Latest post Wed, Jan 16 2019 4:24 PM by Marianna. 8 replies.
Page 1 of 1 (9 items)
  • Tue, Dec 30 2014 1:48 AM
    • EmmanuelAE
    • Joined on Tue, Dec 30 2014
    • Posts 1
    • Points 15
    Avid Media Composer Multi Group only shows first Sub Group
    I created a multigroup based out of several Groups, but the multigroup only shows the first Group which is about 30 seconds, while the entire sequence I am trying to multigroup is 40 mins.A nyone has any ideas why this problem typically occurs?
    It should be a pretty simple multicam exercise. There are two cameras in the sequence that do not share the same timecode. And 1 external audio track.
    I followed this tutorial to create the multigroup:
    http://willblanksblog.blogspot.com/2014/05/how-to-multigroup_15.html
    Filed under: ,
  • Wed, Dec 31 2014 6:50 PM In reply to
    • Pixel Monkey
    • Posts 1,240
    • Points 15,655
    Re: Avid Media Composer Multi Group only shows first Sub Group
    Hi. Sorry no one has responded to you yet. MultiGroup is not used by everyone. I use it all the time.
    At first glance, it looks like you are doing everything correctly but I beed a little more information - what version of Media Composer? What kind of computer? Are you on local storage or shared storage? What format are the clips - 1080i59.94? What codec?
    Thanks.
    ACA Leader__Avid Pro Vid Moderator__Specs? Many. All qualified. But I still do stupid things. :) [view my complete system specs]
    Chris Bove' (Pixel Monkey)
    Twitter: Follow @heybove
    Blog for Craft Editors
    WWLD (What Would Larry Do?)
    WWND (What Would Norman Do?)
  • Wed, Jun 3 2015 10:04 PM In reply to
    Hi, I'm having this same problem as well.  It seems to be related to some of our GoPro clips. If I multigroup just the A/B cam and audio, everything looks fine.
    What's crazy is that if I set my bin display to show references, all of my subgroups and subclips show up for the multigroup, but I'm only able to access the first subgroup if I clip on the multigroup.
    It doesn't happen with every GoPro clip, but I think it's happened about 4 times so far in the last month and it's been driving me nuts.
    We're on Avid 8.3.1 (I also tried to group on 8.2 with no luck). Both Mac and PC. ISIS 5000.
    All clips have been AMA transcoded to DnX HD 45. 1080p/29.97 project.
    Any ideas?
  • Thu, Jul 30 2015 1:59 AM In reply to
    • artofwot
    • Joined on Thu, Jul 30 2015
    • Posts 1
    • Points 15
    Hey guys,
    I stumbled upon a comment on Reddit of all places (by kobfilms) that fixed the issue for me and wanted to share it:
    https://www.reddit.com/r/editors/comments/38fexs/multigroup_problem_only_able_to_access_first_group/ctdvf81
    In short, deleting LUTs/Color Adapters seems to fix it. I've run into this issue on a variety of footage - some that I've applied LUTs to, and some (GoPro) that's come in with a color adapter automatically.
    There doesn't seem to be a patttern as to how or why footage with LUTs groups fine sometimes and not others. I even ran into a group where if I grouped the cameras with the LUTs and external lavs I'd run into the issue mentioned in the first post. But then if I left the lavs out of the group - it grouped fine even with LUTs intact.
    So I'm kinda at a loss. This is a terrible, terrible bug.
  • Wed, Dec 7 2016 3:00 AM In reply to
    • Aragorn
    • Joined on Tue, Sep 20 2016
    • Los Angeles
    • Posts 9
    • Points 105
    We are having this same problem in Media Composer 8.6!  Any time we apply LUTs to footage it results in multigroups broken the way you described.  When we remove the LUTs, the broken multi groups suddenly display and work correctly.
    This is a really inconvenient bug!  The EP of our show decided to shoot all of our footage Log C and apply LUTs in post.  And, of course, now he is complaining that we had to remove them!
    Is there a way to submit this to Avid's tech team?
    Mac Pro 12-Core, D700, 64GB RAM, Avid Media Composer 2018.5, Avid NEXIS [view my complete system specs]
  • Wed, Dec 7 2016 4:09 AM In reply to
    • kkordisch
    • Joined on Mon, Dec 5 2011
    • Posts 85
    • Points 1,085
    This was supposedly fixed in 8.5.3
    • Bug Number: MCCET-572. The duration of a sequence might have been wrong if Multigroup clips in the sequence contained a LUT.
  • Mon, Feb 20 2017 2:47 AM In reply to
    So this looks like it has popped up again in 8.7.2 and 8.8  though in a slightly different form.
    Now the multigroup will be the correct length, but will only show up as one subgroup. You can even scrub in multicam mode and see all the angles but you may not be able to switch between them. The one subgroup matches your first subgroup, so if the first subgroup doesn't have the other cameras you can't select the additional cameras that pop on later.
    Once the LUTS are deleted, the the group behaves normally again.
  • Wed, Jan 16 2019 3:25 AM In reply to
    • smithek
    • Joined on Fri, Oct 12 2018
    • Posts 6
    • Points 80
    I am having this issue in 2018.12.0. Removing LUTs does not fix.
    MC 8.8.5 / OS X 10.14 / iMac Pro (2017) / 3.2 GHz 8 core Intel Xeon W / 64 GB 2666 MHz DDR4 / Radeon Pro Vega 64 16368 MB / RN using G-Drive 0G05024 with... [view my complete system specs]
  • Wed, Jan 16 2019 4:24 PM In reply to
    • Posts 10,202
    • Points 218,050
    Smithek
    You should create a case and have support look at this.
    https://www.avid.com/US/support/support-contact
