Job --
    Just a question for you:
    Seeing as using AMA seems to bring in more audio metadata ...  could you somehow AMA link, copy the metadata or make an ALE, etc.  Then tranditionally import the audio (therefore preserving the ability to perf slip, etc).  And then marry the AMA file`s metadata to the one you imported?
    Home: 2012 rMBP 2.6ghz, 16GB RAM, OSX 10.10.5, MC 8.4.1 || Work: HP Z400, Win7 Professional, MC 6.5, ISIS/Interplay @danielfrome on twitter [view my complete system specs]
    Avid GoPro
  • Wed, Apr 20 2016 4:24 PM In reply to
    Good Q. I guess you could AMA-link, export ALE, import ALE, batch import those clips. Still zero guarantee of any of that making it into Pro Tools. Did I mention how deaf and blind that is to metadata? ;)
  • Wed, Oct 18 2017 10:16 AM In reply to
    • jschreyer
    • Joined on Tue, Jun 18 2013
    • Posts 18
    • Points 210
    Has anyone found a solution to this? Having the same trouble with our sound dept, the usual workaround is using OMF media, but this is a mess on the Avid side and an extra rebatch to omf session isn't much of a choice due to time issues.
    I came across this
    http://duc.avid.com/showpost.php?p=2186544&postcount=7
    but haven't got the time (or software) to verify.
    Can anyone confirm this?
    J.
  • Mon, Oct 23 2017 7:48 PM In reply to
    • Posts 10,152
    • Points 217,280
    Hi there
    There's not a lot of detail in there to tell what metadata you are missing. Most likely you are commenting  that import of Broadcast Wave doesn't bring in any iXML metadata, a problem at is easily cured by using AMA Link with the WaveAIFF plug-in instead, although that has other drawbacks. Usually, the comment we hear is that not all the track names appear, because there isn't room enough in the BEXT header that import does read to include them all.  The problem is, essentially, that the data isn't there for MC to read it.  It is in iXML, but not BEXT, but import only read BEXT, AMA link reads both. Marianna
  • Mon, Dec 4 2017 8:31 PM In reply to
    • JesusPM
    • Joined on Mon, Dec 4 2017
    • Posts 13
    • Points 155
    Hello,
    I'm having the same issue with Poly BWF originated in a Nagra VI recorder:
    • If I Import a poly BWF file, I get no channel metadata.
    • If I use AMA Link instead, I don't get channel metadata either. According to Marianna, this should work, so I don't know what the problem is... I'm specifically choosing the built-in WaveAIFF plug-in in the Link to Media window.
    So here is my workaround, in case it's useful for anybody else:
    • I split the Poly BWF into Mono files, using WaveAgent (which is free and preserves all the original metadata).
    • I AMA Link the Mono files into avid activating the option "Autodetect Broadcast Wave Monophonic Groups". That way, I don't end up with one master clip per channel (just one master clip per take, with all the tracks). And what's best, the master clip displays all the channel metadata entered by the sound recordist properly in the Bin.
    • Finally, I Consolidate the AMA Linked master clips and work with MXF Avid MediaFiles moving forward.
    I've exported an AAF to ProTools just for testing ("Include Inactive Audio Tracks" option is enabled), and my sound guy has no issues with this workflow. He can actually link my AAF to the original Poly BWF files, switch takes by right-clicking in ProTools, etc.
  • Tue, Dec 5 2017 7:53 PM In reply to
    • JesusPM
    • Posts 13
    • Points 155
    Hi all,
    I'm having the same issue working with 6 channel Poly BWF files, generated in a Nagra VI recorder.
    If i Import them, Avid will only read BEXT metadata (and ignore iXML metadata) - and unfortunately there is not enough room in the BEXT header for all the track names, so no channel metadata comes across.
    Import only works with Mono BWF files, so of course we can split the Poly BWF files using WaveAgent and then Importing them into Avid disabling "Autodetect Broadcast Wave Monophonic Groups" (otherwise, it won't work). For me, that's not ideal, since you end up with multiple audio master clips per take (one clip per channel). This is particularly tedious when you need to fix timecode offsets, because you need to manually mark a new sync point in several audio files for a single take...
    According to Marianna, AMA Link reads both, BEXT and iXML metadata. But if I Link my Poly BWF files using specifically the WaveAiff Plug-In, still no channel names come across. So this is clearly not working: currently there is no way to bring that metadata into Media Composer unless you use an .ALE file (which my sound department can't provide).
    1. I split the original Poly BWF using WaveAgent.
    2. I AMA Link the resulting Mono BWF enabling "Autodetect Broadcast Wave Monophonic Groups", so I just end up with a single audio master clip per take. At least, using AMA, all the channel names come across when Autodetecting Groups (unfortunately, this doesn't work over Import - you only get the name of the first channel).
    3. I Consolidate all the Linked files... and from that point on, I exclusively work with the MXF rewrapped Avid MediaFiles, because I don't like to mix workflows (my rushes are delivered as DNx36 MXF files).
    This workflow requires a few extra steps and it's kind of limiting, because Avid knows the audio was ingested over AMA Link (Consolidating won't full the application), which means I cannot adjust Sync by Perforations (1/4 frame). Believe me, I've tried and I get the following message: "This clip was not digitized with audio rate addressing".
    Avid Slip Sync Error
    So to wrap this up, unless you get an .ALE with all the channel names, if you need to work with Poly BWF files, you need to choose between having precise sync or channel names. You can't have them all. It's increidble how Avid makes simple things so complicated for its users. If I drag my Poly BWF files into Final Cut Pro X, I have no issues whatsoever:
    Final Cut Pro X Audio Inspector
    • All the audio channels are properly named.
    • I can disable channels across multiple clips in a batch in the Browser.
    • I can adjust sync at the sample level, and more importantly, at any point in time (even after creating Synchronized or Multicam clips).
    • I can display audio channel names in the magnetic Timeline when I need to.
    • I can Mute or Solo audio channels across my Timeline without paying attention to track numbers.
    After getting used to all these things, it's harder and harder to go back to Avid...
  • Tue, Dec 5 2017 7:57 PM In reply to
    • JesusPM
    • Posts 13
    • Points 155
    Hi all,
    2. AMA Link the resulting Mono BWF enabling "Autodetect Broadcast Wave Monophonic Groups", so I just end up with a single audio master clip per take. At least, using AMA, all the channel names come across when Autodetecting Groups (unfortunately, this doesn't work over Import - you only get the name of the first channel).
    3. Consolidate all the Linked files... and from that point on, I exclusively work with the MXF rewrapped Avid MediaFiles, because I don't like to mix workflows (my rushes are delivered as DNx36 MXF files).
  • Sat, Mar 16 2019 8:52 PM In reply to
    • lextv
    • Joined on Tue, Jan 29 2019
    • Posts 10
    • Points 100
    Hi all
    I'm not intending to hijack every thread on this issue, but I've developed a little app to perform a workaround while we wait for Avid to sort this issue out.
    Prior to ingest, it splits and renames the files to include the track names so we can see them on the timeline.
    Take a look and let me know any comments, etc.
    https://lextv.uk/bwfwavrename/
    Cheers
    Lex
  • Sun, Mar 17 2019 6:59 AM In reply to
    • TrevorA
    • Posts 1,117
    • Points 12,720
    lextv:
    Cheers
    Lex
    Thanks Lex, will give this a try, looks very useful
