Latest post Wed, Dec 24 2014 4:21 AM by touviere7. 6 replies.
Page 1 of 1 (7 items)
  • Mon, Dec 22 2014 3:02 PM
    • Dan
    • Joined on Fri, Aug 12 2011
    • UK
    • Posts 231
    • Points 3,165
    Using older Boris avx effects in latest Avid
    Hi, we've recently ugraded some machines to Avid 8 using the support contract method - as this leaves us with very basic effects I've tried to put our old Boris FX on - these are Continuum Complete AVX 7 and Avid FX discs that came with MC5.5. On one machine they seem to work fine and on another they're not showing up in Avid, although they seemed to install.
    The suites are fairly similar, although one is Win7 Pro and one (the one they're not showing on) is Win8 Pro - is this something anyone has tried? They seem to install ok, you don't get any warnings, but they just don't show in Avid.
    Cheers
    Symphony 8.5.3 Windows 7 pro 64bit. Intel Core i7 2600k. 16GB RAM. Nvidia Quadro fx5500. [view my complete system specs]
    Filed under: , , ,
  • Mon, Dec 22 2014 4:06 PM In reply to
    • dmfreeman
    • Michigan
    • Posts 1,851
    • Points 24,235
    Re: Using older Boris avx effects in latest Avid
    Media Composer 8 is a 64 bit program.  The older AVX filters were 32 bit, and will not work in the newer versions of MC.  The ones that do work are the 64 bit versions.  You might want to look into Boris Red, which is the upgrade to Avid FX.  There was a discounted rate for MC users.  I believe it was at http://www.borisfx.com/press/Boris-FX-Announces-Boris-RED-5.5-for-the-Avid-Product-Family.php
    Hope this helps,
    Denny
    Media Composer 8.5.4, BCC 10.0.0074, AvidDVD 6.4.4, Boris Red 5.5.2.1382, Asus P9X79 Pro Motherboard with Intel 3930K Processor. 32 gigs DDR3 ram, Windows... [view my complete system specs]
  • Mon, Dec 22 2014 4:19 PM In reply to
    • Dan
    • UK
    • Posts 231
    • Points 3,165
    Hi Denny, thanks for responding. That was what I was confused about - the same effects work on one PC (Avid 8, Win 7 pro 64bit) but not another (also Avid 8 but win8 pro). I only tried to install them on the offchance, I didn't really expect them to work but now I don't get why they work on one machine but not the other, when they are very similar.
  • Mon, Dec 22 2014 4:39 PM In reply to
    • dmfreeman
    • Michigan
    • Posts 1,851
    • Points 24,235
    Hi Dan,
    Any of the 64 bit versions of Boris products should work with the later versions of MC.
    Denny
  • Tue, Dec 23 2014 8:14 PM In reply to
    • snedker
    • Joined on Tue, Apr 29 2008
    • Denmark , Odense
    • Posts 49
    • Points 630
    HI
    If it just would be so ....
    I´ve just upgraded my MC to 8.3 and i´m told that my Bcc8.1 (64 bit) will not work with MC 8 !
    i´ve got an email from Boris just 10 min. ago !
    Intel 980X,12 GB RAM ,Asus Sabertooth X58 ,PNY FX3800 graphic , 240GB SSD vertex2, M-Audio Profire 610 .Win7 64 bit UK , Avid MC 8.4.0-Dongle [view my complete system specs]
  • Tue, Dec 23 2014 10:32 PM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,627
    • Points 60,455
    The latest BCC 8 was working with MC 8.2 so the above statement is incorrect.
    Camera(s) PXW-X70, HDR-FX1, Hero 6 Black | MC 18.12.1 | QT 7.7.9 | Continuum 2019 | Sapphire 2019 | Mocha Pro 2019 | Titler Pro 6 | Windows 10 Pro x64... [view my complete system specs]
    Steve
    ______________________
    www.nelliedogstudios.com
  • Wed, Dec 24 2014 4:21 AM In reply to
    • touviere7
    • Joined on Mon, Mar 15 2010
    • los angeles
    • Posts 593
    • Points 6,715
    confirmation that bcc 8.2 works on mc 8.3!
    symphony 2018.12.3 - win 10 pro64 v.1803 - QT essential 7.7.9 - nVidia gtx1080 OC (419.67) - intel i7 6800k@4.1ghz water cooled by corsair H100i V2 - MSI... [view my complete system specs]
