Latest post Thu, May 11 2017 5:46 PM by G0han. 3 replies.
  • Sat, Aug 2 2014 1:32 PM
    • joka
    • Joined on Sat, Sep 4 2010
    • Posts 39
    • Points 505
    Avid 7 - multigroup error - no timecode found- HELP!
    Hi.
    I'm trying to multigroup some subclips by Aux TC and I always get that error "No time code found for clip Exception:CM_LABEL_NOT_FOUND, tt:3. inum:3"
    All subclips have Aux TC.
    The group clips option works, but then I would have to do each subclips pair (A and B cam) one by one....a lot of subclips, not cool.
    Any suggestions would be welcome.
    Thank you Smile
    MacPro - Yosemite 10.10.5 AVID MC 8.4.4 [view my complete system specs]
  • Sat, Aug 2 2014 3:02 PM In reply to
    • kkordisch
    • Joined on Mon, Dec 5 2011
    • Posts 85
    • Points 1,085
    Re: Avid 7 - multigroup error - no timecode found- HELP!
    XAVC footage right? If you notice, the audio and video timecode for each clip don't match. Give the clips a tape name and that will fix the error.
  • Thu, Aug 7 2014 12:09 PM In reply to
    • joka
    • Posts 39
    • Points 505
    Hi, not XAVC, RED media, converted to mxf in Resolve.
    everything seems fine as I can group clips one by one, but not multigroup :/
    Thanks for the reply
  • Thu, May 11 2017 5:46 PM In reply to
    • G0han
    • Joined on Wed, Sep 26 2012
    • Posts 1
    • Points 5
    Thanks for the info! I was running into the same issue with external audio. Adding a tape name to the audio clips fixed the multigroup error for me (MC 8.5.3). I selected all the audio clips in the bin > right clicked > modify > modify clip > Set Source > type in tape name > OK > OK.
    I then had to re-do the portion of the multigroup subclips with the audio that had the tape name changed. After that it was good to go!
