Latest post Mon, Mar 14 2016 10:15 AM by David Clarke. 50 replies.
Page 1 of 4 (51 items) 1 2 3 4 Next >
  • Fri, Jan 9 2015 10:16 AM
    • David Clarke
    • Joined on Sat, Mar 13 2010
    • Brighton, Sussex, UK
    • Posts 239
    • Points 3,255
    Problems with AVCHD footage from a Panasonic GH4/GH2
    I have a Panasonic GH4 and normally film in MOV format at either HD or 4K.  A customer with a GH2 said he had problems with AVCHD footage from his GH2, so I tried the same thing with my GH4.
    You need to set he camer to film in AVCHD.  I filmed @ 1080 50i.  Record a couple of clips and then AMA link to them in Avid.  If you try and play them Avid either locks immediately or plays for a second then locks.  This happens if I AMA link to the volume or the individual files.
    Try and transcode the AMA linked files and Avid also locks.
    BTW locks = Avid freezes and the computer says Avid is not responding.  No other error message.
    If I import the clips the old fasioned way, file - import, they import and transcode fine.
    If I load the clips into other programs - I have tried EDIUS 7, Premiere and Prelude CC 2014 - they work.  It seems to be Avid related.
    AVCHD footage from other cameras - I have a Sony 3D camera, plus footage from Panasonic 151, AC90 and others - all works ok in Avid.
    My tests are using Avid MC8.3 on a PC using Windows 8.  My customer has been using MC8.0 on Windows 7.
    Anyone else had this problem?
    Laptop - Haswell desktop processor, 16GB RAM, 970m NVidia graphic card. Desktop - 2011 pin Haswell-E processor, 16GB RAM, Thunderbolt, Blackmagic UltraStudio... [view my complete system specs]
  • Fri, Jan 9 2015 11:02 AM In reply to
    • mjolnarn
    • Joined on Wed, Feb 8 2006
    • Sweden
    • Posts 13,346
    • Points 159,335
    Re: Problems with AVCHD footage from a Panasonic GH4/GH2
    Hi David, could you upload a small build for examinations
    Tomas
  • Fri, Jan 9 2015 5:55 PM In reply to
    • touviere7
    • Joined on Mon, Mar 15 2010
    • los angeles
    • Posts 589
    • Points 6,675
    i've never been able to ama link clips from a gh2 @23.976.
    720p/59.940 works ok.
    here is the console error message:
    mc 2018.12.1 with symphony - win 10 pro64 v.1803 - QT essential 7.7.9 - nVidia gtx1080 OC (411.63) - intel i7 6800k@4.1ghz water cooled by corsair H100i... [view my complete system specs]
  • Sat, Jan 10 2015 3:22 PM In reply to
    • bobpiech
    • Poland
    • Posts 105
    • Points 1,210
    Hi. Exactly the same problem like David's. It was with MC6 too. So. This is very old bug, in my mind.
    MC8.8, Win764, QTime 7.7.9, NVIDIA Driver 375.86, Asrock P67 Extreme 6, Intel 2600K, 16GB RAM, Deckink HD Extreme 3D+, NVidia Quadro K4000, M-Audio Mbox... [view my complete system specs]
  • Sun, Jan 11 2015 5:26 PM In reply to
    • TVJohn
    • Bayonne NJ
    • Posts 4,321
    • Points 53,415
    I have had problems for several years importing more than 3 AVCHD full length clips at one time, On several different machines, since MC 5.5. I have learned to import no more than 3 at one time, no problems that way.
    Using MC 8.4. Avid FX6.4, Vegas Pro 15/ DVD Architect 6pro, DVDit6.4proHD, CCE Basic, TmpGe Express4, TmpGe Authoring Works 4, DVDLab-Studio. Sony EX-1R, Canon XH-A1, GL2, GL1, Canon EOS 60D
  • Sun, Jan 11 2015 5:58 PM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 159,335
    TVJohn:
    My FS 700 cards usually contains somewhere between 100 and 200 Avchd clips.
    No probs at all to ama link.
    Tomas
  • Sun, Jan 11 2015 6:55 PM In reply to
    • touviere7
    • los angeles
    • Posts 589
    • Points 6,675
    this thread is about files from lumix gh2/gh4!!!
  • Sun, Jan 11 2015 7:07 PM In reply to
    • David Clarke
    • Posts 239
    • Points 3,255
    Thanks for the comments so far.  I can't upload any clips from the GH2 because they are from my customer.  I was going to upload some clips from the GH4 and filmed a few small ones.  Then I noticed that Windows explorer reports them as being 720x480 even though EDIUS, Premiere etc all see them as 1920x1080.  So there is something odd about them.
    I have seen lots of people with problems loading many AVCHD clips over the last few MC versions but I thought they were all solved with MC7/8 and AMA linking and trancoding.  For me, my other AVCHD camera footage (from a Sony, Panasonic AGC90, and AG151) has worked fine.  Hence asking if people had noticed something speciific with GH4 & GH2 footage in AVCHD format,
    One difference between the GH4 and my other cameras is that it is limited to recording 30 minutes.  I don't know what difference this would make to the final files, if any.
  • Sun, Jan 11 2015 8:30 PM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 159,335
    Hi David, the reason for me to ask for a sample is that there are lots of firmware hacks for those cams floating around ( will give you higher file bitrates than the origin ) and those hacks might not be supported.
    From memory 1080 25 p / 50 i should be about 21 mbps and 1080 50p around 28 mpbs
    Tomas
  • Tue, Feb 10 2015 8:33 AM In reply to
    Did any solution come out yet? If the files can't load your avid, then did you consider about transcode them?
  • Tue, Feb 10 2015 10:50 AM In reply to
    • bobpiech
    • Poland
    • Posts 105
    • Points 1,210
    Hi
    Unfortunately it is unsolved problem from many MC Avid updates. You must convert it using eg. Bigasoft Prores Converter or SUPER. Adobe convert this  AVCHD AC3 without sound.
  • Tue, Feb 10 2015 11:21 AM In reply to
    • David Clarke
    • Posts 239
    • Points 3,255
    "Adobe convert this  AVCHD AC3 without sound." do you mean that Adobe converts this footage inocrrectly as well or is that a typo?  I had no problems in Premiere.
  • Tue, Feb 10 2015 1:32 PM In reply to
    • bobpiech
    • Poland
    • Posts 105
    • Points 1,210
    Are you using Premiere CC or CS? CS series has no AC3 decoder. So, Adobe CS Encoder will not decode sound from GH2,GH3, GH4 AVCHD AC3.
  • Tue, Feb 17 2015 4:39 PM In reply to
    • Ingo Witte
    • Joined on Tue, Jan 8 2013
    • Berlin - Germany
    • Posts 10
    • Points 140
    Hi david,
    i have the same problem. my GH2 - in any firmware versions - i had the manufakturer fm and several hacks - the avid mc freeze on linking ama with footage. it seems to be a avid problem. i am realy upset with this stupid error. have to import all the footage....do you have any further solutions?
    ingo
    greetigs from berlin / germany
    Human - Homo Sapiens - Biological Selfrunning Reaktor - Brain ca.1 TB length 6.4ft - weight ca. 100kg & thinkpad x1 carbon - intel core i7 4600u -... [view my complete system specs]
  • Tue, Feb 17 2015 5:08 PM In reply to
    • David Clarke
    • Posts 239
    • Points 3,255
    I am afraid I don't have an answer.  It does seem to be an Avid problem.  I recently updated the firmware on my camera with no affect.
