Latest post Thu, May 15 2014 12:51 AM by Eric. 2 replies.
  • Wed, May 7 2014 9:40 PM
    • Eric
    • Joined on Wed, May 7 2014
    • Porterville, CA
    • Posts 2
    • Points 20
    Two Problems, Possibly Related: Unable to AMA Link or Drag & Drop clips into bin
    I was running Composer 5.5.2 (which worked fine) on Windows 7 until a hard drive crash forced me to upgrade my internal main drive.  As long as everything else was being installed I went ahead and upgraded to Composer 7.0.3, still on Windows 7.  Thing is, whenever I try to drag a MOV (or any) file into a project bin to work with it I get a Windows error that reads: "Avid Out of proc Quicktime App has stopped working." Additional details are:
    Problem signature:
      Problem Event Name: APPCRASH
      Application Name: QuickTime_OPServer.exe
      Application Version: 1.0.0.1325
      Application Timestamp: 527cef13
      Fault Module Name: QuickTime_Wrapper.avx
      Fault Module Version: 1.0.0.1325
      Fault Module Timestamp: 527cee98
      Exception Code: c000001d
      Exception Offset: 00040212
      OS Version: 6.1.7601.2.1.0.768.3
      Locale ID: 1033
      Additional Information 1: 0a9e
      Additional Information 2: 0a9e372d3b4ad19135b953a78882e789
      Additional Information 3: 0a9e
      Additional Information 4: 0a9e372d3b4ad19135b953a78882e789
    AVID additionally states "Exception: A serious error has occured" and tells me to re-start the application "immediately".
    I am also unable to AMA link anything in the bin.  There are no Windows errors involved, but AVID states:
    "You may need to download & install the AMA plug-in from the Avid AMA website."
    It provides a link (http://www.avid.com/US/products/Avid-Media-Access/), but among all the downloadable plug-ins, Quicktime (nor AVI, another SD format I was using) isn't available.
    The phrase "Avid Out of proc Quicktime App has stopped working" does not appear in the knowledge base.  Any ideas?  I haven't been able to use my AVID software in months, instead I have been downgrading my footage into less capable programs, that edit fine but at lower resolution--which is of course maddening.
    AMD Phenom II X4 945 Processor 3.00 Ghz 8 GB Memory Dual Display: ATI Radeon HD 4200 ATI Radeon HD 5450 [view my complete system specs]
  • Mon, May 12 2014 12:55 PM In reply to
    • jakeheat
    • Joined on Sun, Sep 3 2006
    • Posts 491
    • Points 5,905
    Re: Two Problems, Possibly Related: Unable to AMA Link or Drag & Drop clips into bin
    Hi Eric
    I suspect you just need a reinstall of QuickTime. Make sure you're on the latest version of QuickTime thats compatible with Windows 7.
    http://support.apple.com/kb/DL837?viewlocale=en_US&locale=en_US
    If this doesn't help, then cross check your system with the system requirements in the MC ReadMe document.
    Good luck
    jake
    Media Composer 2018.9 MacPro 6 core - 32 GB RAM - OS:10.13.6 3.33Ghz iMacs, Macbook Pros. BM, AJA, Matrox After Effects, etc [view my complete system specs]
    @jaketheeditor
  • Thu, May 15 2014 12:51 AM In reply to
    • Eric
    • Porterville, CA
    • Posts 2
    • Points 20
    Thanks.  I tried a Quicktime reinstall but it was before another hardware upgrade so I'me going to try again.  Will keep my fingers crossed.
