Latest post Fri, Jan 9 2015 7:01 AM by mjolnarn. 6 replies.
Page 1 of 1 (7 items)
  • Thu, Jan 8 2015 1:09 PM
    • Sasquatch
    • Nottingham England
    • Posts 606
    • Points 7,205
    FX in PAL Projects MC8.3
    I have made some changes to an old PAL project and found certain effects render with a band or green or purple or a repeated part of the image at the top and or bottom of the frame, it flickers.  I swithced to HD and it renders fine.
    I have only just updated to 8.3 from 7.0.4,  I updated the grapics driver, but made no changes to the defaults, I also updated QT 7.6.6.
    Not a big issue as it has a simple work around but I would like to know if anyone else has this issue.
    System
    win7 professional 64
    HPz400
    Nvidia quadro fx3800
    HP Z420 16gb FX 1500 MC 8.4.0 Blackmagic deckink 4k extreme HP Z400 24gb FX3800 MC8.4.0 Aja express HP Z400 16gb FX3800 MC8.4.0 Blackmagic deckink 4k... [view my complete system specs]
    Mike Kruft. Nottingham, UK
  • Thu, Jan 8 2015 1:17 PM In reply to
    • mjolnarn
    • Joined on Wed, Feb 8 2006
    • Sweden
    • Posts 13,346
    • Points 159,335
    Re: FX in PAL Projects MC8.3
    Hi Mike.
    Project settings, type of effects and render codec should help, also if you are rendering automatic or have forced it to render 8 or 10 bits
    Tomas
  • Thu, Jan 8 2015 1:33 PM In reply to
    • Sasquatch
    • Posts 606
    • Points 7,205
    Mask, resize, fade to colour, I didn't check any others.
    Rendering on the fly and also rendered to disk as 1:1, automatic bit depth fx processing.  In pal I belive you can only use 601.
    I have found rendering in 16 bit solves the issue.  8 bit has issues.  Oddly automatic subsequently also renders fine.
    mjolnarn
  • Thu, Jan 8 2015 1:48 PM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 159,335
    Ok, thanks, so if 16 bits solves this just leave it this way
    Tomas
  • Thu, Jan 8 2015 5:43 PM In reply to
    • Sasquatch
    • Posts 606
    • Points 7,205
    Well it seem to fix it...  Not sure why it worked, I could not repeat the success of the initial switching between 8 and 16 bit.  Nevermind who works in PAL anyway?
  • Thu, Jan 8 2015 7:48 PM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 159,335
    Will try to find the time to open up some old 25i projects tomorrow and take a look
    Tomas
  • Fri, Jan 9 2015 7:01 AM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 159,335
    Just tested on an origin tape capture and DV 20 applying a resize and render to 1 : 1 with 8 bits render settings without seeing this so not able to reproduce here sorry
    Tomas
