Latest post Fri, Jun 12 2015 1:16 AM by Ken Lent. 16 replies.
  • Tue, Jan 6 2015 6:42 PM
    Can't AMA-play Panasonic P2 clips on Avid MC 8.3
    Hi there,
    Happy New Year!
    I have successfully installed MC 8.3 on my Macbook Pro 15' Dual core i7 2.3 mhz, 16 gb ram laptop running 10.8 Mountain Lion.
    After upgrading almost all plugins (including switching to the latest Panasonic P2 4.3 version), when I try to AMA link any Panasonic P2 cards (pointing to the level before CONTENTS) the AMA clips appear into the bin.
    But when I double click them to open them in the player window I get the following error: EXCEPTION: CM_AEFFECT_NOT_FOUND
    The thumbnails are there but the video looks either black or striped and kind of damaged.
    Could the exception be due to my processor (a dual core as opposed as an Avid supported quad-core?) Or to the fact that I am still running Mountain Lion? Any help is greatly appreciated.
  • Tue, Jan 6 2015 7:22 PM In reply to
    • Mark Renz
    • Joined on Tue, Feb 21 2006
    • Kansas City, MO
    • Posts 1,040
    • Points 12,945
    Re: Can't AMA-play Panasonic P2 clips on Avid MC 8.3
    I can't help with your problem but can confirm 8.3. P2 plugin 4.3 and 10.8.5 all work with P2 media. I am working in a project today that is almost all P2 AMA linked.
    Much of my footage is in this folder structure: HD>FolderX>FolderY>FolderZ>CONTENTS and LASTCLIP.TXT
    Media Composer Nitris DX 2018.8 with Symphony option Win10 64Gb Ram * Media Composer 8.8 with Symphony option Nitris DX Dual 2.66GHz "Westmere"... [view my complete system specs]
  • Sat, Jan 10 2015 5:04 AM In reply to
    Thank you Mark,
    Still running on the same problem: can't AMA play Panasonic P2. Anyone else trying to solve the same problem?
    Could the problem be due to the fact that I am running OSX 10.8 (not 10.8.5), or that Panasonic hasn't upgraded its P2 plugin for MC 8.3? I suspect that because on the Panasonic website version 4.3 of the plugin is supported with MC 8.2 (no indication of MC 8.3 ...)
    Should I downgrade to Avid MC 8.2 (I hate the idea though ...)?
    Thanks in advance for your help.
    Mark Renz:
  • Sat, Jan 10 2015 5:26 AM In reply to
    • Tom Pearson
    • Joined on Thu, Mar 1 2007
    • Los Angeles CA / Minneapolis MN
    • Posts 2,165
    • Points 23,235
    I am running on 10.9.5 and and ama plugin4.3 and  P2 AMA works great
    Mac Pro 3.5 gig 6 core 64 gig ram D700 radons with ssd os drive with a 20 tb raid, Artist Mix and Artist color Artist control [view my complete system specs]
    Tom Pearson
  • Mon, Jan 12 2015 10:40 AM In reply to
    • Hudson Hawk
    • Joined on Thu, Nov 1 2007
    • Phoenix, AZ
    • Posts 14
    • Points 170
    My P2 AMA linking has been working when using 720-native DVCPProHD but I've been getting the CM_AEFFECT_NOT_FOUND error when trying to open what is technically 1080/60 footage (24P 1080 DVCProHD stuff where I typically use the motion effect editor to do the pulldown) in a 1080/23.98 project and can only open these clips in a 1080/60 project. I might have to go back to 8.2 for now, got projects to cut and these clips were working fine there.
    MC6 / OSX 10.7.5 / 2010 Mac Pro 2.8GHz Quad-Core 12GB Ram / ATI Radeon HD 5770 / Avid Artist Control / Motu HDX-SDI [view my complete system specs]
  • Wed, Feb 4 2015 5:18 PM In reply to
    • ManChicken
    • Joined on Mon, Feb 4 2008
    • Denver, CO
    • Posts 260
    • Points 3,295
    • Moderator: MetaFuze
    This just bit me yesterday trying to use footage from a client who insists on shooting 24 over 60 (and can't tell me why, but refuses to listen to me and change.)  I had to remove 8.3 and go back to 8.2.
    Lovely.
  • Fri, Feb 20 2015 2:42 PM In reply to
    • Matt Wildes
    • Joined on Wed, Jun 3 2009
    • Richmond, VA
    • Posts 21
    • Points 255
    Anyone resolve this issue yet?
    1.) HP Z800, X5650 @ 2.67GHz (x2) Xeon, W7 Pro; 18GB of RAM; Nvidia QuadroFX 3800; Symphony 6.0.1 // Nitris DX 2.) HP Z400, W3680 @ 3.33GHz, W7 Pro; 12GB... [view my complete system specs]
  • Fri, Feb 20 2015 9:50 PM In reply to
    I just ran into this, with slightly different circumstances. I have some ProRes MOVs that I linked that are 1080/29.97i. But I know these are actually 23.98 with 2:3 pulldown. So I link them, and then change the field motion to 2:3 Film. Double click and I get the CM_AEFFECT_NOT_FOUND error. Changing the field motion back to Interlaced allows them to be opened in source. I don't get it, and it looks like a bug. For those trying, try changing the Field Motion of the clip in the bin to Interlaced and see if it loads.
    Mac OS X 10.9.5, MC/Symphony v8.4.2, Nitris DX, AJA ioExpress Sony HDCAM-SR SRW-5500 Panasonic AJ-3700HD D5 etc. [view my complete system specs]
  • Thu, Mar 12 2015 7:18 PM In reply to
    • ManChicken
    • Denver, CO
    • Posts 260
    • Points 3,295
    Mark Spano:
    Interesting.  Yes it seems to be a problem with the Field Motion function, not P2 specific.  I just changed a Prores Progressive clip to "Progressive Strobe" (whatever the hell that is) and get the same error.
  • Fri, Mar 13 2015 8:00 AM In reply to
    • Richard Lowe
    • Joined on Fri, May 18 2012
    • Leeds, UK
    • Posts 6
    • Points 80
    Hi there, I don't believe MC8.3 is qualified to run on any version of Mountain Lion other than 10.8.5
    This could be your problem.
  • Fri, Mar 13 2015 4:11 PM In reply to
    • ManChicken
    • Denver, CO
    • Posts 260
    • Points 3,295
    In this case no, it's broken on Windows as well (which is what I'm actually on, I found this thread in a search) so it's an MC thing.
  • Mon, Mar 16 2015 4:11 PM In reply to
    • ManChicken
    • Denver, CO
    • Posts 260
    • Points 3,295
    And, in case you were wondering, this is still broken in 8.3.1
  • Tue, Mar 31 2015 1:10 PM In reply to
    This problem still needs to be fixed. I have P2 footage logged in a 1080/59.94 project and a project created with additional footage from a DSLR in a 1080/23.976 project. I cannot view the P2 footage from the 59.94 project in the 23.976 project. I keep getting the same error - CM_AEFFECT_NOT_FOUND. I'm guessing its a mixed frame rate issue with P2 footage. XDCam footage seems fine. I am running Avid MC 8.3.1 on OSX 10.10.2, with the P2 4.3 plugin.
    27" iMac 5k Retina 4 GHz Intel Core i7, 32GB RAM, AMD Radeon R9 M295X 4096 MB, OSX 10.10.5 Avid Media Composer 8.5.2 [view my complete system specs]
    Sean Dahlberg
    First and Last Films, LLC
    Writer/Director/Editor
  • Mon, May 11 2015 5:08 PM In reply to
    • Dom
    • Joined on Mon, May 11 2015
    • New York
    • Posts 2
    • Points 30
    Has anyone had any luck with this yet? I'm trying to AMA link 1080 footage that was shot on the "24p" setting of a Panasonic HPX-170 but getting the same exception.
    I'm running MC 8.3.1 on a 5k iMac (OS 10.10.3).
    I've also tried using the legacy P2 Import > Clips to Bin to no avail.
    The clips play fine through P2 Viewer Plus, so I know they aren't the issue.
    Finally, I tried downgrading to 8.2 yesterday, but Avid wouldn't open after that (I assume some issue with the license file), so I've now gone back to 8.3.1.
    Retina 5K iMac, 4 GHz Intel Core i7, 16 GB Ram, AMD Radeon R9 M290X [view my complete system specs]
  • Tue, May 12 2015 7:47 AM In reply to
    • hbrock
    • Santa Monica, CA
    • Posts 5,520
    • Points 64,065
      Moderator: MCA Mac
    Are you trying to play AMA footage that was recorded at a different frame rate than the project?
