Latest post Mon, Oct 14 2013 5:23 PM by StephStorm. 3 replies.
  • Mon, Oct 14 2013 3:33 PM
    • StephStorm
    • Joined on Mon, Oct 14 2013
    • Posts 3
    • Points 25
    Recieving an error message when trying to play any of my sequences.
    Last night before I went to bed, I accidentaly pulled the end of my clip, which the ripple trim tool selected to the front of my timeline, I quickly undid this and tried to go on my way, but my computer was not having it at all. As it was late, I force quit Avid Media Composer for the night. I tried to get back on it this morning and it opens fine but when I open a sequence or try to play them the following error shows up:
    "Error: Exception: AMPI subsystem error, ErrorMessage: DSM error code eDSMError_SendMessageErr, AMPIEngineComponentRep::Initialize in AMPIEngine.cpp: 197, mRep->Initialize failed in AMPIEngine.cpp: 312, AMPIEngineComponent::InitializeEngine sync=1 in AMPIEngine.cpp: 316"
    After restarting the program, the first error that I recieve is this:
    "Exception: AMPI subsystem error, ErrorMessage:DSM future error from server eDSMError_ServerDied: (null), AMPIEngineComponent::FinishedProcessing in AMPIEngine.cpp:439"
    Then this when trying to play clips:
    "Exception: AMPI subsystem error, ErrorMessage:DSM error code eDSMError_SendMessageErr, Audio MixPathComponent::DisconnectOutputSection in AudioMixPath.cpp: 1034"
    As I'm still in the processes of learning the program, I don't know if what I did accidentaly last night caused this and, if it did, I don't know how to resolve it.
    Any help would be greatly appreciated so I continue working on an edit. Thank you!
    Mac OSX, Version 10.7.5; Processor: 2.6 GHz Intel Core i7; Memory: 8 GB 1600 MHz DDR3; Startup Disk: Macintosh HD; Media Composer Interlay Edition 7.0... [view my complete system specs]
    Filed under: , ,
  • Mon, Oct 14 2013 4:01 PM In reply to
    • Posts 10,219
    • Points 218,265
    Re: Recieving an error message when trying to play any of my sequences.
    Steph
    First, could you update your profile with your system spec's?  hard to help when we dont know what hardware you have, OS or MC version.
    Secondly, when you say the first error you get - does this occur during the launch of the application or when the bin is loading or the timeline?
    Potentially a corrupt clip ( the one you moved) due to the force quit....
    Also, you should check this Knowledge Base article
    http://avid.force.com/pkb/articles/en_US/error_message/en377091?popup=true&NewLang=en&DocType=1081
  • Mon, Oct 14 2013 5:00 PM In reply to
    • StephStorm
    • Posts 3
    • Points 25
    I updated my system specs, I was unsure if any other information was needed but if there is anything else, I'll surely include it.
    It shows an error once I have have already opened the sequence and click play. In different parts of the projects and certian sequences it shows a few different errors, though they are all only when I try to play what is in my timeline and are all related to whatever "AMPI" is.
    I did a disk repair and it did not do anything. I will attempt to reinstall the PACE driver as the article suggested and see if that solves the problem.
    As well, now when I try to close the program, I am getting this crash error message, not sure if it will help but I wanted to include it just incase:
    Process:         AvidMediaComposer [12849]
    Path:            /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/AvidMediaComposer
    Identifier:      com.avid.mediacomposer
    Version:         7.0.2.1776 (7.0.2)
    Code Type:       X86-64 (Native)
    Parent Process:  launchd [144]
    Date/Time:       2013-10-14 13:01:38.175 -0400
    OS Version:      Mac OS X 10.7.5 (11G63b)
    Report Version:  9
    Interval Since Last Report:          111634 sec
    Crashes Since Last Report:           15
    Per-App Interval Since Last Report:  67202 sec
    Per-App Crashes Since Last Report:   6
    Anonymous UUID:                      00C3A09D-EBF6-43D3-8D1C-130F5FC60263
    Crashed Thread:  0  Dispatch queue: com.apple.main-thread
    Exception Type:  EXC_BAD_ACCESS (SIGSEGV)
    Exception Codes: 0x000000000000000d, 0x0000000000000000
    VM Regions Near 0:
        __TEXT                 0000000100000000-00000001013fe000 [ 20.0M] r-x/rwx SM=COW  /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/AvidMediaComposer
    Application Specific Information:
    objc[12849]: garbage collection is OFF
    Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
    0   com.avid.mediacomposer            0x0000000100976db5 DynRelinkWrapper::NotifySubscribersOfTheChange(void*) + 49
    1   libUIShell.dylib                  0x000000010a75dae7 AApplication::DoEndOfEventTasks() + 287
    2   libUIShell.dylib                  0x000000010a7554ed AApplication::HandleEvent(Mac2Qt::EventRecord*) + 1149
    3   com.avid.mediacomposer            0x00000001000a314b MediaComposerApp::HandleEvent(Mac2Qt::EventRecord*) + 135
    4   libUIShell.dylib                  0x000000010a7df9df AutoRequestDlg::Run(unsigned char (*)(DialogWindow*, AGadget*, int), int) + 465
    5   libUIShell.dylib                  0x000000010a7e075a AvSimpleDlg(char const*, char const*, short, UIicon_t, char const*, unsigned char, char const*) + 200
    6   com.avid.AvidCore                 0x00000001089a7212 _ZL31INTERNAL_NonThreadSafe_UIdialogPKcS0_s8UIicon_tS0_hS0_ + 84
    7   com.avid.AvidCore                 0x00000001089a79d2 UIdialog(char const*, char const*, short, UIicon_t, char const*, unsigned char, char const*) + 203
    8   libUIShell.dylib                  0x000000010a75a24e AApplication::FatalErrUI(char const*, char const*, int) + 1328
    9   com.avid.AvidCore                 0x0000000108970c30 __FtlAbortm(char const*, char const*, int) + 376
    10  com.avid.AvidCore                 0x000000010897101f __FtlAssertFailed(char const*, char const*, int) + 189
    11  com.avid.mediacomposer            0x0000000100ab2a7f RemoveWindowFromWindowsMenu(Mac2Qt::WindowRefTmpl<Mac2Qt::AQtWindow*>) + 111
    12  com.avid.mediacomposer            0x0000000100769457 BinWindow::Close(void*, Mac2Qt::EventRecord*, int, int) + 4123
    13  libUIShell.dylib                  0x000000010a72c540 AWindow::DoWindowMsg(windowMsgID_t, void*, Mac2Qt::EventRecord*, int, int) + 390
    14  libUIShell.dylib                  0x000000010a73113a AWindow::SendMsg(windowMsgID_t, Mac2Qt::EventRecord*, int, int) + 210
    15  com.avid.mediacomposer            0x00000001000e3436 ProjectWindow::CloseAllOpenBins(int, int) + 380
    16  com.avid.mediacomposer            0x00000001000f9fcd ProjectWindow::Close(void*, Mac2Qt::EventRecord*, int, int) + 381
    17  libUIShell.dylib                  0x000000010a72c540 AWindow::DoWindowMsg(windowMsgID_t, void*, Mac2Qt::EventRecord*, int, int) + 390
    18  libUIShell.dylib                  0x000000010a73113a AWindow::SendMsg(windowMsgID_t, Mac2Qt::EventRecord*, int, int) + 210
    19  com.avid.mediacomposer            0x00000001000a2354 MediaComposerApp::QuitCmd() + 260
    20  libUIShell.dylib                  0x000000010a759276 AApplication::CarbonEventHandlerProc(Mac2Qt::Private::EventHandlerCall*, Mac2Qt::Private::EventQueueItem*, void*) + 536
    21  com.avid.Mac2Qt                   0x000000010ee4a21b Mac2Qt::Private::EventHandlerCall::invokeNextHandler() + 189
    22  com.avid.Mac2Qt                   0x000000010ee469b1 Mac2Qt::Private::DispatchEventToCallbacks(Mac2Qt::Private::EventQueueItemSmartPtr const&) + 197
    23  com.avid.Mac2Qt                   0x000000010ee47860 Mac2Qt::Private::Mac2QtEventWaiter::eventFilter(QObject*, QEvent*) + 422
    24  com.avid.Mac2Qt                   0x000000010ee49708 Mac2Qt::Private::TopMostFilter::eventFilter(QObject*, QEvent*) + 24
    25  QtCore                            0x0000000101d3d1e7 QCoreApplicationPrivate::sendThroughApplicationEventFilters(QObject*, QEvent*) + 167
    26  QtGui                             0x0000000101febed6 QApplicationPrivate::notify_helper(QObject*, QEvent*) + 38
    27  QtGui                             0x0000000101ff221e QApplication::notify(QObject*, QEvent*) + 254
    28  com.avid.Mac2Qt                   0x000000010ee5539e Mac2Qt::AQtApplication::notify(QObject*, QEvent*) + 312
    29  QtCore                            0x0000000101d3d3ec QCoreApplication::notifyInternal(QObject*, QEvent*) + 124
    30  QtCore                            0x0000000101d3e150 QCoreApplicationPrivate::sendPostedEvents(QObject*, int, QThreadData*) + 896
    31  com.apple.CoreFoundation          0x00007fff8fec14f1 __CFRUNLOOP_IS_CALLING_OUT_TO_A_SOURCE0_PERFORM_FUNCTION__ + 17
    32  com.apple.CoreFoundation          0x00007fff8fec0d5d __CFRunLoopDoSources0 + 253
    33  com.apple.CoreFoundation          0x00007fff8fee7b49 __CFRunLoopRun + 905
    34  com.apple.CoreFoundation          0x00007fff8fee7486 CFRunLoopRunSpecific + 230
    35  com.apple.AppKit                  0x00007fff9166db08 -[NSMenu _internalPerformActionForItemAtIndex:] + 38
    36  com.apple.AppKit                  0x00007fff914fc6f9 -[NSCarbonMenuImpl _carbonCommandProcessEvent:handlerCallRef:] + 138
    37  com.apple.AppKit                  0x00007fff913489bb NSSLMMenuEventHandler + 339
    38  com.apple.HIToolbox               0x00007fff8d435234 _ZL23DispatchEventToHandlersP14EventTargetRecP14OpaqueEventRefP14HandlerCallRec + 1263
    39  com.apple.HIToolbox               0x00007fff8d434840 _ZL30SendEventToEventTargetInternalP14OpaqueEventRefP20OpaqueEventTargetRefP14HandlerCallRec + 446
    40  com.apple.HIToolbox               0x00007fff8d44b6db SendEventToEventTarget + 76
    41  com.apple.HIToolbox               0x00007fff8d4917b5 _ZL18SendHICommandEventjPK9HICommandjjhPKvP20OpaqueEventTargetRefS5_PP14OpaqueEventRef + 398
    42  com.apple.HIToolbox               0x00007fff8d578e2d SendMenuCommandWithContextAndModifiers + 56
    43  com.apple.HIToolbox               0x00007fff8d5c05b5 SendMenuItemSelectedEvent + 253
    44  com.apple.HIToolbox               0x00007fff8d48a883 _ZL19FinishMenuSelectionP13SelectionDataP10MenuResultS2_ + 101
    45  com.apple.HIToolbox               0x00007fff8d481fc9 _ZL14MenuSelectCoreP8MenuData5PointdjPP13OpaqueMenuRefPt + 600
    46  com.apple.HIToolbox               0x00007fff8d481592 _HandleMenuSelection2 + 580
    47  com.apple.AppKit                  0x00007fff912491da _NSHandleCarbonMenuEvent + 250
    48  com.apple.AppKit                  0x00007fff911decc9 _DPSNextEvent + 2019
    49  com.apple.AppKit                  0x00007fff911de07d -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 135
    50  com.apple.AppKit                  0x00007fff911da9b9 -[NSApplication run] + 470
    51  QtGui                             0x0000000101faa5d0 QEventDispatcherMac::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) + 1824
    52  QtCore                            0x0000000101d3c304 QEventLoop::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) + 68
    53  QtCore                            0x0000000101d3c6b4 QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) + 324
    54  QtCore                            0x0000000101d3e63a QCoreApplication::exec() + 186
    55  com.avid.Mac2Qt                   0x000000010ee458e4 Mac2Qt::Private::Mac2QtEventWaiter::RunApplicationEventLoop() + 76
    56  com.avid.Mac2Qt                   0x000000010ee3ba3d Mac2Qt::RunApplicationEventLoop() + 36
    57  libUIShell.dylib                  0x000000010a7557b1 AApplication::Run() + 9
    58  libUIShell.dylib                  0x000000010a757f43 AApplication::Go() + 115
    59  com.avid.mediacomposer            0x00000001000a7180 main + 218
    60  com.avid.mediacomposer            0x000000010006b754 start + 52
    Thread 1:: Dispatch queue: com.apple.libdispatch-manager
    0   libsystem_kernel.dylib            0x00007fff8f9a47e6 kevent + 10
    1   libdispatch.dylib                 0x00007fff8f981786 _dispatch_mgr_invoke + 923
    2   libdispatch.dylib                 0x00007fff8f980316 _dispatch_mgr_thread + 54
    Thread 2:: MTThreadCoreThreads
    0   libsystem_kernel.dylib            0x00007fff8f9a26ce semaphore_timedwait_trap + 10
    1   com.apple.CoreServices.CarbonCore    0x00007fff8652526e MPWaitOnSemaphore + 77
    2   com.avid.AvidCoreThreads          0x0000000108f28f11 Threads::SemaRepNative::Decrement(char*, long) + 237
    3   com.avid.AvidCoreThreads          0x0000000108f22a2e Threads::Sema::Decrement(char*, long) + 14
    4   com.avid.AvidCore                 0x00000001088e9f3e MTSemaphoreCoreThreads::Decrement(unsigned long, unsigned int) + 242
    5   com.avid.AvidStorageAPI           0x000000010ff2e9ff StorageAPI::CommandProcessor::Body(StorageAPI::MTThread*) + 57
    6   com.avid.AvidStorageAPI           0x000000010ff3086a StorageAPI::MTThread::Run() + 30
    7   com.avid.AvidCoreThreads          0x0000000108f2d45e Threads::ThreadImp::StarterFluid(void*) + 282
    8   libsystem_c.dylib                 0x00007fff8f8ee8bf _pthread_start + 335
    9   libsystem_c.dylib                 0x00007fff8f8f1b75 thread_start + 13
    Thread 3:: MTThreadCoreThreads
    Thread 4:: MTThreadCoreThreads
    Thread 5:: MTThreadCoreThreads
    Thread 6:: MTThreadCoreThreads
    Thread 7:: MTThreadCoreThreads
    Thread 8:: VideoOutRenderer Thread
    0   libsystem_kernel.dylib            0x00007fff8f9a3bca __psynch_cvwait + 10
    1   libsystem_c.dylib                 0x00007fff8f8f2274 _pthread_cond_wait + 840
    2   com.avid.AvidCoreThreads          0x0000000108f2e736 Threads::NativeCondWait(_opaque_pthread_cond_t*, _opaque_pthread_mutex_t*, long, int, void**) + 249
    3   com.avid.AvidCoreThreads          0x0000000108f2f3f9 CoreThreadsMessageQueue::RemoveNext(Threads::Message**, long*, bool*, Threads::Message**, long*, bool*, long, int, void**, bool (*)(Threads::Message const*)) + 183
    4   com.avid.AvidCoreThreads          0x0000000108f2be5b Threads::ThreadImp::WaitForThreadMessage(Threads::Message**, long, bool (*)(Threads::Message const*), int, void**) + 1375
    5   com.avid.AvidCoreThreads          0x0000000108f25255 Threads::Messaging::WaitForThreadMessage(Threads::Message**, long, bool (*)(Threads::Message const*), int, void**) + 113
    6   com.avid.AvidCore                 0x00000001089079eb (anonymous namespace)::VORThreadBody::ThreadBody() + 45
    Thread 9:
    6   com.avid.AvidCoreThreads          0x0000000108f29368 Threads::Body::ThreadBody() + 32
    Thread 10:
    0   libsystem_kernel.dylib            0x00007fff8f9a267a mach_msg_trap + 10
    1   libsystem_kernel.dylib            0x00007fff8f9a1d71 mach_msg + 73
    2   com.apple.CoreFoundation          0x00007fff8fedf50c __CFRunLoopServiceMachPort + 188
    3   com.apple.CoreFoundation          0x00007fff8fee7c74 __CFRunLoopRun + 1204
    5   com.apple.CoreFoundation          0x00007fff8fef719f CFRunLoopRun + 95
    6   com.apple.AVCVideoServices        0x0000000122c44596 _ZN3AVSL27AVCVideoServicesThreadStartEPNS_28AVCVideoServicesThreadParamsE + 129
    7   libsystem_c.dylib                 0x00007fff8f8ee8bf _pthread_start + 335
    8   libsystem_c.dylib                 0x00007fff8f8f1b75 thread_start + 13
    Thread 11:: FlamethrowerThreadedLinkManagerRep::m_pLinkManagerThread
    6   com.avid.macflamethrowerohci      0x0000000122b99256 (anonymous namespace)::FlamethrowerThreadedLinkManagerThread::ThreadBody() + 252
    Thread 12:: Pyromaniac DIO FireBOBEventThread
    Thread 13:: Pyromaniac DIO DevicePortBusResetThread
    Thread 14:: *PMDIO_IOManagerRep::IOThread
    6   com.apple.diopyromaniacohci       0x000000011ea7a28e PMDIO_IOThreadBody::ThreadBody() + 84
    Thread 15:: PMDIO_InputModeRep::AudioInCBThread
    Thread 16:: PMDIO_OutputModeRep::VideoCBThread
    Thread 17:: *PMDIO_OutputModeRep::AudioCBThread
    Thread 18:: AVCReceiverThread
    6   com.apple.diopyromaniacohci       0x000000011ea8dcb9 PMDIODeviceControlRep::AVCReceiverThread() + 103
    Thread 19:: com.avid.xcorekit.Utilities.CacheRepository
    2   XcoreKit                          0x000000012bf09c8f Xcore::Utilities::MutexCondition_Unix::WaitUntil(Xcore::Utilities::AbsoluteTimeT const&) + 605
    3   XcoreKit                          0x000000012bf1378c Xcore::Utilities::MutexCondition::WaitDuring(Xcore::Utilities::TimeDurationT const&) + 70
    4   XcoreKit                          0x000000012bcfb2f3 Xcore::Utilities::CacheRepository::DoAutoPrune(Xcore::Utilities::TimeValue const&) + 597
    5   XcoreKit                          0x000000012bd1c6ea Xcore::Utilities::MemberFunction_1<Xcore::Utilities::CacheRepository*, void (Xcore::Utilities::CacheRepository::*)(Xcore::Utilities::TimeValue const&), void, Xcore::Utilities::TimeValue const&, Xcore::Utilities::TimeValue>::DoCallInternal(Xcore::Utilities::Bool2Type<true>) const + 76
    6   XcoreKit                          0x000000012bd104d4 Xcore::Utilities::MemberFunction_1<Xcore::Utilities::CacheRepository*, void (Xcore::Utilities::CacheRepository::*)(Xcore::Utilities::TimeValue const&), void, Xcore::Utilities::TimeValue const&, Xcore::Utilities::TimeValue>::operator()() const + 14
    7   XcoreKit                          0x000000012bd9983a Xcore::Utilities::SmartPtr<Xcore::Utilities::Function, true, true>::operator()() + 716
    8   XcoreKit                          0x000000012bda8a83 Xcore::Utilities::DelegateExecutor::Execute(Xcore::Utilities::SmartPtr<Xcore::Utilities::Operation, true, true> const&) + 285
    9   XcoreKit                          0x000000012bdac557 Xcore::Utilities::Executor::ThreadedExecute() + 1367
    10  XcoreKit                          0x000000012bdae7f6 Xcore::Utilities::MemberFunction_0<Xcore::Utilities::Executor*, void (Xcore::Utilities::Executor::*)(), void>::operator()() const + 60
    11  XcoreKit                          0x000000012bd9983a Xcore::Utilities::SmartPtr<Xcore::Utilities::Function, true, true>::operator()() + 716
    12  XcoreKit                          0x000000012bf0e03a Xcore::Utilities::Thread_Unix::ThreadRunner(Xcore::Utilities::Thread::ThreadData*) + 270
    13  libsystem_c.dylib                 0x00007fff8f8ee8bf _pthread_start + 335
    14  libsystem_c.dylib                 0x00007fff8f8f1b75 thread_start + 13
    Thread 20:: AMEDeferredTaskExecutor 00
    4   com.avid.AvidCore                 0x00000001088a5094 AMEDeferredTaskExecutor::ThreadBody() + 478
    5   com.avid.AvidCoreThreads          0x0000000108f2d45e Threads::ThreadImp::StarterFluid(void*) + 282
    6   libsystem_c.dylib                 0x00007fff8f8ee8bf _pthread_start + 335
    7   libsystem_c.dylib                 0x00007fff8f8f1b75 thread_start + 13
    Thread 21:: AMEDeferredTaskExecutor 01
    Thread 22:: AMEDeferredTaskExecutor 02
    Thread 23:: AMEDeferredTaskExecutor 03
    Thread 24:: AMEDeferredTaskExecutor 04
    Thread 25:: AMEDeferredTaskExecutor 05
    Thread 26:: AMEDeferredTaskExecutor 06
    Thread 27:: AMEDeferredTaskExecutor 07
    Thread 28:
    6   DSM_ClientLib                     0x000000011d00e50b DSM_InsertBPs(unsigned long long, int, DSM_AutoBreakpoint*, unsigned int) + 7247
    Thread 29:: Viewer_CPUQT_Offscreen
    6   com.avid.AvidCore                 0x00000001089e508b Viewer::ViewerThreadBody::ThreadBody() + 49
    Thread 30:: Viewer_CPUQT_DrawResource
    Thread 31:: Viewer_GPU_Default
    Thread 32:: Viewer_GPU_Src
    Thread 33:: Viewer_GPU_Rec
    Thread 34:: Viewer_GPU_FSP
    Thread 35:: Viewer_GPU_Polled
    Thread 36:: Viewer_CPUQT_Default
    Thread 37:: Viewer_CPUQT_Src
    Thread 38:: Viewer_CPUQT_Rec
    Thread 39:: Viewer_CPUQT_FSP
    Thread 40:: Viewer_CPUQT_Polled
    Thread 41:
    Thread 42:
    Thread 43:
    Thread 44:
    Thread 45:
    Thread 46:
    2   libtbb.dylib                      0x000000010fec7b97 tbb::internal::rml::private_worker::thread_routine(void*) + 455
    Thread 47:
    Thread 48:
    Thread 49:
    Thread 50:
    Thread 51:
    Thread 52:
    Thread 53:
    2   mt.dylib                          0x000000010e474557 CMTSingleTaskThread::ThreadFunctionImplementation() + 151
    3   mt.dylib                          0x000000010e473f1a CMTThreadImpl::Entry_point(void*) + 10
    4   libsystem_c.dylib                 0x00007fff8f8ee8bf _pthread_start + 335
    5   libsystem_c.dylib                 0x00007fff8f8f1b75 thread_start + 13
    Thread 54:
    Thread 55:
    Thread 56:
    Thread 57:
    Thread 58:
    Thread 59:
    Thread 60:
    Thread 61:: MVP_Host_Processing
    Thread 62:: MSP_Host_Processing
    Thread 63:
    6   com.avid.AMADeviceMonitor         0x000000011d78a9b0 AMA::Impl::CAMADeviceMonitor::ThreadMain(void*) + 146
    Thread 64:: Waveform Cache Thread
    Thread 65:: Waveform Cache Thread
    Thread 66:: Waveform Cache Thread
    Thread 67:: Waveform Cache Thread
    Thread 68:
    2   com.apple.audio.midi.CoreMIDI     0x000000010acac5be XServerMachPort::ReceiveMessage(int&, void*, int&) + 96
    3   com.apple.audio.midi.CoreMIDI     0x000000010accd653 MIDIProcess::RunMIDIInThread() + 207
    4   com.apple.audio.midi.CoreMIDI     0x000000010acad96a XThread::RunHelper(void*) + 10
    5   com.apple.audio.midi.CoreMIDI     0x000000010acad396 CAPThread::Entry(CAPThread*) + 98
    Thread 69:: AsyncRead
    6   com.avid.mediacomposer            0x000000010053ab18 OSXSerialIO::AsyncReadThread() + 70
    7   com.avid.mediacomposer            0x000000010053ad18 AsyncReadThreadJacket(void*) + 64
    8   com.avid.AvidCoreThreads          0x0000000108f2d45e Threads::ThreadImp::StarterFluid(void*) + 282
    9   libsystem_c.dylib                 0x00007fff8f8ee8bf _pthread_start + 335
    10  libsystem_c.dylib                 0x00007fff8f8f1b75 thread_start + 13
    Thread 70:: AsyncWrite
    6   com.avid.mediacomposer            0x000000010053a988 OSXSerialIO::AsyncWriteThread() + 56
    7   com.avid.mediacomposer            0x000000010053aaa8 AsyncWriteThreadJacket(void*) + 56
    Thread 71:: AsyncRead
    Thread 72:: AsyncWrite
    Thread 73:: AMonitorPane::mon::sourcemon
    Thread 74:: AMonitorPane::mon::recordmon
    Thread 75:: AMonitorPane::minimon::leftmon1
    Thread 76:: AMonitorPane::minimon::rightmon1
    Thread 77:: AMonitorPane::minimon::leftmon2
    Thread 78:: AMonitorPane::minimon::rightmon2
    Thread 79:: AMonitorPane::
    Thread 80:: AMonitorPane::
    Thread 81:: AMonitorPane::
    Thread 82:: AMonitorPane::minimon::rightmon
    Thread 83:: AMonitorPane::minimon::leftmon
    Thread 84:: AMonitorPane::minimon::leftmon1
    Thread 85:: AMonitorPane::minimon::rightmon1
    Thread 86:: AMonitorPane::minimon::leftmon2
    Thread 87:: AMonitorPane::minimon::rightmon2
    Thread 88:: AMonitorPane::minimon::topleftmon
    Thread 89:: AMonitorPane::minimon::botleftmon
    Thread 90:: AMonitorPane::minimon::centerleftmon
    Thread 91:: AMonitorPane::minimon::centerrightmon
    Thread 92:: AMonitorPane::minimon::toprightmon
    Thread 93:: AMonitorPane::minimon::botrightmon
    Thread 94:: AMonitorPane::
    Thread 95:: AMonitorPane::minimon::leftmon
    Thread 96:: AMonitorPane::minimon::rightmon
    Thread 97:: AMonitorPane::minimon::rightmon1
    Thread 98:: AMonitorPane::minimon::rightmon1
    Thread 99:: AMonitorPane::minimon::leftmon2
    Thread 100:: AMonitorPane::minimon::leftmon2
    Thread 101:: AMonitorPane::
    Thread 102:: AMonitorPane::
    Thread 103:: AMonitorPane::minimon::leftmon
    Thread 104:: AMonitorPane::minimon::centermon
    Thread 105:: AMonitorPane::minimon::rightmon
    Thread 106:: AsyncRead
    Thread 107:: AsyncWrite
    Thread 108:: Chron
    6   com.avid.AvidCore                 0x00000001088ddeb9 ChronBody::ThreadBody() + 547
    Thread 109:: AudioSuitePreviewThread
    6   com.apple.carbonbundletemplate    0x0000000122910f4d AudioSuiteDAEmanagerRep::PreviewThreadBody() + 53
    Thread 110:: AMonitorPane::mon::digirecmon
    Thread 111:: AMonitorPane::mon::clipboard
    Thread 112:: AMFImpl::SearchClientThread
    0   libsystem_kernel.dylib            0x00007fff8f9a3df2 __select + 10
    1   QtCore                            0x0000000101d6cf4e qt_safe_select(int, fd_set*, fd_set*, fd_set*, timeval const*) + 142
    2   QtCore                            0x0000000101d71323 QEventDispatcherUNIXPrivate::doSelect(QFlags<QEventLoop::ProcessEventsFlag>, timeval*) + 435
    3   QtCore                            0x0000000101d717f2 QEventDispatcherUNIX::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) + 178
    4   QtCore                            0x0000000101d3c304 QEventLoop::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) + 68
    5   QtCore                            0x0000000101d3c6b4 QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) + 324
    6   QtCore                            0x0000000101c22b38 QThread::exec() + 312
    7   com.avid.amf_Search               0x00000001349c7905 AMFImpl::SearchClientThread::run() + 809
    8   QtCore                            0x0000000101c260e4 QThreadPrivate::start(void*) + 356
    Thread 113:: AMFImpl::SearchClientThread
    Thread 114:: AMFImpl::SearchClientThread
    Thread 115:
    2   QtWebKit                          0x00000001049296f5 WTF::TCMalloc_PageHeap::scavengerThread() + 117
    3   QtWebKit                          0x0000000104929989 WTF::TCMalloc_PageHeap::runScavengerThread(void*) + 9
    Thread 116:: QThread
    1   QtCore                            0x0000000101d6d045 qt_safe_select(int, fd_set*, fd_set*, fd_set*, timeval const*) + 389
    7   QtCore                            0x0000000101c260e4 QThreadPrivate::start(void*) + 356
    Thread 117:: ThreadedPeriodicTimer kExtraHighPriority Thread
    4   com.avid.AvidCore                 0x00000001089ba4ba ThreadedPeriodicTimer::ProcessCallbacks() + 378
    Thread 118:: QThread
    Thread 119:: PendingMediaHelper
    Thread 120:: QThread
    Thread 121:
    2   com.avid.mediacomposer            0x0000000100dad5bd k34ba3 + 93
    Thread 122:
    2   com.avid.mediacomposer            0x0000000100dad4d0 a3467n3 + 192
    Thread 123:: PHTBody
    6   com.avid.mediacomposer            0x0000000100b51cb1 PHT::PlayerHostThread::ThreadBody() + 129
    Thread 124:: AMEDeferredTaskExecutor 00
    Thread 125:: AMEDeferredTaskExecutor 00
    Thread 126:: AMEDeferredTaskExecutor 01
    Thread 127:: AMEDeferredTaskExecutor 02
    Thread 128:: AMEDeferredTaskExecutor 03
    Thread 129:: AMEDeferredTaskExecutor 04
    Thread 130:: AMEDeferredTaskExecutor 05
    Thread 131:: AMEDeferredTaskExecutor 06
    Thread 132:: AMEDeferredTaskExecutor 07
    Thread 133:: AMEDeferredTaskExecutor 08
    Thread 134:: AMEDeferredTaskExecutor 09
    Thread 135:: AMEDeferredTaskExecutor 10
    Thread 136:: AMEDeferredTaskExecutor 11
    Thread 137:: AMEDeferredTaskExecutor 12
    Thread 138:: AMEDeferredTaskExecutor 13
    Thread 139:: AMEDeferredTaskExecutor 14
    Thread 140:: AMEDeferredTaskExecutor 15
    Thread 141:
    Thread 142:
    Thread 143:
    Thread 144:
    Thread 145:
    Thread 146:
    Thread 147:
    Thread 148:
    Thread 149:
    Thread 150:
    Thread 151:
    Thread 152:
    Thread 153:
    Thread 154:
    Thread 155:
    Thread 156:
    Thread 157:: AsyncMSMRescan
    Thread 158:
    0   libsystem_kernel.dylib            0x00007fff8f9a4192 __workq_kernreturn + 10
    1   libsystem_c.dylib                 0x00007fff8f8f0594 _pthread_wqthread + 758
    2   libsystem_c.dylib                 0x00007fff8f8f1b85 start_wqthread + 13
    Thread 159:
    Thread 160:
    Thread 161:: com.apple.appkit-heartbeat
    0   libsystem_kernel.dylib            0x00007fff8f9a3e42 __semwait_signal + 10
    1   libsystem_c.dylib                 0x00007fff8f8a4dea nanosleep + 164
    2   libsystem_c.dylib                 0x00007fff8f8a4bb5 usleep + 53
    3   com.apple.AppKit                  0x00007fff9141311b -[NSUIHeartBeat _heartBeatThread:] + 1727
    4   com.apple.Foundation              0x00007fff858ef72a -[NSThread main] + 68
    5   com.apple.Foundation              0x00007fff858ef6a2 __NSThread__main__ + 1575
    Thread 0 crashed with X86 Thread State (64-bit):
      rax: 0x700000001cc12974  rbx: 0x0000000100976d84  rcx: 0x0000000000000000  rdx: 0x0000000000000000
      rdi: 0x00000001cc9a0fb8  rsi: 0x00007fff5fbfafd0  rbp: 0x00007fff5fbfaee0  rsp: 0x00007fff5fbfae20
       r8: 0x0000000000000000   r9: 0x0000000108ce1370  r10: 0x0000000108ce1370  r11: 0x00000001c6cd3dc8
      r12: 0x00000001cc9a0fb8  r13: 0x00007fff5fbfae80  r14: 0x00007fff5fbfaf90  r15: 0x00000001141e0948
      rip: 0x0000000100976db5  rfl: 0x0000000000010202  cr2: 0x000000011e07d000
    Logical CPU: 6
    Binary Images:
           0x100000000 -        0x1013fdff7 +com.avid.mediacomposer (7.0.2.1776 - 7.0.2) <3605EB93-7FE1-93DA-B805-97895592C855> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/AvidMediaComposer
           0x101bfe000 -        0x101ecaff7 +QtCore (4.8.3 - compatibility 4.8.0) <8FD5CEC8-DB12-DE0D-D235-EA30346FBE90> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/QtCore.framework/Versions/4/QtCore
           0x101f68000 -        0x10294bfef +QtGui (4.8.3 - compatibility 4.8.0) <5CA536AA-D8DF-0459-275B-C56D923852A4> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/QtGui.framework/Versions/4/QtGui
           0x102bfc000 -        0x102c39fff +QtXml (4.8.3 - compatibility 4.8.0) <A1B585F7-A657-CAEC-1C54-FF23A3E0EED5> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/QtXml.framework/Versions/4/QtXml
           0x102c53000 -        0x10312fff7 +QtDesigner (4.8.3 - compatibility 4.8.0) <568E5BA4-0CC1-1ADA-75A6-AB3DC1326B49> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/QtDesigner.framework/Versions/4/QtDesigner
           0x103267000 -        0x10329eff7 +QtSql (4.8.3 - compatibility 4.8.0) <12B5E344-B719-48F4-7835-B6309FCB946B> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/QtSql.framework/Versions/4/QtSql
           0x1032b5000 -        0x1033f5fff +QtNetwork (4.8.3 - compatibility 4.8.0) <524FCAD8-4F2D-AB49-EB49-52589723756F> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/QtNetwork.framework/Versions/4/QtNetwork
           0x103459000 -        0x103908fe7 +QtXmlPatterns (4.8.3 - compatibility 4.8.0) <E879FB3D-C971-E394-5D4F-AF2C7096EA17> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/QtXmlPatterns.framework/Versions/4/QtXmlPatterns
           0x103a8c000 -        0x103ad2ff7 +phonon (4.4.0 - compatibility 4.4.0) <CCC39E00-B49A-D2D6-D239-4DB8EB6CE34F> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/phonon.framework/Versions/4/phonon
           0x103af9000 -        0x1051fbfef +QtWebKit (4.9.3 - compatibility 4.9.0) <B12CDD00-97BE-3625-74CE-4EF1483BBDD2> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/QtWebKit.framework/Versions/4/QtWebKit
           0x1061b5000 -        0x1062c5fe7 +libicuucAvid.dylib (42.1.0 - compatibility 42.0.0) <6CAF5115-6C58-3139-AED4-144AA6798532> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libicuucAvid.dylib
           0x10630d000 -        0x106470fef +libicui18nAvid.dylib (42.1.0 - compatibility 42.0.0) <848EA0AE-EAB1-33C0-9791-EEB51B2BAD35> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libicui18nAvid.dylib
           0x1064fd000 -        0x106505fff +libicuioAvid.dylib (42.1.0 - compatibility 42.0.0) <1C37BB8F-9559-3385-9954-1ED97A26E97E> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libicuioAvid.dylib
           0x10650b000 -        0x10744ffff +libicudataAvid.dylib (42.1.0 - compatibility 42.0.0) <228F67F7-1739-34B9-B871-1253B38A0FA5> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libicudataAvid.dylib
           0x107451000 -        0x1074bcfff +com.avid.DMF (1.0 - 1) <C8F2BF27-2F96-DF1E-786F-FFAF208C866E> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/DMF.framework/Versions/A/DMF
           0x1074f0000 -        0x10833bfe7 +com.avid.UIShellQt (1.0 - 1.0) <6999E752-C6C6-96FC-4328-2A6C14E9D0F0> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/UIShellQt.framework/Versions/A/UIShellQt
           0x108493000 -        0x108498fff +com.avid.backgroundqueue (1.0 - 1) <70B0872D-8485-E76D-5721-7C0C16D87597> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/BackgroundQueue.framework/Versions/A/BackgroundQueue
           0x1084a5000 -        0x108637fff +libAed.dylib (??? - ???) <7A1FB93E-BC4D-E2E3-751C-0CE27D639AF8> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libAed.dylib
           0x10886c000 -        0x108882ff7 +libAut.dylib (??? - ???) <37A5BB92-9EF5-E2BC-ED9E-FEA564FAB0D8> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libAut.dylib
           0x10889b000 -        0x108cd1ff7 +com.avid.AvidCore (5.12.0 - 5.12.0) <1F62A0A9-399C-E63C-B172-78079A1CC4FD> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/AvidCore.framework/Versions/A/AvidCore
           0x108edc000 -        0x108f04fff +com.avid.AvidCoreServices (5.12.0 - 5.12.0) <616615D2-E5BF-262E-05B5-8D9178727E8A> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/AvidCoreServices.framework/Versions/A/AvidCoreServices
           0x108f21000 -        0x108f42fff +com.avid.AvidCoreThreads (5.12.0 - 5.12.0) <EB584A28-C502-29D4-7F25-D94DBC0A2CB8> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/AvidCoreThreads.framework/Versions/A/AvidCoreThreads
           0x108f58000 -        0x108f5dfff +com.avid.AvidCoreUtils (5.12.0 - 5.12.0) <07450DDF-1D01-A31E-5E18-A5116DE40587> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/AvidCoreUtils.framework/Versions/A/AvidCoreUtils
           0x108f63000 -        0x108f94ff7 +AvidDigitalIO (??? - ???) <2877C3E8-7F36-2732-14BF-779BD4EBE046> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/AvidDigitalIO.framework/Versions/A/AvidDigitalIO
           0x108fc6000 -        0x109583ff7 +libQualityMgmt.dylib (??? - ???) <B5EB0ADC-38B4-7F80-20A1-DF69F11D0E06> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libQualityMgmt.dylib
           0x109c68000 -        0x109c9ffff +libACME.dylib (??? - ???) <357BEAB9-27A7-FDD5-A018-046429EAE22E> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libACME.dylib
           0x109cb3000 -        0x109d71fff +Ami (??? - ???) <BC7433B1-6C4F-92CC-5FE2-69E9B6FD43B0> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/Ami.framework/Versions/A/Ami
           0x109df4000 -        0x109f6efe7 +libAuiCore.dylib (??? - ???) <F2953357-463F-1933-94AB-C340F46A35BD> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libAuiCore.dylib
           0x10a110000 -        0x10a1a5ff7 +libMvCore.dylib (??? - ???) <D151C1DE-86F8-3E42-42B8-AB9EC57827E5> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libMvCore.dylib
           0x10a288000 -        0x10a299ff7 +RPE (??? - ???) <8C8C15D9-4BA0-96B2-6B31-32BC8187B111> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/RPE.framework/Versions/A/RPE
           0x10a2a7000 -        0x10a3bdfff +libAMI_Mob.dylib (??? - ???) <B679204E-5152-D057-A723-52C87E359233> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libAMI_Mob.dylib
           0x10a50a000 -        0x10a577ff7 +libLegacyVideoEffects.dylib (??? - ???) <3D0CA40C-098C-4708-7BD6-67F471DD2F0C> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libLegacyVideoEffects.dylib
           0x10a5a5000 -        0x10a66ffef +libClassicEffects.dylib (??? - ???) <AB80A6EF-4E2C-1498-E1C4-B6FB684079B3> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libClassicEffects.dylib
           0x10a6de000 -        0x10a6ecff7 +AVX2PluginHost.dylib (??? - ???) <390071B1-3C87-8274-A152-C656F12014FA> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/AVX2PluginHost.dylib
           0x10a6f7000 -        0x10aa7fff7 +libUIShell.dylib (??? - ???) <A369E0A2-5759-E890-C647-7FFC48DF8ACB> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libUIShell.dylib
           0x10ac9d000 -        0x10aceeff7  com.apple.audio.midi.CoreMIDI (1.8 - 42) <7E503A06-6C65-3D08-B4B8-6B606EFA6ABF> /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI
           0x10ad14000 -        0x10bdfefff +libameLibrary.dylib (??? - ???) <55419E50-415A-1BC9-0C35-3950B94E9B1A> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libameLibrary.dylib
           0x10c6a3000 -        0x10c970fff +libameImportExport.dylib (??? - ???) <4305DB2E-15F1-33ED-81ED-550442BE14F8> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libameImportExport.dylib
           0x10cae5000 -        0x10caeefff +libDynViewUIShell.dylib (??? - ???) <D4B37DE6-60B7-E7D9-D2A9-2FCA0C5EA432> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libDynViewUIShell.dylib
           0x10cb02000 -        0x10cb23fff +com.avid.VDM.HWcommon (1.0 - 1.0) <A294F222-5CB6-539E-60C4-7E4EBC6C3039> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/HWcommon.framework/Versions/A/HWcommon
           0x10cb3a000 -        0x10cb57ff7 +libameQuickTime.dylib (??? - ???) <B65AC5EF-C8D8-1571-4734-8873F752E4E1> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libameQuickTime.dylib
           0x10cb7f000 -        0x10cbbdfe7 +libADMCommon.dylib (??? - ???) <81434DE2-6ED2-2E4D-C58E-0B197FE44D7B> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libADMCommon.dylib
           0x10cbda000 -        0x10cc70fef +libADMDevices.dylib (??? - ???) <EB2E3799-F48B-25E6-5C44-22AD83856906> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libADMDevices.dylib
           0x10ccb2000 -        0x10cccaff7 +AVXLibrary.dylib (??? - ???) <C6634DCC-9FB9-5805-A9A4-F10D3C52AE6C> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/AVXLibrary.dylib
           0x10ccde000 -        0x10cd52fff +com.avid.LavaFlow (5.12.0 - 5.12.0) <73A01C41-66E8-6910-116B-15BCA4A99482> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/lavaFlow.framework/Versions/A/lavaFlow
           0x10ce11000 -        0x10ce18ff7 +libMultiTouchSurfaceControl.dylib (??? - ???) <6C312D82-4FD7-2595-B1B1-28E95D51DF8A> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libMultiTouchSurfaceControl.dylib
           0x10ce21000 -        0x10ce27ff7 +libConfigClient.dylib (??? - ???) <4C15D595-D9BC-56D5-D78F-159205A8F1F7> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libConfigClient.dylib
           0x10ce38000 -        0x10ce73fff +libHiip_Library.dylib (??? - ???) <531A3628-6550-DB8F-AC0F-3A5CC01DB217> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libHiip_Library.dylib
           0x10ce85000 -        0x10d0e9fef +libMesa.dylib (6.3.0 - compatibility 6.0.0) <23A645B7-5584-F5B1-A0AC-4A19E3B48B02> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libMesa.dylib
           0x10d16a000 -        0x10df27fe7 +il.dylib (6.0.0 - compatibility 6.0.0) <D1E67535-D1F8-DEE9-D4A9-20080EB16018> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/il.dylib
           0x10e468000 -        0x10e47afff +mt.dylib (6.0.0 - compatibility 6.0.0) <988EB358-FACA-693B-ECE9-A12E380C7A22> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/mt.dylib
           0x10e48e000 -        0x10e491fff +libDigiDAEBridge.dylib (??? - ???) <F4799C89-E596-EA41-A9E9-251FEEC05066> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libDigiDAEBridge.dylib
           0x10e499000 -        0x10e86ffff +ml.dylib (6.0.0 - compatibility 6.0.0) <2D68F662-41E3-0473-9848-16254C94F377> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/ml.dylib
           0x10e9a3000 -        0x10e9b3fff +libAMAUtilLib20.dylib (??? - ???) <C47E79E9-B0C4-24C5-6421-FD170D497D65> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libAMAUtilLib20.dylib
           0x10e9bf000 -        0x10e9ccff7 +libjpegV4.dylib (??? - ???) <489DD444-3BFD-A329-A0EE-23831E01C7E4> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libjpegV4.dylib
           0x10e9d1000 -        0x10eabffef +com.avid.AvidSwrtFx (5.12.0 - 5.12.0) <E806DC8A-871F-8DE4-CF20-16A56F96B085> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/AvidSwrtFx.framework/Versions/A/AvidSwrtFx
           0x10eb0c000 -        0x10ec7afe7 +libAeu.dylib (??? - ???) <1B171657-8714-8742-A35D-311C4E805DFE> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libAeu.dylib
           0x10ee24000 -        0x10f54afff +com.avid.Mac2Qt (1.0 - 1.0) <EBACBFF6-0E77-D280-F2D1-961293959815> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/Mac2Qt.framework/Versions/A/Mac2Qt
           0x10f5ac000 -        0x10f5efff7 +libameWaveformEngine.dylib (??? - ???) <1B55A9BD-FEE4-0E25-1CC9-BED77DB38601> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libameWaveformEngine.dylib
           0x10f61b000 -        0x10f622ff7 +com.avid.TaskScheduler (5.0.0.0 - 5.0.0.0) <6DB0CB5A-5F85-8B9F-3C46-3F6ECF1727E8> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/TaskScheduler.framework/Versions/A/TaskScheduler
           0x10f630000 -        0x10f851fef +libDMSClientLib.dylib (??? - ???) <96938352-1FBE-CB5F-EA84-756AA3D217ED> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libDMSClientLib.dylib
           0x10f972000 -        0x10f972ff7 +com.avid.AvidBSMClient (1.0.1 - 1) <D34E3F3F-C993-6BC8-7EC1-E1594228AD1D> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/AvidBSMClient.framework/Versions/A/AvidBSMClient
           0x10f975000 -        0x10f9dbffd +com.SafeNet.SuperPro (SuperPro version 6.6.0 - 6.6.0) /Library/Frameworks/SuperPro.framework/Versions/A/SuperPro
           0x10f9ef000 -        0x10fc48fff +QtScript (4.8.3 - compatibility 4.8.0) <1AD035D2-4384-20C5-6B26-2461A55C55BB> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/QtScript.framework/Versions/4/QtScript
           0x10fd03000 -        0x10fde6fe7 +QtOpenGL (4.8.3 - compatibility 4.8.0) <628EAB72-D457-C219-EBD5-7D39325CC666> /Library/Frameworks/QtOpenGL.framework/QtOpenGL
           0x10fe30000 -        0x10fe36fff  com.apple.agl (3.2.0 - AGL-3.2.0) <4A404DD3-5542-3D5D-A9B6-5068139A0218> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
           0x10fe3d000 -        0x10fe84fef +com.avid.AvidMPEG2Parser (5.12.0 - 5.12.0) <2CE0B087-0C67-3EAB-FB87-C17FA4D10FFE> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/AvidMPEG2Parser.framework/Versions/A/AvidMPEG2Parser
           0x10feb8000 -        0x10fee5ff7 +libtbb.dylib (??? - ???) <6CDA994C-3EC9-3575-B409-2BA57079E456> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libtbb.dylib
           0x10fefc000 -        0x10ff0eff7 +libtbbmalloc.dylib (??? - ???) <9ABF3780-8CD6-E1D8-238B-C82AB7889A42> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libtbbmalloc.dylib
           0x10ff22000 -        0x10ff22fff  libmx.A.dylib (2026.0.0 - compatibility 1.0.0) <C23BF0A1-7E6D-35EF-85FE-651EE2C13D53> /usr/lib/libmx.A.dylib
           0x10ff25000 -        0x10ff41ff7 +com.avid.AvidStorageAPI (5.12.0 - 5.12.0) <6D2E0D6B-A5F3-934E-B715-E3B1D7774E55> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/AvidStorageAPI.framework/Versions/A/AvidStorageAPI
           0x10ff58000 -        0x11010dfe7 +gk.dylib (6.0.0 - compatibility 6.0.0) <F4782ABC-C91E-C6AA-DA04-0579C23BBD5E> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/gk.dylib
           0x110173000 -        0x110173ff7 +libMvInt.dylib (??? - ???) <2B28E1A1-DA5A-C902-D2D0-7740CE61BD12> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libMvInt.dylib
           0x110176000 -        0x1106bdfff +AmiMDK (??? - ???) <9FAE0504-7912-1EC8-9808-19E65F43B96C> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/AmiMDK.framework/Versions/A/AmiMDK
           0x110aa5000 -        0x110aa5ff7 +libEvents.dylib (??? - ???) <C93A25E3-8DE0-E4E5-2795-74AFA0ECD7D6> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libEvents.dylib
           0x110f1b000 -        0x110f1cfff +libAvidVidSatInterface.dylib (??? - ???) <31B2F2EA-26FA-FABF-F07F-3A74E5B67045> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libAvidVidSatInterface.dylib
           0x110f1f000 -        0x110f47ff7 +libAvidVideoSlave.dylib (??? - ???) <14C4A954-146F-5D00-1F1E-4A6FCA63E5E4> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libAvidVideoSlave.dylib
           0x110f5f000 -        0x110f7afff +com.digidesign.framework.TCPE (11.0.0.518 - 11.0.0d518) <28DFAC04-F56D-364B-8AE7-7E5E968E8D97> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/TCPE.framework/Versions/A/TCPE
           0x110fda000 -        0x110fdeff7 +com.avid.AMEPlatformImpl (1.0 - 1.0) <D161B567-D890-E07A-61A7-6A6CBFA26C70> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/AMEPlatformImpl.bundle/Contents/MacOS/AMEPlatformImpl
           0x110fe5000 -        0x110fe7fff  com.apple.textencoding.unicode (2.4 - 2.4) <FD4695F4-6110-36C6-AC06-86453E30FF6E> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
           0x112722000 -        0x112732fe6 +com.avid.ACFString ( version 1.0 - 1.0) /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/ACFString.avx/Contents/MacOS/ACFString
           0x1140a5000 -        0x1140d9fff  com.apple.security.csparser (3.0 - 55148.6) <CAA9817C-3D70-369D-894D-AA8034EEF2DD> /System/Library/Frameworks/Security.framework/PlugIns/csparser.bundle/Contents/MacOS/csparser
           0x1140f0000 -        0x1140f0ff3 +cl_kernels (??? - ???) <E48045FC-3AEA-4F35-915C-E3931E841261> cl_kernels
           0x115e78000 -        0x115e82fff +com.avid.VDM.bridge (4.6.4 - 4.6.4) <4437B551-C6A3-6002-6A87-ABC84F859BE0> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/AvidVDM.acf/Contents/MacOS/AvidVDM
           0x115e8a000 -        0x115e8efff +com.avid.HWcommon_ACF (1.0 - 1.0) <FAB7428A-7523-8C8C-EC28-1EC77F6880C3> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/HWcommon_ACF.acf/Contents/MacOS/HWcommon_ACF
           0x115e9d000 -        0x115e9ffff  com.apple.ExceptionHandling (1.5 - 10) <26885447-EB5B-3241-8AE5-10AEEB036789> /System/Library/Frameworks/ExceptionHandling.framework/Versions/A/ExceptionHandling
           0x1167c0000 -        0x1167c6ff7 +libqgif.dylib (??? - ???) <DA38A60F-C02E-22DF-BC09-2D6337BF9EA0> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/imageformats/libqgif.dylib
           0x11a000000 -        0x11a03bff7 +libqjpeg.dylib (??? - ???) <23CA4ACF-286A-AA13-70A5-943AFFEB1D63> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/imageformats/libqjpeg.dylib
           0x11d006000 -        0x11d016fff +DSM_ClientLib (9.0.2 - compatibility 9.0.2) <36CA4F36-36FF-635F-7B21-5A3989ED09B3> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/DSM/DSM_ClientLib.framework/Versions/A/DSM_ClientLib
           0x11d780000 -        0x11d784ff7 +com.avid.AMALogger (3.0.0d2720 - ???) <85DCC909-E33E-24AD-07DF-029187427282> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/AMA/AMALogger.avx/Contents/MacOS/AMALogger
           0x11d789000 -        0x11d793fff +com.avid.AMADeviceMonitor (3.0.0d2720 - 3.0.0) <4DAB3F4E-26CD-A734-5CD7-9E1C75C6E88C> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/AMA/AMADeviceMonitor.avx/Contents/MacOS/AMADeviceMonitor
           0x11d7a1000 -        0x11d7affff  libGPUSupport.dylib (??? - ???) <9FF8DDA2-7CB1-3888-8AAE-227C7691CB98> /System/Library/PrivateFrameworks/GPUSupport.framework/Versions/A/Libraries/libGPUSupport.dylib
           0x11d7b7000 -        0x11d7e5ff7  GLRendererFloat (??? - ???) <06CA5D0B-BC5F-3CC7-836D-A02F7DB92BE8> /System/Library/Frameworks/OpenGL.framework/Resources/GLRendererFloat.bundle/GLRendererFloat
           0x11d7ee000 -        0x11d7f8fef  libcldcpuengine.dylib (2.0.19 - compatibility 1.0.0) <4572AD1E-D1D1-3412-AFCC-D37037B1FAB5> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/libcldcpuengine.dylib
           0x11e000000 -        0x11e004fff  com.apple.audio.AudioIPCPlugIn (1.2.3 - 1.2.3) <F94D690D-3196-3B01-B798-09708367D28D> /System/Library/Extensions/AudioIPCDriver.kext/Contents/Resources/AudioIPCPlugIn.bundle/Contents/MacOS/AudioIPCPlugIn
           0x11e009000 -        0x11e00efff  com.apple.audio.AppleHDAHALPlugIn (2.2.5 - 2.2.5a5) <4EC4981B-68AE-357E-960F-3D4603A61E9F> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Contents/MacOS/AppleHDAHALPlugIn
           0x11e013000 -        0x11e016ff7 +com.avid.DynViewLoader (1.0 - 1.0) <056600CE-BB8D-E506-B844-90AC41DEDBE8> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/DynViewLoader.acf/Contents/MacOS/DynViewLoader
           0x11e200000 -        0x11e2c2ff7 +com.avid.amfPlayer ( version 1.0 - 1.0) <98FBA748-ADCE-1DE9-E96E-724148E21ED6> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/amfPlayer.avx/Contents/MacOS/amfPlayer
           0x11e365000 -        0x11e377ff7 +com.avid.MSP-Sphere (1.1.1d6135 - 1.0) <804A15D1-98C7-04C6-44C6-5188B31C0DB6> /Library/Application Support/Avid/*/MSP_Sphere
           0x11e38c000 -        0x11e394ff7 +com.avid.DynViewEngineQt4 (1.0 - 1.0) <837CE494-69EB-0A8A-6569-A13795B874C0> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/DynViewEngineQt4.acf/Contents/MacOS/DynViewEngineQt4
           0x11e429000 -        0x11e5e1fff  GLEngine (??? - ???) <59179FEC-D0E2-38B3-BD49-765506A645AC> /System/Library/Frameworks/OpenGL.framework/Resources/GLEngine.bundle/GLEngine
           0x11e618000 -        0x11e772fff  libGLProgrammability.dylib (??? - ???) <90390984-70BC-365C-AB3E-16C35C4240CB> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
           0x11e7a4000 -        0x11e7a7ff7  libCoreFSCache.dylib (??? - ???) <0D155750-7910-32C5-8327-924FC1089442> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
           0x11e7ec000 -        0x11e7f7ff7 +libMXF_SDK_GenericContainer_MPEG_ESAudio.dylib.4.4.23 (4.4.23 - compatibility 4.4.23) /Library/Application Support/Avid/*/libMXF_SDK_GenericContainer_MPEG_ESAudio.dylib.4.4.23
           0x11e982000 -        0x11e98cff7 +libMXF_SDK_GenericContainer_AES3.dylib.4.4.23 (4.4.23 - compatibility 4.4.23) /Library/Application Support/Avid/*/libMXF_SDK_GenericContainer_AES3.dylib.4.4.23
           0x11e995000 -        0x11e99afff +libMXF_SDK_Metadata_AS11.dylib.1.3.29 (1.3.29 - compatibility 1.3.29) /Library/Application Support/Avid/*/libMXF_SDK_Metadata_AS11.dylib.1.3.29
           0x11ea62000 -        0x11eb65fff  com.apple.diopyromaniacohci (5.12.0 - 5.12.0) <8D5764A6-7DDE-5112-D7F1-04A3B7512052> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/DIOPyromaniacOHCI_v001_MC.bundle/Contents/MacOS/DIOPyromaniacOHCI_v001_MC
           0x11ecae000 -        0x11ecbdfff +libMXF_SDK_GenericContainer_JPEG2000.dylib.4.4.23 (4.4.23 - compatibility 4.4.23) /Library/Application Support/Avid/*/libMXF_SDK_GenericContainer_JPEG2000.dylib.4.4.23
           0x122337000 -        0x1223daff7 +com.Avid.HWSDK (1.0 - 1) <13436D1F-9B7E-09A5-5972-A863B7C07CA4> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/HWSDK.acf/Contents/MacOS/HWSDK
           0x1228f1000 -        0x12292cff7  com.apple.carbonbundletemplate (1.0 - 1.0) <00362D41-F34D-338F-0333-A8025B7C8F63> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/AMPIPluginDSM.avx/Contents/MacOS/AMPIPluginDSM
           0x1229d7000 -        0x122a50fe7 +acpl_main.acf (??? - ???) <847EBE2F-37F1-B821-D4DF-01153344AF5C> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/acpl_main.acf/Contents/MacOS/acpl_main.acf
           0x122ada000 -        0x122adeff7 +libAvidDataInterchange.dylib (??? - ???) <F095AC24-8826-1997-5822-05519066D7A0> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libAvidDataInterchange.dylib
           0x122b13000 -        0x122b36ff7 +acpl_convert.acf (??? - ???) <B9CE1DB3-F267-8DB9-BDF0-85BB8319E441> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/acpl_convert.acf/Contents/MacOS/acpl_convert.acf
           0x122b71000 -        0x122bc8fff +com.avid.macflamethrowerohci (5.12.0 - 5.12.0) <B9E41A62-1939-7C71-C584-AB327A491E72> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/MacFlamethrowerOHCI_MC.bundle/Contents/MacOS/MacFlamethrowerOHCI_MC
           0x122c34000 -        0x122c67fff  com.apple.AVCVideoServices (1.0 - 42) <AF3D72EF-4DA9-E884-50FF-26366EEB1257> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/AVCVideoServices.framework/Versions/A/AVCVideoServices
           0x122fed000 -        0x122ff5fff +com.avid.RestClient (1.0 - 1.0) <6C968527-F6AD-301D-BFFB-709AD4D7F8B1> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/RestClient.acf/Contents/MacOS/RestClient
           0x123800000 -        0x123c75fff  com.apple.driver.AppleIntelHD4000GraphicsGLDriver (7.32.12 - 7.3.2) <D7812529-7A02-347B-AD5F-1CB458B9337C> /System/Library/Extensions/AppleIntelHD4000GraphicsGLDriver.bundle/Contents/MacOS/AppleIntelHD4000GraphicsGLDriver
           0x123f83000 -        0x123fbeff7 +com.avid.avx2.avidhost.avx2dll.avx2 (1.0.7 - 1.0.7) <CB5C026F-28FE-51B3-9BF7-B74646A6E6E9> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/avx2.bundle/Contents/MacOS/avx2
           0x124d72000 -        0x124dd3fef +acpl_gpu.acf (??? - ???) <710B2BDC-FC62-A816-3E11-7D5830313A8E> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/acpl_gpu.acf/Contents/MacOS/acpl_gpu.acf
           0x124e40000 -        0x124f5dfe7 +ilgpu.dylib (6.0.0 - compatibility 6.0.0) <40789539-DC22-EA0D-3A60-16859100845E> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/ilgpu.dylib
           0x125100000 -        0x12511eff7 +com.avid.AMASampleProviderSupport (3.0.0d2720 - 3.0.0) <92F7B257-4E15-6835-1F2F-43FDBE13BEA5> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/AMA/AMASampleProviderSupport.avx/Contents/MacOS/AMASampleProviderSupport
           0x12518e000 -        0x1251c6fff +libMOG_Framework.dylib.2.2.11 (2.2.11 - compatibility 2.2.11) <E03C3BAC-6B0C-E23F-7E71-0B4380E31E8E> /Library/Application Support/Avid/*/libMOG_Framework.dylib.2.2.11
           0x125400000 -        0x125412fff +libMXF_SDK_GenericContainer_Wave.dylib.4.4.23 (4.4.23 - compatibility 4.4.23) /Library/Application Support/Avid/*/libMXF_SDK_GenericContainer_Wave.dylib.4.4.23
           0x125422000 -        0x125456ff0 +libMXF_SDK_GenericContainer_MPEG_AVC.dylib.1.3.29 (1.3.29 - compatibility 1.3.29) /Library/Application Support/Avid/*/libMXF_SDK_GenericContainer_MPEG_AVC.dylib.1.3.29
           0x125472000 -        0x125483fff +libMXF_SDK_GenericContainer_MPEG_MPEG2Video.dylib.4.4.23 (4.4.23 - compatibility 4.4.23) /Library/Application Support/Avid/*/libMXF_SDK_GenericContainer_MPEG_MPEG2Video.dylib.4.4.23
           0x125490000 -        0x1254a1fff +libMXF_SDK_GenericContainer_VC3.dylib.1.3.29 (1.3.29 - compatibility 1.3.29) /Library/Application Support/Avid/*/libMXF_SDK_GenericContainer_VC3.dylib.1.3.29
           0x1254ad000 -        0x1254beff7 +libMXF_SDK_MetaMetadata_BinaryLoader.dylib.4.4.23 (4.4.23 - compatibility 4.4.23) /Library/Application Support/Avid/*/libMXF_SDK_MetaMetadata_BinaryLoader.dylib.4.4.23
           0x125700000 -        0x12579efef +com.avid.MSP-AS11 (1.0 - 1.0) <33AE42B9-3555-6313-C7B5-CC36C695F16A> /Library/Application Support/Avid/*/MSP_AS11
           0x1258ad000 -        0x1258f6fff  com.apple.uncompressed (1.0.0 - 1.0.0) <C3DB103F-B37C-6AE7-DC0B-08FD9A66446F> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/Codecs/CMAvidUncompressedCodec.avx/Contents/MacOS/CMAvidUncompressedCodec
           0x125925000 -        0x12595fffb +libMXF_SDK_MXFIO_AS11.dylib.1.3.29 (1.3.29 - compatibility 1.3.29) /Library/Application Support/Avid/*/libMXF_SDK_MXFIO_AS11.dylib.1.3.29
           0x125e00000 -        0x125ffbff7 +libMXF_SDK.dylib.4.4.23 (4.4.23 - compatibility 4.4.23) /Library/Application Support/Avid/*/libMXF_SDK.dylib.4.4.23
           0x12618b000 -        0x12649bfff +libcom-api.dylib (??? - ???) <F6873844-2280-345E-3AD7-994B89E7CDCA> /Library/Application Support/Avid/libcom-api.dylib
           0x12677d000 -        0x126dc9fef +libMXF_SDK_XMLUtils.dylib.4.4.23 (4.4.23 - compatibility 4.4.23) /Library/Application Support/Avid/*/libMXF_SDK_XMLUtils.dylib.4.4.23
           0x1271d1000 -        0x1275a6fef +libxqilla.5.0.0.dylib (6.0.0 - compatibility 6.0.0) /Library/Application Support/Avid/*/libxqilla.5.0.0.dylib
           0x12786d000 -        0x127b39ff6 +libxerces-c-3.0.dylib (??? - ???) /Library/Application Support/Avid/*/libxerces-c-3.0.dylib
           0x127e83000 -        0x128a6dfef +com.newblue.StarterPack.mac.library (1.0 - 1.0) <D3DE9F95-B558-9B66-F8D9-DA7957D4FD6F> /Library/Application Support/NewBlue/*/StarterPackMac.bundle/Contents/MacOS/StarterPackMac
           0x129372000 -        0x129427fef +acpl_cpu.acf (??? - ???) <816C8BEA-29AD-F70D-5616-3B6F3737FF57> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/acpl_cpu.acf/Contents/MacOS/acpl_cpu.acf
           0x12a027000 -        0x12c8e2fe7 +XcoreKit (1.3.0.6367424 - 1.3.0.6367424) <C093F419-9141-3F28-B1CC-96CC4158DCD0> /Library/Application Support/Avid/*/XcoreKit.framework/Versions/A/XcoreKit
           0x130a0c000 -        0x130a49fff +acpl_processing.acf (??? - ???) <E8EAE5B1-22B7-7EBE-EE39-3D985798B886> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/acpl_processing.acf/Contents/MacOS/acpl_processing.acf
           0x131800000 -        0x131903ff7 +com.avid.AcplEffects (1.0 - 1.0) <EF178580-4FC4-22E0-389E-33A5B720B033> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/AcplEffects.avx/Contents/MacOS/AcplEffects
           0x1335ca000 -        0x1336bfff7 +com.avid.MCEffects (1.0 - 1.0) <EDF01D82-F8BB-0422-8BEA-04A04456C703> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/MCEffects.avx/Contents/MacOS/MCEffects
           0x1349c5000 -        0x1349e1fff +com.avid.amf_Search (1.0 - 1) <40257995-4EE7-8D09-6E00-77E3011E83D8> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/amf_Search.acf/Contents/MacOS/amf_Search
           0x135683000 -        0x1356f9ff7 +com.avid.MSP-AVCHD (1.3.1d6135 - 1.0) <2FC827E7-64DB-7267-9E0B-B1B0B47D025E> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/AMA/MSP_AVCHD.avx/Contents/MacOS/MSP_AVCHD
           0x1bed69000 -        0x1bedb2fef +com.avid.MVP-AVCHD (1.3.1d6135 - 1.0) <C8C5DE21-A5CA-AC78-E244-A559120CBD4E> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/AMA/MVP_AVCHD.avx/Contents/MacOS/MVP_AVCHD
           0x1bef00000 -        0x1bef66fff +com.avid.avxplugin.tsparser (1.0 - 1.0) <43015514-19EA-7BC4-6CE3-970C0F599B3A> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/Codecs/TSParser.acf/Contents/MacOS/TSParser
           0x1bf006000 -        0x1bf082fff +com.avid.MVP-MSP-Quicktime (1.3.1d6135 - 1.3.1) <8B89D1B0-6084-1799-D2D5-E01D5ED506DF> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/AMA/MVP_MSP_Quicktime.avx/Contents/MacOS/MVP_MSP_Quicktime
           0x1bf10f000 -        0x1bf16dfff +com.avid.MSP-MXF (1.10.0d6135 - 1.0) <F782811E-0B67-924F-7D42-70B0E25E9950> /Library/Application Support/Avid/*/MSP_MXF
           0x1bf400000 -        0x1bf48bff7 +com.avid.MSP-WaveAiff (version 1.0 - 1.0) <4E70A8A5-135C-0B1E-67C6-44FAA96C61DF> /Library/Application Support/Avid/*/MSP_WaveAiff
           0x1bf4e8000 -        0x1bf5b5fff +com.avid.MVP-MSP-AS02 (1.2.1d6135 - 1.0) <5E4DE5E4-1CB2-B5D5-A726-12C7E4314B50> /Library/Application Support/Avid/*/MVP_MSP_AS02
           0x1bf900000 -        0x1bfa37ff7  com.apple.CodecsManager (1.0.0 - 1.0.0) <C44AC163-0E7A-8903-5B5C-8AD1EBC50B85> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/Codecs/CodecManager.avx/Contents/MacOS/CodecManager
           0x1bfa6e000 -        0x1bfb08fff +com.avid.codecs.10packed (1.0.0 - 1.0.0) <5114C5C4-2E67-AC1E-8C32-99B12B9CD3E0> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/Codecs/CMAvid10PackerCodec.avx/Contents/MacOS/CMAvid10PackerCodec
           0x1bfb41000 -        0x1bfe0efff +com.avid.codecs.dv100 (1.0.0 - 1.0.0) <FFAE1176-A7FF-490F-E196-17FD57504613> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/Codecs/CMAvidDV100Codec.avx/Contents/MacOS/CMAvidDV100Codec
           0x1bfe92000 -        0x1bff05ff7 +com.avid.codecs.rgbpacker (1.0.0 - 1.0.0) <5EC83C01-E042-FF56-CB85-7EF8DFC3331B> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/Codecs/CMAvidRGBPacker.avx/Contents/MacOS/CMAvidRGBPacker
           0x1c003e000 -        0x1c004dfff +com.digidesign.framework.digitrace (11.0.0.518 - 11.0.0d518) <78F81EAF-CB6C-37AD-9DB2-CC472ED31312> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/Digitrace.framework/Versions/A/Digitrace
           0x1c0203000 -        0x1c0790fdf +com.yourcompany.CMAvidAVCIntraCodec (1.0 - 1) <DF6159EC-AE1A-DD36-D0C2-846DFA8BB97F> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/Codecs/CMAvidAVCIntraCodec.avx/Contents/MacOS/CMAvidAVCIntraCodec
           0x1c0987000 -        0x1c09d1fff +com.avid.searchsupport (1.0 - 1) <B71FE266-004E-36FE-42B8-0B5A9D9305B8> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/SearchSupport.framework/Versions/A/SearchSupport
           0x1c0bb3000 -        0x1c0bd1ff7 +com.avid.TE_Client (1.0 - 1.0) <2347F6E9-3A06-AABE-19D4-47025D7F7378> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/TE_Client.acf/Contents/MacOS/TE_Client
           0x1c0fb6000 -        0x1c12f2fff +com.avid.codecs.dv (1.0.0 - 1.0.0) <261EDBAB-5B1B-B91D-F9D6-70C9AC777913> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/Codecs/CMAvidDVCodec.avx/Contents/MacOS/CMAvidDVCodec
           0x1c1391000 -        0x1c1682ff7 +com.avid.avxplugin.CMAvidHDCodec (1.0.0 - 1.0.0) <352E6F90-409F-3849-FC48-F223F2701CA4> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/Codecs/CMAvidHDCodec.avx/Contents/MacOS/CMAvidHDCodec
           0x1c1b45000 -        0x1c24f6fe7  com.apple.carbonframeworktemplate (1.0.0 - 1.0.0) <E210117E-7821-0BDC-5C19-A9CDBA499DCE> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/Codecs/CMAvidH264IBPCodecD2.avx/Contents/MacOS/CMAvidH264IBPCodecD2
           0x1c25c4000 -        0x1c29ccff7 +com.yourcompany.CMAvidJ2KCodec (1.0 - 1) <64EE5B9A-3BF4-47CB-A334-612071F55D0A> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/Codecs/CMAvidJ2KCodec.avx/Contents/MacOS/CMAvidJ2KCodec
           0x1c2ac1000 -        0x1c2b1afe7 +com.avid.SearchUIPlugin (1.0 - 1) <B80E9E04-0715-D691-B2F4-33CD92087256> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/SearchUIPlugin.acf/Contents/MacOS/SearchUIPlugin
           0x1c2b46000 -        0x1c2e1afff +com.avid.codecs.jpeg (1.0.0 - 1.0.0) <ADA6F83A-0D02-9E81-D1DD-4E553A7F0848> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/Codecs/CMAvidJPEGCodec.avx/Contents/MacOS/CMAvidJPEGCodec
           0x1c2e91000 -        0x1c316cff7 +com.avid.codecs.MPEG2EncoderBridge (1.0.0 - 1.0.0) <89755470-A144-16C3-D923-FE14A7168837> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/Codecs/CMAvidMPEG2EncoderBridge.avx/Contents/MacOS/CMAvidMPEG2EncoderBridge
           0x1c31e7000 -        0x1c34edff7 +com.avid.codecs.mpeg2 (1.0.0 - 1.0.0) <3C56F792-C4CD-50C4-42D7-814BC03ABE48> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/Codecs/CMAvidMPEG2IBPCodec.avx/Contents/MacOS/CMAvidMPEG2IBPCodec
           0x1c3576000 -        0x1c3852fef +com.avid.codecs.mpeg2iframe (1.0.0 - 1.0.0) <502F032C-FA12-7B04-A38D-DD97546BF167> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/Codecs/CMAvidMPEG2IFrameCodec.avx/Contents/MacOS/CMAvidMPEG2IFrameCodec
           0x1c38dc000 -        0x1c3bb2fef +com.avid.codecs.mpeg2imx (1.0.0 - 1.0.0) <14F65D3D-711F-A0DB-AB19-62DB4743D2E0> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/Codecs/CMAvidMPEG2IMXCodec.avx/Contents/MacOS/CMAvidMPEG2IMXCodec
           0x1c3c3e000 -        0x1c3fd9fe7 +com.avid.codecs.mpeg4 (1.0.0 - 1.0.0) <5781B666-FDDC-5D95-D62F-01A1FD0E88B9> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/Codecs/CMAvidMPEG4Codec.avx/Contents/MacOS/CMAvidMPEG4Codec
           0x1c4063000 -        0x1c4376fe7 +com.avid.codecs.ProResCodec (1.0.0 - 1.0.0) <E9A14DE4-0F23-6327-2A47-CDCA6426D7D0> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/Codecs/CMAvidProResCodec.avx/Contents/MacOS/CMAvidProResCodec
           0x1c4432000 -        0x1c46eefff +com.avid.codecs.rle (1.0.0 - 1.0.0) <78A2058F-E7FE-E678-0E57-FDA9F87493B7> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/Codecs/CMAvidRLECodec.avx/Contents/MacOS/CMAvidRLECodec
           0x1c4750000 -        0x1c4a34ff7 +com.avid.codecs.vc1decoder (1.0.0 - 1.0.0) <15A6D90D-6597-143E-5A3F-4722FC0F4304> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/Codecs/CMAvidVC1Decoder.avx/Contents/MacOS/CMAvidVC1Decoder
           0x1c9500000 -        0x1c9a2cfe7 +com.avid.PhoneticIndex (1.0 - 1.0) <10C5E9DB-2082-781C-DE58-97324C27101F> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/PhoneticIndex.avx/Contents/MacOS/PhoneticIndex
           0x1c9c52000 -        0x1c9d39ff7 +com.avid.searchdb (1.0 - 1) <12AE74C2-EF40-FA70-8165-CB9605581D03> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/AvidSearchDB.framework/Versions/A/AvidSearchDB
           0x1cb9fe000 -        0x1cbbe0fff +com.avid.XMLPlugin (3.0.0d2720 - ???) <25468A74-D402-F40B-E9A8-7AE5B90ADDDD> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/AMA/XMLPlugin.avx/Contents/MacOS/XMLPlugin
           0x1cd73d000 -        0x1cd7e8fff  com.apple.AudioCodecManager (1.0.0 - 1.0.0) <7CA8916E-B4E0-248D-B172-4E4C27B58ECF> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/Codecs/AudioCodecManager.avx/Contents/MacOS/AudioCodecManager
           0x1cd806000 -        0x1cd866fe7 +com.avid.AC3Codec (1.0.0 - 1.0.0) <8DE5A656-E2F5-F7D3-7FF8-B194DCBA36A3> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/Codecs/CMAvidAC3Codec.avx/Contents/MacOS/CMAvidAC3Codec
           0x1cdb00000 -        0x1cdb58fef +com.avid.MPEG1Layer2 (1.0.0 - 1.0.0) <65463AB0-AD84-97B7-826E-933FFCAE6C5F> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/Codecs/CMAvidMPEG1Layer2AudioCodec.avx/Contents/MacOS/CMAvidMPEG1Layer2AudioCodec
           0x1cea26000 -        0x1cea94fff +com.digidesign.framework.SystemLink (11.0.0.518 - 11.0.0d518) <6CE5DDEB-10BD-362B-87AD-55A8EC49225B> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/SatelliteLink.framework/Versions/A/SatelliteLink
           0x1ced00000 -        0x1ced1dff7 +com.digidesign.framework.PlatformSupport (11.0.0.518 - 11.0.0d518) <BB0C0A5F-E9BF-3A8B-A621-33E8CF76A6A3> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/DigiPlatformSupport.framework/Versions/A/DigiPlatformSupport
           0x1cee4f000 -        0x1ceeedff7 +com.digidesign.framework.MoreFoundation (11.0.0.518 - 11.0.0d518) <C85D155D-515B-3ECD-BD11-DF3C4B031EFD> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/MFnd.framework/Versions/A/MFnd
           0x1d0002000 -        0x1d027ffff +com.digidesign.framework.CoreFoundation (11.0.0.518 - 11.0.0d518) <86B9AB2D-DA34-341A-BDCD-9B314BCC88EE> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/CFnd.framework/Versions/A/CFnd
           0x1d1c7c000 -        0x1d1d1bff7  unorm8_bgra.dylib (2.0.19 - compatibility 1.0.0) <47DA7D73-C52D-322F-A08F-4DB320A65373> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/ImageFormats/unorm8_bgra.dylib
           0x200000000 -        0x20082ffff  com.apple.GeForceGLDriver (7.32.12 - 7.3.2) <0361820C-7006-3AB4-91A1-D589847D8455> /System/Library/Extensions/GeForceGLDriver.bundle/Contents/MacOS/GeForceGLDriver
        0x7fff5fcbf000 -     0x7fff5fcf3baf  dyld (195.6 - ???) <0CD1B35B-A28F-32DA-B72E-452EAD609613> /usr/lib/dyld
        0x7fff85895000 -     0x7fff85baefff  com.apple.Foundation (6.7.2 - 833.25) <F6584E06-7C8F-3422-AF84-3AA58EC67935> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
        0x7fff85baf000 -     0x7fff85bb0ff7  libsystem_blocks.dylib (53.0.0 - compatibility 1.0.0) <8BCA214A-8992-34B2-A8B9-B74DEACA1869> /usr/lib/system/libsystem_blocks.dylib
        0x7fff85bb6000 -     0x7fff85c6cfff  com.apple.PDFKit (2.7.7 - 2.7.7) <96C0C88B-F049-39F1-92A5-180F1C2EE6EB> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versions/A/PDFKit
        0x7fff85c6d000 -     0x7fff85d62fff  libiconv.2.dylib (7.0.0 - compatibility 7.0.0) <5C40E880-0706-378F-B864-3C2BD922D926> /usr/lib/libiconv.2.dylib
        0x7fff85d63000 -     0x7fff85d6afff  libCGXCoreImage.A.dylib (600.0.0 - compatibility 64.0.0) <1116CD6D-E7AD-375F-A691-B9DF6609FEAD> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXCoreImage.A.dylib
        0x7fff85d6b000 -     0x7fff85d6cff7  libsystem_sandbox.dylib (??? - ???) <5459F293-E1F2-33B3-B9B2-2ABB7B915B62> /usr/lib/system/libsystem_sandbox.dylib
        0x7fff85d6d000 -     0x7fff85d82fff  com.apple.speech.synthesis.framework (4.0.74 - 4.0.74) <FCFE889E-4832-3F1F-B4A2-2E933F645500> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
        0x7fff86226000 -     0x7fff86229fff  com.apple.AppleSystemInfo (1.0 - 1) <5FDAB74E-8257-3D9F-ACE1-F3A7263ABB55> /System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/A/AppleSystemInfo
        0x7fff86273000 -     0x7fff862acff7  libssl.0.9.8.dylib (49.0.0 - compatibility 0.9.8) <AE5B0BB9-75F1-34DA-A10F-63F2640210A8> /usr/lib/libssl.0.9.8.dylib
        0x7fff862ad000 -     0x7fff862bcfff  com.apple.opengl (1.8.1 - 1.8.1) <51B34133-CEE3-3FC6-82AC-ADF567AE673C> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
        0x7fff862bd000 -     0x7fff862befff  libunc.dylib (24.0.0 - compatibility 1.0.0) <0482C762-746D-37EB-A8C9-E1048CF70462> /usr/lib/system/libunc.dylib
        0x7fff862bf000 -     0x7fff86306ff7  com.apple.CoreMedia (1.0 - 705.94) <700C6863-7A8F-34FA-8B1D-7659EC95000B> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
        0x7fff86307000 -     0x7fff86319ff7  libsasl2.2.dylib (3.15.0 - compatibility 3.0.0) <6245B497-784B-355C-98EF-2DC6B45BF05C> /usr/lib/libsasl2.2.dylib
        0x7fff8631a000 -     0x7fff863feed7  libobjc.A.dylib (228.0.0 - compatibility 1.0.0) <76082BBC-446B-3355-AED5-0DBCEE600CB2> /usr/lib/libobjc.A.dylib
        0x7fff8643a000 -     0x7fff8643eff7  com.apple.CommonPanels (1.2.5 - 94) <CA9C910D-E406-33E7-B8EE-C86EAA62AB68> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
        0x7fff8643f000 -     0x7fff86440fff  liblangid.dylib (??? - ???) <CACBE3C3-2F7B-3EED-B50E-EDB73F473B77> /usr/lib/liblangid.dylib
        0x7fff8648d000 -     0x7fff8649bfff  com.apple.NetAuth (3.2 - 3.2) <9E6526E2-254F-3087-A66F-7BB9E7502D3F> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
        0x7fff8649c000 -     0x7fff867b8fff  com.apple.CoreServices.CarbonCore (960.25 - 960.25) <4FC1AB30-022C-3C67-AC46-FDCBFCB7EEDE> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
        0x7fff867b9000 -     0x7fff86824ff7  com.apple.framework.IOKit (2.0 - ???) <FE838BB6-D42E-3291-A1A0-6F53FC970261> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
        0x7fff868a8000 -     0x7fff868adfff  libcache.dylib (47.0.0 - compatibility 1.0.0) <3D114C8A-AD1F-3C78-9E8C-B8F3810740E5> /usr/lib/system/libcache.dylib
        0x7fff868ae000 -     0x7fff86b26fff  com.apple.imageKit (2.1.2 - 1.0) <23470050-28FB-3B09-8E27-ADC371B0E4B8> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Versions/A/ImageKit
        0x7fff86b27000 -     0x7fff86b2ffff  libsystem_dnssd.dylib (??? - ???) <584B321E-5159-37CD-B2E7-82E069C70AFB> /usr/lib/system/libsystem_dnssd.dylib
        0x7fff86b30000 -     0x7fff86b7efff  libauto.dylib (??? - ???) <D8AC8458-DDD0-3939-8B96-B6CED81613EF> /usr/lib/libauto.dylib
        0x7fff86b7f000 -     0x7fff86b9bfff  com.apple.ScriptingBridge (1.2.1 - ???) <3E99B861-E011-3594-A9C4-E39B7EFE2F3F> /System/Library/Frameworks/ScriptingBridge.framework/Versions/A/ScriptingBridge
        0x7fff86b9c000 -     0x7fff86bdeff7  libcommonCrypto.dylib (55010.0.0 - compatibility 1.0.0) <A5B9778E-11C3-3F61-B740-1F2114E967FB> /usr/lib/system/libcommonCrypto.dylib
        0x7fff86bdf000 -     0x7fff86ce4fff  libFontParser.dylib (??? - ???) <D2E56B6E-3182-3667-A78C-4172C435523A> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
        0x7fff86ce5000 -     0x7fff86ceaff7  libsystem_network.dylib (??? - ???) <DD7492F9-39FB-3E73-9028-3E1027D012B9> /usr/lib/system/libsystem_network.dylib
        0x7fff86ceb000 -     0x7fff86ceffff  libCGXType.A.dylib (600.0.0 - compatibility 64.0.0) <35D606B1-7AD9-38E3-A2A9-E92B904BDDE8> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXType.A.dylib
        0x7fff86cf0000 -     0x7fff86d30fe7  libGLImage.dylib (??? - ???) <0B7DAB2B-F1C6-39C7-B864-61EF683B6656> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
        0x7fff86daf000 -     0x7fff86dc3ff7  com.apple.LangAnalysis (1.7.0 - 1.7.0) <A7C58D71-6D4A-317D-AA06-D648B1F78573> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
        0x7fff86ed1000 -     0x7fff86f31fff  libvDSP.dylib (325.4.0 - compatibility 1.0.0) <1E3EEDA7-1DC6-3593-9DED-0BAFA0972A76> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
        0x7fff86f32000 -     0x7fff86f3dff7  com.apple.speech.recognition.framework (4.0.21 - 4.0.21) <6540EAF2-E3BF-3D2E-B4C1-F106180D6F20> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
        0x7fff86f3e000 -     0x7fff86f3efff  com.apple.ApplicationServices (41 - 41) <E23F1CED-C0FB-35A8-9657-484C5E6A32AE> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
        0x7fff86f3f000 -     0x7fff86f43fff  libmathCommon.A.dylib (2026.0.0 - compatibility 1.0.0) <FF83AFF7-42B2-306E-90AF-D539C51A4542> /usr/lib/system/libmathCommon.A.dylib
        0x7fff86f44000 -     0x7fff87528fff  libBLAS.dylib (??? - ???) <09028536-1215-324C-B7BD-384CF5DBC5D0> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
        0x7fff87529000 -     0x7fff875adff7  com.apple.ApplicationServices.ATS (317.12.0 - ???) <BE3C156D-8326-37AA-BC4E-D3C0D31BF976> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
        0x7fff875ae000 -     0x7fff876b5fe7  libsqlite3.dylib (9.6.0 - compatibility 9.0.0) <EE02BB01-64C9-304D-9719-A35F5CD6D04C> /usr/lib/libsqlite3.dylib
        0x7fff87726000 -     0x7fff87729fff  libRadiance.dylib (??? - ???) <CD89D70D-F177-3BAE-8A26-644EA7D5E28E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
        0x7fff8772a000 -     0x7fff8776eff7  libRIP.A.dylib (600.0.0 - compatibility 64.0.0) <B2A38D2C-7E82-34C5-8896-48C37B0E64A3> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
        0x7fff87777000 -     0x7fff8783eff7  ColorSyncDeprecated.dylib (4.6.0 - compatibility 1.0.0) <3ED589D2-77C3-3E99-B6E9-49CE4C70EB8C> /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ColorSync.framework/Versions/A/Resources/ColorSyncDeprecated.dylib
        0x7fff8784e000 -     0x7fff87850ff7  com.apple.print.framework.Print (7.4 - 247.3) <626C58D5-2841-3329-8C32-9F4A8353F3E7> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
        0x7fff87de6000 -     0x7fff87e13fe7  libSystem.B.dylib (159.1.0 - compatibility 1.0.0) <85A55D2C-6C94-381B-9DE8-6ECFD8152A62> /usr/lib/libSystem.B.dylib
        0x7fff87e14000 -     0x7fff87e16fff  com.apple.TrustEvaluationAgent (2.0 - 1) <3087AE86-B57F-3D39-9885-C93DC6FD5163> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
        0x7fff87e43000 -     0x7fff87f0aff7  com.apple.ColorSync (4.7.4 - 4.7.4) <F00820E4-7753-3F41-8D3D-95CD6F174886> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
        0x7fff87f0b000 -     0x7fff87f12fff  com.apple.NetFS (4.0 - 4.0) <B9B9D9C8-2E5E-3C34-84D7-D0AB61EDC8B9> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
        0x7fff87f13000 -     0x7fff87f19ff7  com.apple.phonenumbers (1.0 - 47) <8CE13253-C65B-392F-B87F-D85A15D500D3> /System/Library/PrivateFrameworks/PhoneNumbers.framework/Versions/A/PhoneNumbers
        0x7fff87f1a000 -     0x7fff87f25ff7  com.apple.DisplayServicesFW (2.5.4 - 323.3) <99274440-6289-325B-9CFC-DDD808F73D59> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices
        0x7fff87f26000 -     0x7fff87f26fff  com.apple.audio.units.AudioUnit (1.7.3 - 1.7.3) <04C10813-CCE5-3333-8C72-E8E35E417B3B> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
        0x7fff87f27000 -     0x7fff87fc8fff  com.apple.LaunchServices (480.40 - 480.40) <C936A07F-0CF8-3F8E-BDB3-76AA7611B4CA> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
        0x7fff87fd3000 -     0x7fff88013fff  libtidy.A.dylib (??? - ???) <E500CDB9-C010-3B1A-B995-774EE64F39BE> /usr/lib/libtidy.A.dylib
        0x7fff88014000 -     0x7fff8819eff7  com.apple.WebKit (7534.57 - 7534.57.7) <15AA1A2E-DCAC-35CE-89DF-0FF7149198CD> /System/Library/Frameworks/WebKit.framework/Versions/A/WebKit
        0x7fff8850d000 -     0x7fff88518ff7  libc++abi.dylib (14.0.0 - compatibility 1.0.0) <8FF3D766-D678-36F6-84AC-423C878E6D14> /usr/lib/libc++abi.dylib
        0x7fff88519000 -     0x7fff8856bff7  libGLU.dylib (??? - ???) <DB906997-0F70-3469-BA0E-2F1DDBEAD8D5> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
        0x7fff8856c000 -     0x7fff8856cfff  com.apple.Accelerate (1.7 - Accelerate 1.7) <A42ACCF8-7C09-3891-B2B3-F6048A650BA2> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
        0x7fff8856d000 -     0x7fff8856dfff  com.apple.quartzframework (1.5 - 1.5) <A7A2DBBA-BFFC-35C0-A927-CC0BA4C851E7> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
        0x7fff8856e000 -     0x7fff88863ff7  com.apple.security (7.0 - 55148.6) <4535E500-973A-3BA7-AF65-DF5CF0658F02> /System/Library/Frameworks/Security.framework/Versions/A/Security
        0x7fff88932000 -     0x7fff88a16ff7  com.apple.CoreServices.OSServices (478.50 - 478.50) <3D6AA4EF-C601-36C7-8F3A-A00964F01759> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
        0x7fff88a55000 -     0x7fff88a62fff  libCSync.A.dylib (600.0.0 - compatibility 64.0.0) <72C53E7B-C222-3BE5-9984-FDC328CC4846> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCSync.A.dylib
        0x7fff88a63000 -     0x7fff88a96ff7  com.apple.GSS (2.2 - 2.0) <971395D0-B9D0-3FDE-B23F-6F9D0A2FB95F> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
        0x7fff88a97000 -     0x7fff88ad1fe7  com.apple.DebugSymbols (2.1 - 87) <ED2B177C-4146-3715-91DF-D99A8ED5449A> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
        0x7fff88ad2000 -     0x7fff88ad8ff7  libunwind.dylib (30.0.0 - compatibility 1.0.0) <1E9C6C8C-CBE8-3F4B-A5B5-E03E3AB53231> /usr/lib/system/libunwind.dylib
        0x7fff88b68000 -     0x7fff88b8ffff  com.apple.framework.internetaccounts (1.2 - 3) <28D44E21-54F2-366B-B9D9-1DB788EF0278> /System/Library/PrivateFrameworks/InternetAccounts.framework/Versions/A/InternetAccounts
        0x7fff88b90000 -     0x7fff88b9cfff  com.apple.DirectoryService.Framework (10.7 - 146) <700CE91B-3025-325B-B94C-836EB5FD5DE3> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
        0x7fff88b9d000 -     0x7fff88c97ff7  com.apple.DiskImagesFramework (10.7.4 - 331.7) <BEBA6D78-08E0-3B99-B77B-A5CBF3344834> /System/Library/PrivateFrameworks/DiskImages.framework/Versions/A/DiskImages
        0x7fff88c98000 -     0x7fff88cd7fff  com.apple.AE (527.7 - 527.7) <93AAF9E1-6315-362B-922A-10AE662CE2E8> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
        0x7fff88e45000 -     0x7fff88e5cfff  com.apple.CFOpenDirectory (10.7 - 146) <531D8930-2526-390E-B2CA-DF37931F50A6> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
        0x7fff88e5d000 -     0x7fff88e70ff7  libCRFSuite.dylib (??? - ???) <322486D1-359C-3059-BF53-D4B038621E18> /usr/lib/libCRFSuite.dylib
        0x7fff88e71000 -     0x7fff88e7ffff  com.apple.HelpData (2.1.2 - 72.2) <920AFDD2-DD33-379F-8AFF-EFEF2FBFEE85> /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpData
        0x7fff88e80000 -     0x7fff88ed8ff7  libTIFF.dylib (??? - ???) <59353B7F-EA9A-32D5-A501-283443B30C60> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
        0x7fff88ed9000 -     0x7fff88f08fff  com.apple.shortcut (2.1 - 2.1) <BE0AB36A-6911-356B-8784-D39175ACAF55> /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Shortcut
        0x7fff88f09000 -     0x7fff88f10ff7  com.apple.CommerceCore (1.0 - 17) <95285481-4162-308B-85E9-E0A47D4F3766> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Frameworks/CommerceCore.framework/Versions/A/CommerceCore
        0x7fff88f11000 -     0x7fff88f35fff  com.apple.RemoteViewServices (1.5 - 44.2) <A0417D7F-22E9-3FD8-AC55-67654D8E93EB> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices
        0x7fff88f85000 -     0x7fff88fbafff  com.apple.securityinterface (5.0 - 55022.6) <4D6DAF8F-7873-3992-A6D6-478C7664FA39> /System/Library/Frameworks/SecurityInterface.framework/Versions/A/SecurityInterface
        0x7fff88fbb000 -     0x7fff8902efff  libstdc++.6.dylib (52.0.0 - compatibility 7.0.0) <6BDD43E4-A4B1-379E-9ED5-8C713653DFF2> /usr/lib/libstdc++.6.dylib
        0x7fff8902f000 -     0x7fff89030fff  libdnsinfo.dylib (395.11.0 - compatibility 1.0.0) <853BAAA5-270F-3FDC-B025-D448DB72E1C3> /usr/lib/system/libdnsinfo.dylib
        0x7fff890b8000 -     0x7fff890d3fff  libexpat.1.dylib (7.2.0 - compatibility 7.0.0) <DDB91E75-A2FA-331F-8069-999127AC6A9D> /usr/lib/libexpat.1.dylib
        0x7fff890d4000 -     0x7fff892d6fff  libicucore.A.dylib (46.1.0 - compatibility 1.0.0) <0176782F-9526-3905-813A-7A5676EC2C86> /usr/lib/libicucore.A.dylib
        0x7fff89490000 -     0x7fff89490fff  libOpenScriptingUtil.dylib (??? - ???) <A7847713-F410-39C0-884F-A7188A18E742> /usr/lib/libOpenScriptingUtil.dylib
        0x7fff894b1000 -     0x7fff894b4fff  com.apple.help (1.3.2 - 42) <416BA8D2-9A2F-3F07-9E6B-E1231A92AAC0> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
        0x7fff894b5000 -     0x7fff895c2fff  libJP2.dylib (??? - ???) <6AF1F5FC-34D4-3278-BEBB-0712B81890B4> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
        0x7fff895c3000 -     0x7fff89604fff  com.apple.QD (3.40.1 - ???) <13ACC7F4-B004-3370-B575-6D06447EE428> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
        0x7fff89644000 -     0x7fff8968afff  libcurl.4.dylib (7.0.0 - compatibility 7.0.0) <2C442396-1006-3765-92D2-60869D4641CE> /usr/lib/libcurl.4.dylib
        0x7fff8968b000 -     0x7fff897f2fff  com.apple.CFNetwork (520.5.1 - 520.5.1) <08F70E26-5456-3BFB-8192-00D3CE40D3C9> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
        0x7fff897f3000 -     0x7fff897fefff  com.apple.CommonAuth (2.2 - 2.0) <77E6F0D0-85B6-30B5-B99C-F57104DD2EBA> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
        0x7fff897ff000 -     0x7fff89801fff  libCVMSPluginSupport.dylib (??? - ???) <982F1ED4-3CBB-3161-8BEA-8A980C27FCC1> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib
        0x7fff89807000 -     0x7fff8980dfff  IOSurface (??? - ???) <C8E54127-0563-3E23-8217-6D0446E1B9FC> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
        0x7fff8980e000 -     0x7fff89870ff7  com.apple.Symbolication (1.3 - 91) <D6E16F96-0C71-3708-9184-5F4D39904AA3> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
        0x7fff89871000 -     0x7fff8998afff  com.apple.DesktopServices (1.6.5 - 1.6.5) <5E7DD5F4-B4DA-3F75-A14A-3494E81CFBA0> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
        0x7fff8998b000 -     0x7fff8998bfff  com.apple.CoreServices (53 - 53) <97E086D0-20B4-3BB4-BEE2-04EE5700D55B> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
        0x7fff8998c000 -     0x7fff89992fff  libmacho.dylib (800.0.0 - compatibility 1.0.0) <548BAEB6-8C4C-3B0F-AB0C-7E1C960BCAB5> /usr/lib/system/libmacho.dylib
        0x7fff899eb000 -     0x7fff8a389a27  com.apple.CoreGraphics (1.600.0 - ???) <576777EA-921B-3D94-98C3-40A9CF8EBD18> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
        0x7fff8a38a000 -     0x7fff8a851fff  FaceCoreLight (1.4.7 - compatibility 1.0.0) <BDD0E1DE-CF33-3AF8-B33B-4D1574CCC19D> /System/Library/PrivateFrameworks/FaceCoreLight.framework/Versions/A/FaceCoreLight
        0x7fff8a852000 -     0x7fff8a852fff  libkeymgr.dylib (23.0.0 - compatibility 1.0.0) <61EFED6A-A407-301E-B454-CD18314F0075> /usr/lib/system/libkeymgr.dylib
        0x7fff8a853000 -     0x7fff8a8a7fff  libFontRegistry.dylib (??? - ???) <60FF9C2C-5E44-3C49-8A08-F26101898F21> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
        0x7fff8a8aa000 -     0x7fff8a8bcff7  libbsm.0.dylib (??? - ???) <666E88F0-F8F3-3490-B688-2CF9418CB7E8> /usr/lib/libbsm.0.dylib
        0x7fff8a8bd000 -     0x7fff8b065fff  com.apple.CoreAUC (6.16.12 - 6.16.12) <EF535959-14FE-3B61-9C32-DF4C54B8F12D> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
        0x7fff8b093000 -     0x7fff8b096ff7  com.apple.securityhi (4.0 - 1) <03190CF6-037B-3C98-8692-BE76466B7CC8> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
        0x7fff8b097000 -     0x7fff8b0b6fff  libresolv.9.dylib (46.1.0 - compatibility 1.0.0) <0635C52D-DD53-3721-A488-4C6E95607A74> /usr/lib/libresolv.9.dylib
        0x7fff8b110000 -     0x7fff8b163fff  com.apple.AppleVAFramework (5.0.16 - 5.0.16) <6F9A4BCE-8B99-3144-BCF7-B4299B27F6E9> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
        0x7fff8b164000 -     0x7fff8b190ff7  com.apple.CoreServicesInternal (113.19 - 113.19) <74532B3B-EDE0-3553-9BED-F02B9CDF1FF7> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesInternal
        0x7fff8b1e8000 -     0x7fff8b1f1ff7  libsystem_notify.dylib (80.1.0 - compatibility 1.0.0) <A4D651E3-D1C6-3934-AD49-7A104FD14596> /usr/lib/system/libsystem_notify.dylib
        0x7fff8b1f2000 -     0x7fff8b268fff  com.apple.ISSupport (1.9.8 - 56) <E7ED107A-1EFD-3720-A4B4-C0E2DDFA6C81> /System/Library/PrivateFrameworks/ISSupport.framework/Versions/A/ISSupport
        0x7fff8b269000 -     0x7fff8b2b5ff7  com.apple.SystemConfiguration (1.11.3 - 1.11) <73976D69-E672-36C9-8231-52BC782AECC7> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
        0x7fff8b2b6000 -     0x7fff8b3b7fff  com.apple.QuickLookUIFramework (3.2 - 500.18) <56A13D40-9A61-3B98-85ED-B1C7075A88FB> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/Versions/A/QuickLookUI
        0x7fff8b3b8000 -     0x7fff8b3bffff  libGFXShared.dylib (??? - ???) <D3598924-B167-372E-8C9F-1BBF68852542> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
        0x7fff8b3c0000 -     0x7fff8b3e4fff  com.apple.Kerberos (1.0 - 1) <5A114BAB-19C7-30B1-B9FB-F40019499734> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
        0x7fff8b3e5000 -     0x7fff8b3e6fff  libDiagnosticMessagesClient.dylib (??? - ???) <3DCF577B-F126-302B-BCE2-4DB9A95B8598> /usr/lib/libDiagnosticMessagesClient.dylib
        0x7fff8b3f5000 -     0x7fff8b422fff  com.apple.quartzfilters (1.7.0 - 1.7.0) <9CC87BAA-A056-3C1E-BEBD-D956A89CF5EF> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework/Versions/A/QuartzFilters
        0x7fff8b572000 -     0x7fff8b573ff7  libremovefile.dylib (21.1.0 - compatibility 1.0.0) <8901B7EE-6CA0-31F3-BBFE-BB71C90B1E49> /usr/lib/system/libremovefile.dylib
        0x7fff8b574000 -     0x7fff8b5a4ff7  com.apple.DictionaryServices (1.2.1 - 158.3) <5E2EBBFD-D520-3379-A431-11DAA844B8D6> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
        0x7fff8b5a5000 -     0x7fff8b5aafff  com.apple.OpenDirectory (10.7 - 146) <8B473C22-2E46-3818-8D57-4C1ADBCCD0A7> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
        0x7fff8b8f5000 -     0x7fff8b8f9fff  libdyld.dylib (195.6.0 - compatibility 1.0.0) <FFC59565-64BD-3B37-90A4-E2C3A422CFC1> /usr/lib/system/libdyld.dylib
        0x7fff8b8fa000 -     0x7fff8b9fcfff  libxml2.2.dylib (10.3.0 - compatibility 10.0.0) <AFBB22B7-07AE-3F2E-B88C-70BEEBFB8A86> /usr/lib/libxml2.2.dylib
        0x7fff8b9fd000 -     0x7fff8ba41ff7  com.apple.MediaKit (12 - 602) <D69EDB2E-3432-3E54-966E-35AFD049135C> /System/Library/PrivateFrameworks/MediaKit.framework/Versions/A/MediaKit
        0x7fff8ba42000 -     0x7fff8ba48fff  com.apple.DiskArbitration (2.4.1 - 2.4.1) <2FCC53F0-36A2-3B8C-ACB6-927A24155D49> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
        0x7fff8ba49000 -     0x7fff8bb28fff  com.apple.ImageIO.framework (3.1.2 - 3.1.2) <047DFE61-500F-3F11-9881-D0844D2FCE5F> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/ImageIO
        0x7fff8bb29000 -     0x7fff8bb54ff7  libxslt.1.dylib (3.24.0 - compatibility 3.0.0) <E71220D3-8015-38EC-B97D-7FDB383C2BDC> /usr/lib/libxslt.1.dylib
        0x7fff8bb55000 -     0x7fff8be77fff  com.apple.JavaScriptCore (7534.57 - 7534.57.3) <3A04B8FC-CFA6-3AEB-8FDF-B0525B5A4C82> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
        0x7fff8be78000 -     0x7fff8be99fff  libPng.dylib (??? - ???) <E2B52527-4D0C-3595-BB13-8E8EF364E998> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
        0x7fff8be9a000 -     0x7fff8c2b8ff7  com.apple.SceneKit (125.3 - 125.8) <23382F45-D9CE-3897-B998-5B26337608FD> /System/Library/PrivateFrameworks/SceneKit.framework/Versions/A/SceneKit
        0x7fff8c2b9000 -     0x7fff8c2b9fff  com.apple.Carbon (153 - 153) <AF0F9910-E3C3-3922-AA92-A39000655E0F> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
        0x7fff8c2ba000 -     0x7fff8c316ff7  com.apple.HIServices (1.21 - ???) <B012EE97-D1CD-3F4B-812D-9AC7E6852FE6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
        0x7fff8c356000 -     0x7fff8c373fff  libxpc.dylib (77.19.0 - compatibility 1.0.0) <9F57891B-D7EF-3050-BEDD-21E7C6668248> /usr/lib/system/libxpc.dylib
        0x7fff8c374000 -     0x7fff8c3dcff7  com.apple.coreui (1.2.2 - 165.11) <9316266A-39CA-3EC7-9C9E-726462CEFF4D> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
        0x7fff8c3dd000 -     0x7fff8c607fe7  com.apple.CoreData (104.1 - 358.14) <1C100A86-EEDF-352E-8BC0-DFE82FF92362> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
        0x7fff8c608000 -     0x7fff8c631fff  libJPEG.dylib (??? - ???) <64D079F9-256A-323B-A837-84628B172F21> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
        0x7fff8c632000 -     0x7fff8c632fff  com.apple.Cocoa (6.6 - ???) <9E3D4787-A2CE-38E0-BEF8-E5DA63B6E6A1> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
        0x7fff8c640000 -     0x7fff8c6b6ff7  libc++.1.dylib (28.4.0 - compatibility 1.0.0) <A24FC3DA-4FFA-3DD2-9DCC-2B8D1B3BF97C> /usr/lib/libc++.1.dylib
        0x7fff8c6df000 -     0x7fff8c7bdfff  com.apple.DiscRecording (6.0.4 - 6040.4.1) <E6D5835F-EE3C-3814-A2EE-6962B5570EF1> /System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRecording
        0x7fff8c7be000 -     0x7fff8c850ff7  com.apple.CorePDF (3.1 - 3.1) <B5B5215F-38C0-364D-BDA4-35D674FFCEC4> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePDF
        0x7fff8c8b8000 -     0x7fff8c933ff7  com.apple.print.framework.PrintCore (7.1 - 366.3) <51681D6E-62D3-3B7D-9981-D3FC3568BAB6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
        0x7fff8c934000 -     0x7fff8cd61fff  libLAPACK.dylib (??? - ???) <C7456566-4B04-3971-8D62-DE0DEBE811B7> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
        0x7fff8cd62000 -     0x7fff8ce04fff  com.apple.securityfoundation (5.0 - 55116) <1E062087-A9B1-3E38-8133-E9D282EA34B0> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
        0x7fff8ce05000 -     0x7fff8ce9bff7  libvMisc.dylib (325.4.0 - compatibility 1.0.0) <C06C0706-3462-3F24-A8BE-4DA8076DE59F> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
        0x7fff8ce9c000 -     0x7fff8d03cff7  com.apple.QuartzCore (1.7 - 270.5) <19E5E0AB-DAA9-3F97-988C-D9A46AFB9C04> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
        0x7fff8d03d000 -     0x7fff8d13aff7  com.apple.avfoundation (2.0 - 180.50) <A2EAE4E6-4DBA-3AAB-A387-7E72B93B6DA9> /System/Library/Frameworks/AVFoundation.framework/Versions/A/AVFoundation
        0x7fff8d13b000 -     0x7fff8d148ff7  libbz2.1.0.dylib (1.0.5 - compatibility 1.0.0) <3373D310-3B10-3DD1-B754-B7B138CD448D> /usr/lib/libbz2.1.0.dylib
        0x7fff8d152000 -     0x7fff8d1ecff7  com.apple.SearchKit (1.4.0 - 1.4.0) <C5585E08-76A0-34E0-B92C-22BA9D3E083C> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
        0x7fff8d1ed000 -     0x7fff8d2a0ff7  com.apple.CoreText (220.22.0 - ???) <A7A1096F-A211-3775-BA33-08FE98D27F08> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.framework/Versions/A/CoreText
        0x7fff8d2a1000 -     0x7fff8d42cff7  com.apple.QTKit (7.7.1 - 2345) <02D33483-2F88-352B-8E1E-C9CF2A2B0752> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
        0x7fff8d42d000 -     0x7fff8d759fff  com.apple.HIToolbox (1.9 - ???) <CCB32DEA-D0CA-35D1-8019-E599C8007AB6> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
        0x7fff8d75a000 -     0x7fff8d765ff7  com.apple.bsd.ServiceManagement (2.0 - 2.0) <D836A22C-BBDC-3C9F-83D3-F8CC0EE75885> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
        0x7fff8d766000 -     0x7fff8d7a1fff  com.apple.LDAPFramework (3.2 - 120.2) <275D4298-C435-3E98-AA25-95D9D0A56550> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
        0x7fff8d7a2000 -     0x7fff8d7a2fff  com.apple.Accelerate.vecLib (3.7 - vecLib 3.7) <4F7416F1-A069-3A39-B5F1-008279F6B819> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
        0x7fff8d7a3000 -     0x7fff8d7e3ff7  libcups.2.dylib (2.9.0 - compatibility 2.0.0) <7D2E5016-A960-3ADE-B042-F74063E79550> /usr/lib/libcups.2.dylib
        0x7fff8d7e4000 -     0x7fff8d801ff7  com.apple.openscripting (1.3.3 - ???) <F5E34F54-CE85-334B-8F25-53581D43960C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
        0x7fff8d802000 -     0x7fff8d828fff  com.apple.framework.familycontrols (3.0 - 300) <6F0C58C0-22E7-3877-8CFA-1ED0CB3CE38B> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A/FamilyControls
        0x7fff8d829000 -     0x7fff8d83ffff  libGL.dylib (??? - ???) <A4876AE9-DDFE-3B9A-874E-09BC29D46C39> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
        0x7fff8d840000 -     0x7fff8d8e5fff  com.apple.ink.framework (10.7.5 - 113) <1AE6676D-490A-36C2-B6CC-00F93AEB31DE> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
        0x7fff8d8e6000 -     0x7fff8d9f2fef  libcrypto.0.9.8.dylib (49.0.0 - compatibility 0.9.8) <96BA2B42-4E11-33A9-84A5-31757F131A83> /usr/lib/libcrypto.0.9.8.dylib
        0x7fff8d9f6000 -     0x7fff8da0cff7  com.apple.ImageCapture (7.1.0 - 7.1.0) <1AD40E02-2126-377B-A0D2-CBB21D932558> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
        0x7fff8da0d000 -     0x7fff8da1cfff  libxar-nossl.dylib (??? - ???) <518C0791-AB8D-3E8A-BB40-D4F312704FE2> /usr/lib/libxar-nossl.dylib
        0x7fff8da33000 -     0x7fff8da41ff7  libkxld.dylib (??? - ???) <01161870-E3B3-3F87-BA4A-0AA7A081F409> /usr/lib/system/libkxld.dylib
        0x7fff8da42000 -     0x7fff8da93ff7  com.apple.CoreMediaIO (216.0 - 3199.8) <4D3FE512-E943-34E3-A7A5-2EC2E3854E28> /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/CoreMediaIO
        0x7fff8da94000 -     0x7fff8dd01ff7  com.apple.RawCamera.bundle (4.07 - 696) <CCB97D78-309C-3CD9-B499-81192069A333> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
        0x7fff8dd02000 -     0x7fff8dd6aff7  com.apple.audio.CoreAudio (4.0.3 - 4.0.3) <9987DC46-2A96-3BA0-B88B-04E573C0AD9B> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
        0x7fff8dd6b000 -     0x7fff8ddbfff7  com.apple.ScalableUserInterface (1.0 - 1) <EB468227-3203-38C9-A5BC-E28576D507CF> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks/ScalableUserInterface.framework/Versions/A/ScalableUserInterface
        0x7fff8ddc0000 -     0x7fff8ddc2fff  libquarantine.dylib (36.7.0 - compatibility 1.0.0) <8D9832F9-E4A9-38C3-B880-E5210B2353C7> /usr/lib/system/libquarantine.dylib
        0x7fff8ddc3000 -     0x7fff8deafff7  com.apple.backup.framework (1.3.5 - 1.3.5) <B25104A3-1CE5-36CA-8F26-0A2DE3F95F70> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
        0x7fff8df35000 -     0x7fff8dfb8fef  com.apple.Metadata (10.7.0 - 627.37) <B9BEB598-B6F2-3BFF-A8F3-C3C87CD076AB> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
        0x7fff8e003000 -     0x7fff8e328ff7  com.apple.AddressBook.framework (6.1.3 - 1091) <5A8BEED1-229C-3A9C-8281-581127A1B9B5> /System/Library/Frameworks/AddressBook.framework/Versions/A/AddressBook
        0x7fff8e329000 -     0x7fff8e32cfff  libCoreVMClient.dylib (??? - ???) <28CB0F3F-A202-391F-8CAC-FC9A1398A962> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
        0x7fff8e32d000 -     0x7fff8e368fff  libsystem_info.dylib (??? - ???) <35F90252-2AE1-32C5-8D34-782C614D9639> /usr/lib/system/libsystem_info.dylib
        0x7fff8e369000 -     0x7fff8e49ffff  com.apple.vImage (5.1 - 5.1) <A08B7582-67BC-3EED-813A-4833645964A7> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
        0x7fff8e4a0000 -     0x7fff8e4b2ff7  libz.1.dylib (1.2.5 - compatibility 1.0.0) <30CBEF15-4978-3DED-8629-7109880A19D4> /usr/lib/libz.1.dylib
        0x7fff8e5ce000 -     0x7fff8e842fff  com.apple.CoreImage (7.99.1 - 1.0.1) <4BB09B79-275B-364C-9466-0FF36ABB1218> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks/CoreImage.framework/Versions/A/CoreImage
        0x7fff8e843000 -     0x7fff8e8c8ff7  com.apple.Heimdal (2.2 - 2.0) <A9FC8FF4-8D02-3D91-B409-AF19B72AEFDE> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
        0x7fff8e8c9000 -     0x7fff8e8cefff  libpam.2.dylib (3.0.0 - compatibility 3.0.0) <D952F17B-200A-3A23-B9B2-7C1F7AC19189> /usr/lib/libpam.2.dylib
        0x7fff8e8e6000 -     0x7fff8e8f0ff7  liblaunch.dylib (392.39.0 - compatibility 1.0.0) <8C235D13-2928-30E5-9E12-2CC3D6324AE2> /usr/lib/system/liblaunch.dylib
        0x7fff8ea34000 -     0x7fff8ea50ff7  com.apple.GenerationalStorage (1.0 - 126.1) <509F52ED-E54B-3FEF-B3C2-759387B826E6> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalStorage
        0x7fff8ea5f000 -     0x7fff8f796fff  com.apple.WebCore (7534.57 - 7534.57.7) <33FCF30A-08C5-3169-B3B0-3A9462FA1A0D> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versions/A/WebCore
        0x7fff8f797000 -     0x7fff8f7f4ff7  com.apple.QuickLookFramework (3.2 - 500.18) <C36371BF-E1F6-3DF7-83EA-CE96FCDCE4C4> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
        0x7fff8f7f5000 -     0x7fff8f865fff  com.apple.datadetectorscore (3.0 - 179.4) <4C555151-0658-3C3B-83CC-461C945B52B4> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
        0x7fff8f866000 -     0x7fff8f86bfff  libGIF.dylib (??? - ???) <58A4492D-AAE7-3B8F-8B06-62867471A3EE> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
        0x7fff8f86e000 -     0x7fff8f899fff  libpcre.0.dylib (1.1.0 - compatibility 1.0.0) <7D3CDB0A-840F-3856-8F84-B4A50E66431B> /usr/lib/libpcre.0.dylib
        0x7fff8f89a000 -     0x7fff8f89ffff  libcompiler_rt.dylib (6.0.0 - compatibility 1.0.0) <98ECD5F6-E85C-32A5-98CD-8911230CB66A> /usr/lib/system/libcompiler_rt.dylib
        0x7fff8f8a0000 -     0x7fff8f97dfef  libsystem_c.dylib (763.13.0 - compatibility 1.0.0) <535C622E-2C14-3DD4-98D0-EA181DF8D582> /usr/lib/system/libsystem_c.dylib
        0x7fff8f97e000 -     0x7fff8f98cfff  libdispatch.dylib (187.10.0 - compatibility 1.0.0) <8E03C652-922A-3399-93DE-9EA0CBFA0039> /usr/lib/system/libdispatch.dylib
        0x7fff8f98d000 -     0x7fff8f9adfff  libsystem_kernel.dylib (1699.32.7 - compatibility 1.0.0) <66C9F9BD-C7B3-30D4-B1A0-03C8A6392351> /usr/lib/system/libsystem_kernel.dylib
        0x7fff8f9ae000 -     0x7fff8fa09fff  com.apple.ImageCaptureCore (3.1.0 - 3.1.0) <9F7C4D81-5CC7-3D66-AC66-81EA9A5EAB94> /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore
        0x7fff8fa0e000 -     0x7fff8fa0efff  com.apple.vecLib (3.7 - vecLib 3.7) <F968254A-2A06-3E2A-A587-151D7A2DB55A> /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
        0x7fff8fa4e000 -     0x7fff8fa76fff  com.apple.PerformanceAnalysis (1.11 - 11) <E8A8518A-3484-375A-B582-8CE1E8FC22A6> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
        0x7fff8fa77000 -     0x7fff8feaaff7  com.apple.VideoToolbox (1.0 - 705.94) <72AD524C-0616-3C69-BA1F-8D444F97F5A2> /System/Library/PrivateFrameworks/VideoToolbox.framework/Versions/A/VideoToolbox
        0x7fff8feaf000 -     0x7fff90083ff7  com.apple.CoreFoundation (6.7.2 - 635.21) <62A3402E-A4E7-391F-AD20-1EF20236CE1B> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
        0x7fff90084000 -     0x7fff900dfff7  com.apple.opencl (2.0.19 - 2.0.19) <B05BF605-73B8-328F-A228-6FA59E1FC73A> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
        0x7fff900e0000 -     0x7fff9023dfff  com.apple.audio.toolbox.AudioToolbox (1.7.3 - 1.7.3) <5F1E4695-BC74-3ADD-8345-627BCD68201A> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
        0x7fff90daf000 -     0x7fff90e25fff  com.apple.CoreSymbolication (2.2 - 73.2) <126415E3-3A35-315B-B4B7-507CDBED0D58> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication
        0x7fff90e9b000 -     0x7fff90e9cfff  libffi.dylib (??? - ???) <DB96CC4B-0D38-3102-80AA-91DDE9AF3886> /usr/lib/libffi.dylib
        0x7fff90e9d000 -     0x7fff9110efff  com.apple.QuartzComposer (5.0 - 236.10) <F8560AEC-4E26-3A43-BE0A-B20FCB5B2E7D> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framework/Versions/A/QuartzComposer
        0x7fff9111f000 -     0x7fff91139fff  com.apple.CoreMediaAuthoring (2.0 - 891) <C7A92C52-AD9F-3CF1-86D5-C0714118935C> /System/Library/PrivateFrameworks/CoreMediaAuthoring.framework/Versions/A/CoreMediaAuthoring
        0x7fff911d6000 -     0x7fff91ddcfff  com.apple.AppKit (6.7.5 - 1138.51) <44417D02-6123-3FC3-A119-CE51BB4C3006> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
        0x7fff91ddd000 -     0x7fff91de4fff  libcopyfile.dylib (85.1.0 - compatibility 1.0.0) <65602684-33B1-32DE-802B-050CE07659AC> /usr/lib/system/libcopyfile.dylib
        0x7fff91de5000 -     0x7fff924a9fe7  libclh.dylib (4.0.3 - 4.0.3) <1A19D767-568D-396A-9C29-DB5C538E248D> /System/Library/Extensions/GeForceGLDriver.bundle/Contents/MacOS/libclh.dylib
        0x7fff924aa000 -     0x7fff924d3fff  com.apple.CoreVideo (1.7 - 70.3) <32241BA9-DCB6-3829-A0F7-EA916602659D> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
        0x7fff924d4000 -     0x7fff9287efe7  com.apple.MediaToolbox (1.0 - 705.94) <0719E69C-3275-3BD9-AD04-27DBADEB6E03> /System/Library/PrivateFrameworks/MediaToolbox.framework/Versions/A/MediaToolbox
        0x7fff9287f000 -     0x7fff92896fff  com.apple.MultitouchSupport.framework (231.4 - 231.4) <EA9DD3D2-3C5D-3D67-986C-C8AE47D4630C> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
        0x7fff92897000 -     0x7fff928b3fff  com.apple.frameworks.preferencepanes (15.0 - 15.0) <A72CED98-BB2A-3236-B2D6-2024B387DE4D> /System/Library/Frameworks/PreferencePanes.framework/Versions/A/PreferencePanes
    External Modification Summary:
      Calls made by other processes targeting this process:
        task_for_pid: 7
        thread_create: 0
        thread_set_state: 0
      Calls made by this process:
        task_for_pid: 0
        thread_create: 0
        thread_set_state: 0
      Calls made by all processes on this machine:
        task_for_pid: 11647
        thread_create: 0
        thread_set_state: 0
    VM Region Summary:
    ReadOnly portion of Libraries: Total=680.9M resident=357.7M(53%) swapped_out_or_unallocated=323.2M(47%)
    Writable regions: Total=2.7G written=2.2G(81%) resident=2.3G(86%) swapped_out=4212K(0%) unallocated=390.5M(14%)
    REGION TYPE                      VIRTUAL
    ATS (font support)                 32.0M
    ATS (font support) (reserved)         8K        reserved VM address space (unallocated)
    CG backing stores                  8216K
    CG image                            120K
    CG raster data                      120K
    CG shared images                   3448K
    CoreGraphics                         16K
    CoreImage                             4K
    CoreServices                       2312K
    IOKit                              37.3M
    MALLOC                            432.8M
    MALLOC guard page                    64K
    MALLOC_LARGE (reserved)            4300K        reserved VM address space (unallocated)
    Memory tag=240                        4K
    Memory tag=242                       12K
    Memory tag=243                        4K
    Memory tag=251                        8K
    OpenCL                                8K
    OpenGL GLSL                        1024K
    STACK GUARD                        56.6M
    Stack                             114.3M
    VM_ALLOCATE                         2.1G
    __CI_BITMAP                          80K
    __DATA                             64.5M
    __IMAGE                             528K
    __LINKEDIT                        158.7M
    __TEXT                            522.2M
    __UNICODE                           544K
    mapped file                       100.2M
    shared memory                      2380K
    TOTAL                               3.6G
    TOTAL, minus reserved VM space      3.6G
    Model: MacBookPro9,1, BootROM MBP91.00D3.B08, 4 processors, Intel Core i7, 2.6 GHz, 8 GB, SMC 2.1f170
    Graphics: NVIDIA GeForce GT 650M, NVIDIA GeForce GT 650M, PCIe, 1024 MB
    Graphics: Intel HD Graphics 4000, Intel HD Graphics 4000, Built-In, 512 MB
    Memory Module: BANK 0/DIMM0, 4 GB, DDR3, 1600 MHz, 0x80AD, 0x484D54333531533643465238432D50422020
    Memory Module: BANK 1/DIMM0, 4 GB, DDR3, 1600 MHz, 0x80AD, 0x484D54333531533643465238432D50422020
    AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0xF5), Broadcom BCM43xx 1.0 (5.106.198.19.22)
    Bluetooth: Version 4.0.8f17, 2 service, 18 devices, 1 incoming serial ports
    Network Service: Wi-Fi, AirPort, en1
    Serial ATA Device: APPLE HDD HTS547575A9E384, 750.16 GB
    Serial ATA Device: HL-DT-ST DVDRW  GS31N
    USB Device: hub_device, 0x8087  (Intel Corporation), 0x0024, 0x1a100000 / 2
    USB Device: FaceTime HD Camera (Built-in), apple_vendor_id, 0x8509, 0x1a110000 / 3
    USB Device: hub_device, 0x8087  (Intel Corporation), 0x0024, 0x1d100000 / 2
    USB Device: hub_device, 0x0424  (SMSC), 0x2513, 0x1d180000 / 3
    USB Device: BRCM20702 Hub, 0x0a5c  (Broadcom Corp.), 0x4500, 0x1d181000 / 6
    USB Device: Bluetooth USB Host Controller, apple_vendor_id, 0x821d, 0x1d181300 / 9
    USB Device: Apple Internal Keyboard / Trackpad, apple_vendor_id, 0x0252, 0x1d183000 / 5
    USB Device: IR Receiver, apple_vendor_id, 0x8242, 0x1d182000 / 4
    FireWire Device: Rugged USB3-FW, LaCie, 800mbit_speed
    Thank you for the fast response!
    Mac OSX, Version 10.7.5; Processor: 2.6 GHz Intel Core i7; Memory: 8 GB 1600 MHz DDR3; Startup Disk: Macintosh HD; Media Composer Interlay Edition 7.0... [view my complete system specs]
  • Mon, Oct 14 2013 5:23 PM In reply to
    • StephStorm
    • Joined on Mon, Oct 14 2013
    • Posts 3
    • Points 25
    Re: Recieving an error message when trying to play any of my sequences.
    I tried reinstalling PACE and I am still running into the same issue.
