Latest post Mon, Oct 27 2014 12:22 PM by arimvideo. 0 replies.
Page 1 of 1 (1 items)
  • Mon, Oct 27 2014 12:22 PM
    • arimvideo
    • Joined on Tue, Oct 14 2014
    • Posts 1
    • Points 5
    problem 8.2 and 7.xx with decklink sdi
    I'have the problem during capture mode.the error is "avid capture blackmagic no input signal present".During the  start of the capture the signal is discontinuous (black and after the image).
    Before I'work with AMC 6.5.4 and the blackmagic driver 9.9.3, but now it's don't work with the same drive.
    I have to test the other driver for the blackmagic, but the error is the same.
    my sistem is:macpro  IOS x 10.9.5.
    you have any suggestions ?
    thanks
    marco
    96 800x600 Normal 0 14 false false false IT JA X-NONE /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Tabella normale"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
    Filed under: , ,
