Latest post Mon, Mar 14 2016 12:20 PM by Pipa. 12 replies.
Page 1 of 1 (13 items)
  • Tue, Jun 17 2014 12:23 AM
    • glachhu
    • Joined on Mon, Jun 16 2014
    • Posts 0
    • Points 0
    How do I export an Alpha Channel in AVID MEDIA COMPOSER?
    Hi All,
    I have been researching this issue for days with no success.  I need to export a subtitle track from a film to place over a color corrected version of the film.  When I import the color corrected version of the film into AVID MC, it compresses the file and the quality becomes much darker.  Also, I have a letterboxed film.  AVID MC is limited to 16:9 exports only.
    I need to get the subtitled track out of AVID to overlay on the color corrected version of the film.  Any ideas or is this impossible.  Thanks.
    Filed under: ,
  • Tue, Jun 17 2014 3:01 AM In reply to
    • smrpix
    • Joined on Wed, Sep 5 2012
    • Posts 1,354
    • Points 16,655
    Re: How do I export an Alpha Channel in AVID MEDIA COMPOSER?
    Please be clearer about what's coming in and what's going out.
    Is this a film you created in Avid?  Where is it being color corrected?  Where are the subtitle tracks coming from?  Importing into Avid should not change the color.
    The subcap generator is the normal way to get subtitles in and out of Avid -- but it is completely unclear from your description where your subtitles are being generated and whether you are trying to export subtitles only or subtitles embedded in picture.
    Also not clear what an alpha channel has to do with any of this.
  • Tue, Jun 17 2014 3:42 AM In reply to
    • glachhu
    • Posts 0
    • Points 0
    Apologies for not being clearer.
    I edited my thesis film in AVID Media Composer and created subtitles using Title tool in Avid.  I had a colorist do color correction on my film using Da Vinci.  Naturally, none of the subtitles and credits were included in the color grade.
    I now have a High Resolution Quicktime file that looks amazing.  I need to get the subtitles track from my AVID project sequence onto the color graded version of my film.  Naturally, the best thing to do is just import the color graded version of the film into AVID and add the subtitle track above it.  However, this does not appear to be the best option.  The issue with importing the high res color graded version of my film back into AVID is this:
    Avid compresses all imported files unlike FCP and Adobe Premiere.  I don't want the quality of the color graded film to be altered in AVID, so I decided to do a Final Cut Export of the new color graded version.  When I tried using AVID to export a cut of the color graded film, the quality is much much darker and I hate it.
    Also, I have a letterboxed high resolution, color graded film.  AVID only allows 16:9 aspect ration exports, nothing larger.  This is why I decided to use FCP for the final export.
    I just wish I could export the subtitles track from my AVID project sequence and bring it into FCP for the Final Export.  Somehow it exports with a black background.  I presume you need to export subtitles as an alpha channel.  Otherwise, how do I get the subtitles track exported solo and appear transparent (no black background)?
    Is this clearer?  Thanks.
  • Tue, Jun 17 2014 3:49 AM In reply to
    • jef
    • Joined on Sun, Feb 26 2006
    • Maryland
    • Posts 3,346
    • Points 40,445
    Ok, step by step questions.
    glachhu:
    What - exactly  - is the file size that you recieve from the color correction session?  And by that I mean pixel dimensions and pixel aspect ratio.
    What is the codec of this file?
    What were the levels of this color correction - Video or Data?  If you do not know the answers to these questions, the colorist should be able to help answer them.
    Jef
    Jef Huey
  • Tue, Jun 17 2014 4:04 AM In reply to
    • smrpix
    • Posts 1,354
    • Points 16,655
    glachhu:
    You can AMA link to the CC'd version and there should be no recompression and no color change.  Alternately, if the CC'd film is an Avid-native codec you can fast import with no recompression or color change.
    glachhu:
    If you do all imports/exports set to 601/709 levels, Avid will not touch the color, even if it's actually RGB.
    glachhu:
    Generally, you should use the subcap generator to make subtitles, not the title tool.  (If you do not have very many you can still cut and paste.)  Then you can export to a number of different standard subtoitle formats.
    Another option is to simply export your subs with a black background and luma key them over your movie in FCP.
    glachhu:
    It is, but you can still refine your workflow a bit.  Best of luck.
  • Wed, Jun 18 2014 4:26 AM In reply to
    • Ctjones
    • Joined on Wed, Aug 24 2011
    • Posts 53
    • Points 615
    smrpix:
    I must be doing stuff wrong then Becasue I export and import 601/709 and it looks darker all the time. Im just saying you can tell a difference after exporting
  • Wed, Jun 18 2014 6:42 AM In reply to
    • smrpix
    • Posts 1,354
    • Points 16,655
    Please answer jef's earlier question regarding regarding codec, raster size, color space and pixel aspect ratio for each step of your process -- Resolve, Aviid and FCP.
    i suspect there are discrepancies.
  • Wed, Jun 18 2014 6:50 AM In reply to
    And to be clear it's not normally the correct workflow to import into MC. Rather AMA.
    And to export there are methods to avoid QT issues.
    But as others have said we need more information on just what you have and the steps involved.
    Alternatively I'd be looking for a local Posthouse to help if it's important.
  • Fri, Jul 25 2014 4:51 PM In reply to
    • Peter Lund
    • Joined on Mon, Sep 22 2008
    • Hamburg
    • Posts 146
    • Points 1,755
    glachhu:
    Hi glachhu,
    there is no way to get the alpha channel out.
    But what you could do is export the complete Title (are they white ?) Export Quicktime Reference.
    Or if you need more Quality (Animation Codec).
    And then you could use a compositing  Software After Effects or any other App that is availeble to compose
    the title on top of the video without affecting the color of the video.
    It works perfekt if the text is white or black. With transparencies you need to experiment.
    You could even use AVID FX for this task.
    Transfer the Titles to AvidFX and import your CC.movie there.
    On the other hand there should be no color or luma shifting if you import.
    Sometimes it also depends on which monitor you are watching? Did you reference the clip on a HD Broadcast LED,LCD?
    Was everything only done on the "normal" computer monitor?
    And do you have still time , so you can ask a tutor?
    And a very good thing would be if you could provide so screenshots that show the difference.
    i hope this helps you
    ___________________________________________________________________________________________________________________ Avid MC 7.0.4 /// MacBooks pro early... [view my complete system specs]
  • Fri, Jul 25 2014 9:07 PM In reply to
    • Peter Lund
    • Hamburg
    • Posts 146
    • Points 1,755
    Hi ,
    i just tested it :
    Ich you transfer your title to AvidFX with the title matte effect, then you can "export" the titles that you did in the
    avid as "TGA" .
    You have to delete the black background in AvidFX if there is.
    Then go to file>export>moviefile or cmdM
    In the dialog select "TGA" as "Movie TYPE"
    i used "straight" as Alpha.
    press ok and then it renders.
    In After Effects just import as sequencial file (you have to tell AE that this is a movie)
    you do this in the import menu.
    And then you apply the alpha clip to the video that you got from you Color correcter.
    I think you even could do it on his machine if he has time ....
    This would be the savest thing to do.
    so it was exciting to research this. my first atempt to solve something with AvidFX
    i llike it.... its nice....
    i hope this helps you !
    peter
  • Fri, Jul 25 2014 9:20 PM In reply to
    • Posts 10,089
    • Points 216,615
    Not exactly what you are asking for, but it may give you some ideas for future jobs with subtitles
    http://avidtips.in/boris-tv-episode-152-import-manipulate-subtitles-avid-fxboris-red/
    Regards
    Douglas
  • Fri, Jul 25 2014 9:37 PM In reply to
    • Peter Lund
    • Hamburg
    • Posts 146
    • Points 1,755
    Hi Doug,
    nice one!
    very good.
    and thanxs for those excellent tutorials you do....
    from hamburg
    kind regards peter
  • Mon, Mar 14 2016 12:20 PM In reply to
    • Pipa
    • Joined on Mon, Mar 14 2016
    • Posts 2
    • Points 20
    Hi Glachhu,
    you can export your subtitle track  from AVID using alpha channel following this steps:
    Export as Quicktime Movie.
    Click on "Use marks", "Use selected tracks" and "Include Inactive audio tracks".
    Mark "Custom" and click on the button "Format Options".
    It opens a new tab of settings.
    In Video Settings you have to go to settings, and then in "Compression Type" clic on "Animation".
    After, in "Compressor" click on "Millions of colors", and 100% quality.  Click on "Accept".
    And that's it!!!
    Hope this helped you!!
    Pipa
