Latest post Fri, Apr 24 2020 2:43 PM by Maniavid. 8 replies.
Page 1 of 1 (9 items)
  • Wed, Aug 28 2013 1:31 PM
    Free download of BCC & FEC AVX effects bins for Symphony
    For users of BCC8 AVX and/or FEC7 AVX there is a free download of some effect bins available (with a movie explaining what the effects are) on borisfx.com here ;
    http://www.borisfx.com/videos/BCCAVX/Avid-Bin-Templates-Overlay-Transitions.php
    These effects are basically some stacks of BCC and FEC AVX effect filters keyframed and adjusted to be used as transition effects.
    The longer movie @ the above address explains how to use them in more detail, but this movie (a much shorter 30 second excerpt taken from the above movie) gives you an idea of the kinds of effects provided ;
    http://www.borisfxresources.com/AvidForum/AVXoverlayTransitions-Short/AVXoverlayTransitions-Short.html
    —————— Dirk de Jong BorisFX
  • Tue, Sep 3 2013 1:40 PM In reply to
    • Puzzle
    • Bangkok, Thailand
    • Posts 196
    • Points 2,425
    Re: Free download of BCC & FEC AVX effects bins for Symphony
    I download the BCC & FEC AVX effects bin...could you tell me how to install it into the Avid? Where is the BorisFXAVXoverlayTransitions folder needs to be place?
    Thanks for your help
    Smith Timsawat
    Avid Media Composer with Symphony option V.2018.12.1 Avid Artist DNxIQ HP Z820 Workstation Intel Xeon E5-2665@2.40GHz (2 Processors) 32GB RAM Window7 Pro... [view my complete system specs]
  • Tue, Sep 3 2013 6:09 PM In reply to
    Puzzle:
    sure. Someone on another forum recently asked the same question and so I made this web page to explain ;
    http://www.borisfxresources.com/AvidForum/howToOpen/howToOpen.html
    Basically you choose "Open Bin" in Media Composer, navigate to where the bins are, select a bin that matches the frame rate of your project, and hit the "Open" button in the File selection dialogue window. then the bin will be open in your project, and you can apply the effect stacks.
    The project will remember the bin under "Other Bins" and it will remember the file path from when you opened it - so you might want to move it someplace more permanent than your desktop before opening it. If they are opened from the desktop and the bins are later moved from the desktop MC would fail to find them and you would need to re-open the bins from where ever they were in order to apply more instances from the bins.
    To clarify, MC needs to have the bins open for applying the effects but once they are applied in a sequence it no longer needs the bin to maintain the effect in that sequence (it is only necessary that BCC and/or FEC is installed - depending on which stacks are applied) I hope that makes sense.. (it sounds more complicated than it really is ; >)
  • Sat, Sep 21 2013 4:11 PM In reply to
    • issey9090
    • Joined on Mon, Jan 4 2010
    • Posts 30
    • Points 410
    Great - will give these a go - very handy to have to quickly show client a quick range of transitions to choose from
    thanks
  • Sun, Sep 22 2013 1:23 AM In reply to
    • Adman
    • Atlanta Georgia, USA
    • Posts 5,413
    • Points 61,085
    • BlogAuthor
      Moderator: Avid Free DV
      Moderator: Avid Xpress DV PC
      Moderator: Avid Xpress Studio
    Thanks Dirk! :)
    Mac Pro, 64GB Ram. 1TB SSD system drive, 250Gb SSD external (media) drive. QHD Ultra wide, thunderbolt LG monitor, MC 2019.12.1. Pro Tools 11 HD (Mbox... [view my complete system specs]
  • Tue, Sep 24 2013 1:52 AM In reply to
    Yes
    Desktop PC
    Corsair RM750X|Asus P8Z68 Deluxe(Gen3)|i7 2600K@4.4|Corsair 32G DDR3|PNY Quadro P2000(441.28)|Samsung 850 Pro SSD(OS) 256 GB|2x1TB Crucial MX500@RAID 0|2x500GB Mushkin SSD@RAID 0|LG BH16NS40|W10 Pro 64bit|Media Composer Software 2020.4 with Symphony Option on Dongle|2xHP 22'' Monitors|M-Audio AV30 Speakers.
    3 Heads Digital Films
  • Wed, Oct 23 2013 9:54 PM In reply to
    • CraigACM
    • Posts 1
    • Points 15
    I just downloaded the transitions but I'm having problems using them.  Although 6 of the BCC transition overlays work, the others, when dropped on V2 show a blank screen.  Opening them up in Effects Editor reveals either that several of the nested BCC effects in the stack say "Unavailable Effect", or, when (I'm assuming) only one BCC plug-in is being called for, the effect name appears in Italics and there are no contols in the Effect Editor.
    I have BCC 8.1 installed with Symphony 6.5.3 and those "unavailable effects" are in my normal BCC effects folders.  Radial Blur, Film Glow, Lens Flare 3D, Rays Puffy, Film Damage are the ones that are identified as unavailable, but I have them in my effects palette.
  • Thu, Oct 24 2013 3:29 AM In reply to
    CraigACM:
    You need to update to BCC 8.2, which will also give you many more green dot effects.
    click the Continuum Complete AVX link here ;  http://www.borisfx.com/updates/ and follow the steps to download the installer
    you can see a sort of intro to the 8.2 release here ; http://youtu.be/a9r26ZyB1xE
  • Fri, Apr 24 2020 2:43 PM In reply to
    • Maniavid
    • Joined on Tue, Mar 16 2010
    • Posts 26
    • Points 260
    If any of you guys is interested in some hip templated/preset effects and transition for their Avid, checkout this website https://fxsyndrome.io
    They have a Boris CC option and a No-Plugin option. Very handy and easy and affordable.
