Latest post Fri, Oct 18 2013 4:53 PM by Drew Layman. 3 replies.
  • Fri, Oct 18 2013 1:42 PM
    • Drew Layman
    • Joined on Thu, Oct 17 2013
    • Lousiville KY
    • Posts 9
    • Points 105
    Scaling 1080p sequence to 720p
    So some what new to Avid so forgive me if this is a very elementry question. I've come from Final Cut Pro and in FCP when i had 1080 footage and threw that into a 720 timeline it automatically scaled the footage to fit, therefore displaying the footage at only 67% of its original size. I did that partly, sometimes, so that i could do digital punch-ins and not see any pixelation/loss of quality.
    Now how does that translate into Avid? I open a new 1080p project, link to my 1080p footage, then in the FORMAT tab i switch the project to 720p to try to achive the same effect i did in FCP. When I do that I don't see any indication that my image is now being displayed at a smaller size to fit the viewer window. Is there a way to scale up the image and know when you've reached the 100% size mark of the original footage? Does this make sense?
    Thank for taking the time to read this. Would love to hear your thoughts and/or advice!
    Late 2013 Mac Pro Processor: 2.7 GHz 12-Core Intel Xeon E5 Memory: 32 GB 1867 MHz DDR3 ECC Graphics: AMD FirePro D500 3072 MB Software: OS X 10.9.2 Avid... [view my complete system specs]
  • Fri, Oct 18 2013 3:38 PM In reply to
    Re: Scaling 1080p sequence to 720p
    The size your media is being played back, is the format and raster size you shoose in the project window, even it is beign up sized or downsized.
    Since version 7 and the frame flex feature, you should see a green dot in the middle of the clip.
    Is this what you wanted to know?
    Best.
    * Avid Media Composer 2018.2 * Interplay | Production 3.8.1 * Media Central 2.10
  • Fri, Oct 18 2013 4:16 PM In reply to
    • Tom Pearson
    • Joined on Thu, Mar 1 2007
    • Los Angeles CA / Minneapolis MN
    • Posts 2,165
    • Points 23,235
    I think a better way IMHO  would be to open up a 720 proj and ama and transcode the 1080 footage into the 720 proj...
    Mac Pro 3.5 gig 6 core 64 gig ram D700 radons with ssd os drive with a 20 tb raid, Artist Mix and Artist color Artist control [view my complete system specs]
    Tom Pearson
  • Fri, Oct 18 2013 4:53 PM In reply to
    • Drew Layman
    • Lousiville KY
    • Posts 9
    • Points 105
    Tom,
    I agree. That does make sense but what would be your workflow after you transcode? When you scale up how do you know how much to scale before you go over 100 and start to loose resolution/quality?
