Latest post Thu, Oct 31 2013 7:42 AM by mjolnarn. 9 replies.
Page 1 of 1 (10 items)
  • Wed, Oct 30 2013 6:06 PM
    • juako
    • Joined on Fri, Sep 15 2006
    • Posts 59
    • Points 740
    Fast Import on Media Composer 7.0.2
    Hello.
    I´m working in Media Composer a 25p PAL Project and I´m trying to import (as Fast Import) QuickTime files (720 x 576) rendered in After Effects using Avid 1:1x codec with following setup:
    RESOLUTION: SD PALi
    COLOR IMPUT: ITU R-601
    This clips aren´t import as Fast Import in Avid.
    What´s the problem??
    In Media Creation, Import tab, Video Resolution is set as 1:1.
    Both machines have installed same Avid version codecs.
    Thanks in advance.
  • Wed, Oct 30 2013 6:37 PM In reply to
    • jef
    • Joined on Sun, Feb 26 2006
    • Maryland
    • Posts 3,334
    • Points 40,315
    Re: Fast Import on Media Composer 7.0.2
    Not sure this is the issue, but you state your project is 25p - progressive.
    You state you are creating PALi - interlace.
    That mismatch could keep Fast Import from working.  Create a PALi project and try there.
    Good luck,
    Jef
    Jef Huey
  • Wed, Oct 30 2013 7:41 PM In reply to
    • juako
    • Posts 59
    • Points 740
    Thanks Jef.
    I think this isn´t a project problem, maybe codec. From After Effects I try to render AVID 1:1x (SD PALp) QuickTime and clips results are interleaced.
    When I worked with MC 5.5.3 in 25p PAL projects the correct way was export clips from After Effects as Avid 1:1x (SD PALi)
    Thanks!
  • Wed, Oct 30 2013 7:59 PM In reply to
    • mjolnarn
    • Joined on Wed, Feb 8 2006
    • Sweden
    • Posts 13,346
    • Points 159,335
    It´s a Pal SD bug that comes and goes over versions, just switch advanced codec settings to p and you´ll get i.
    Mpeg50 should give you correct properties if you don´t really need uncompressed SD.
    Tomas
  • Wed, Oct 30 2013 8:09 PM In reply to
    • juako
    • Posts 59
    • Points 740
    Thanks mjolnarn.
    I need uncompressed SD. Clips from AE are CG renders with graphic elements.
    Any solution?
  • Wed, Oct 30 2013 8:17 PM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 159,335
    juako:
    If this is what you see, you wrote the opposite in your initial post, set the advanced codec settings to Pal i as said and you might get progressive.
    I actually thought that this bug was fixed but haven´t checked for a while, will do maybe tomorrow if you don´t confirm that this is the current ( 7.02 ) situation
    Tomas
  • Wed, Oct 30 2013 8:40 PM In reply to
    • juako
    • Posts 59
    • Points 740
    Yes mjolnarm.
    I try Pal p only to check if maybe bug was solved in 7.0.2 version.
    From AE correct exports needs to use opposite settings; "i" for progressive clips an "p" for interleaced clips.
    Sorry for my english.
  • Thu, Oct 31 2013 12:58 AM In reply to
    If your AE renders are 1:1x, but you're selecting 1:1 as your import resolution, that might be the issue.  It's been awhile since I've worked in SD, but I thought 1:1x was an HD codec?
  • Thu, Oct 31 2013 1:17 AM In reply to
    • jwrl
    • Melbourne, Australia
    • Posts 8,381
    • Points 96,975
    Kenton.VanNatten:
    I would put money on it.  Avid 1:1 is an 8-bit codec, and 1:1x is a 10-bit one as I understand it.  You can't fast import a 10 bit codec as 8 bit media.
  • Thu, Oct 31 2013 7:42 AM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 159,335
    jwrl:
    Kenton.VanNatten:
    How much John ?
    avid codec specs
    Tomas
