Latest post Mon, Sep 16 2013 7:32 AM by DGG. 4 replies.
  • Wed, Sep 11 2013 4:09 PM
    • DGG
    • Joined on Tue, Sep 19 2006
    • Barcelona, Spain
    • Posts 81
    • Points 1,070
    Help with HD import/export
    Hi everybody,
    I only moved to HD late last year, and I'm making some kind of rookie mistake: I have imported footage which is at 1920 X 1080 (with the option 1:1 MXF) but now Avid only offers me to export it as 1024 X 576...
    What am I overlooking? Thanks in advance!
    Avid Media Composer 7, on Windows 7 Professional, on a Dell Precision T5400 workstation, with 32 Gb of RAM [view my complete system specs]
    Filed under: , ,
  • Wed, Sep 11 2013 9:45 PM In reply to
    • Vilem
    • Joined on Sat, Apr 10 2010
    • Prague
    • Posts 1,404
    • Points 15,465
    Re: Help with HD import/export
    It seems that the project is in SD resolution. Check and set the resolution to HD project.
    V.
    AVID MC2018.12.1 - dongle, HP Z620 - 2 x Intel Xeon E5-2620, Quadro P2000 - driver 390.77, RAM 48GB - DDR3, BM Intensity Pro 4k - 10.11, W10 - 64bit Professional... [view my complete system specs]
  • Thu, Sep 12 2013 11:11 AM In reply to
    • DGG
    • Barcelona, Spain
    • Posts 81
    • Points 1,070
    Thanks for that Vilem. In case it might help anybody in the future, it also had something to do with the Import settings option "Image size adjustment".
  • Thu, Sep 12 2013 11:44 AM In reply to
    Do you really want to work at 1:1? For HD content that is massive (DNX185 is normally more than enough)
    Also Importing stuff is largely better if you use AMA and then Transcode (teh conform time can be much less)
    Your export choices in terms of image size are determined by the project format. SO if you import into an SD project you amke SD media and will only have SD export options.
    If you import into an SD project (and make SD media) and change to an HD project and then export you will have upscaled Sd media.
  • Mon, Sep 16 2013 7:32 AM In reply to
    • DGG
    • Barcelona, Spain
    • Posts 81
    • Points 1,070
    Thanks for that information... I'll definitely try DNX185 now.
